| [TABLE] Ghostbuster Stern | |
+187Kenshiro68 CEGCAB TontonChelou shalkys ozloz31000 giotta stanimal CalimeroOeuf El'Baronrouge lemerle benoitdu77 biuod hypermc dario7218 Kidloco alucard_xs PO5481 cyrgeta Powerus Moussounet tomimpakt Darven Arkan07 dav7 yopsolo Steeven.14 hobuxo njaynl zack06007 Nesta78 leeoneil Francis971 berserk flajolbass ryguy417 julian1976 tealk oroborus77 heyjoe laulaw06 PDERYCHE marmotte666 stoneheart Maxwell42 ebor zax badcat zekill seriousam28270 ozon davadruix blouik titi29 Flaviox bono flashpc Vincent0047 defre1976 jawah philgoods9 leopold GUILLAUME49 Benoit33 katanka sarsouille28 tlub fraglerok01 17Al3x17 Draken06 colsaber Krys76 beckscc2010 Bigbeefr Snorky gangstaalien777 VPtouko810 foxyt roms34 vothar altimeuler GéraldB vilko zoubiwan quen ducatfrank nico7575 nitros alivan Fibology mrtr32 JohnRofls olijez Colonelpacman BorisFR TylerDurden67 vnguyenquangdo guhtravesso thebeast0449 Lee dujack Mikcab Rey blc29 doraj90 xphilou29 nicofab18 junkbox35 gigalula mikuslegrand sOuLWwX Kern glx Satansx phl0ve joku ze-bob POOTERMAN zedrummer giannibini lustucul BonZ@i TheHighFlying magnum1976 ElricDesDragons Carny_Priest sebinouse le.ced samsmile Rhis Spidey077 djtete pietjepukel jeyspeed optikazz Magicaurel Citron68 mikevirgil zubial moviemaniac52 snwfrd38 Sebcemoi neofr45 jéjé83520 jphil82 belgarion41 wspawn Mick_03 miket37 Mandrack obtender spike56 mouche jObiwan DamsBALL nussss lololol foudcox darkslide Nnanard8 Jannek42 chucky87 grozby88 xavelios khomodo g57 mariopourlavie PHILI50 garath AnthozoA jimenez nairolf firebrand007 Aetios ktmboy manples peskopat bip-bip-72 kwak vulbas lavache599 leevuth razorbaxx RipleYYY arngrim ced Shadow_SHD tom tower 191 participants |
Mick_03
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 19:07 | |
| C'est bon, en fait j'ai pas été assez patient ^^ effectivement y'a des flash ^^ | |
wspawn
Messages : 239 Département : Belgique
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 19:09 | |
| Depuis l'installation de ghostbuster , mes table ont plus de son au lancement , mais apparait seulement quand j'ai mis un credit et lancer le jeux . une idee? | |
belgarion41
Messages : 365 Département : 41
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 20:24 | |
| Salut,
Moi j'ai un dmd lcd, et je n'arrive pas a avoir la palette de couleur de Shadow (Bleu). Ca marche seulement en mode Test de vpinSpa. Et j'ai bien mis le répertoire dans le altcolor du vPinMame classic.
Une idée ? | |
jphil82
Messages : 106 Département : 82
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 20:42 | |
| enfin ,j'ais installé Ghosbuster marche tres bien dmd de couleur vert manifique ,mais il m'a fallu une re installation de windows10 @ [Vous devez être inscrit et connecté pour voir ce lien] le fichier pal dans altcolor ,dans Vpinspa | |
Mandrack
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 21:20 | |
| Quand jecoche "use external DMD" je n'ai plus de DMD et j'ai "No dmd devine driver found" qui apparaît. J'ai un lcd en ecran dmd. | |
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 21:23 | |
| bah c est normal, tu n'as pas de DMD EXTERNE ( pin2dmd ou autre genre) tu as un ecran !! rien a voir | |
Mandrack
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 21:36 | |
| Merci lololol c'est un peu la réponse que j'attendais, car je vois écrit plusieurs fois cocher use external dmd. Du coup avec mon ecran je peux avoir le mode couleur sur ghostbuster? Car j'ai mis tous les fichiers mais je n'ai toujours pas de couleur | |
Mick_03
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 22:00 | |
| J'ai un écran lcd et j'ai les couleurs avec use external dmd que ce soit ghostbusters, acdc, star trek et autre utilisant le dossier altcolor.
Mais il faut aussi cocher colorize dmd (la ligne en dessous) sinon ça marche pas. | |
miket37
Messages : 197 Département : tours
| Sujet: [EN COURS] probleme msvcp110.dll Lun 19 Mar 2018 - 22:03 | |
| msvcp110.dll n est pas concu pour s executè sous windows ou il contient des erreurs G installer plusieur fois c++ 2013 C'est le message d erreur que j ai quand je lance la ghosbusters je suis en 32 bit j espere que c pas ca qui pose probleme sinon g vu un logiciel qui se nomme dmdext a quoi sert t il existe t il en version 32 bit
je sais ca fait beaucoup de questions mais je suis trop impatient de tester cette table merci encore | |
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 22:13 | |
| [Vous devez être inscrit et connecté pour voir ce lien] faire un copier/coller du MP que tu m’as envoyé c’est bien mais là sorti du contexte dans un nouveau sujet qui a à priori plus à voir avec Windows plutôt qu’avec une table VPX = un sujet destiné aux archives du forum D’autant qu’à deux reprises je t’ai demandé de poster ton problème dans le sujet de la table pas de créer un nouveau sujet à chaque problème rencontré avec cette même table; au final on se retrouve avec 10 sujets traitant d’une même table et c’est contre-productif Du coup j’ai fusionné ton sujet avec celui de la table Ghostbusters LE ++ | |
Mandrack
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 23:18 | |
| [Vous devez être inscrit et connecté pour voir ce lien] j'ai bien coché colorize DMD mais j'ai pas de couleur. | |
belgarion41
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 23:49 | |
| Pareil, le colorize est coché et le altcolor est aussi bien dans le vPinmame que le vPinSpa, et pas de full couleurs non plus (juste les 4 dans les options) | |
moviemaniac52
| Sujet: Re: [TABLE] Ghostbuster Stern Lun 19 Mar 2018 - 23:57 | |
| Hello à tous, dites voir je suis le seul à avoir le dof qui merde??? par exemple, le flasher droit n'est jamais utilisé...
Bon et si j'arrete deux minutes de me plaindre parce que le boulot sur cette table est plus que extraordinaire | |
wspawn
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 6:48 | |
| Oui je me suis posee la question . J ai un des flasheur a droite qui est presque jamais utiliser
Une solution pour que la table soit en credit et pas free to play ? ( la rom garde pas en mémoire les modification ) | |
mouche
Messages : 177 Département : 87
| Sujet: palette couleur Mar 20 Mar 2018 - 7:59 | |
| salut voici une palette couleur tres propre pour ghostbusters teinte cuivre et or ,meme si on est pas encore dans le rouge est blanc le code couleur du logo ghostbusters mais elle est de tres belle qualité
clic ici | |
moviemaniac52
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 8:13 | |
| [Vous devez être inscrit et connecté pour voir ce lien] Chez moi la configuration reste bien en memoire avec la bonne dll | |
jphil82
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 8:15 | |
Mandrack
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 9:01 | |
mouche
| Sujet: backglass Mar 20 Mar 2018 - 10:55 | |
| voila ma version perso du flip [Vous devez être inscrit et connecté pour voir cette image] | |
darkslide
Messages : 221 Département : 31
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 11:21 | |
| Chez moi n’ont plus, la rom ne garde pas en mémoire les réglages... impossible de mettre extraball pour le gain d’un special. | |
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 14:41 | |
| C'est normal les gars ça reste de la "bidouille" pour faire tourner le fichier Pinball Arcade, la plupart des modifications faites dans le menu de la ROM n'est donc pas sauvegardée quand on quitte la table. On peut par contre changer Free play ou Credit dans le fichier txt ou ini (je ne sais plus je suis au taf) du dossier spagb_100, mais même si on met Credit ça revient à 0 quand on relance la table ++ | |
darkslide
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 14:59 | |
| OK merci pour l’info shadow, Ça ne vient pas de mon installation alors. | |
wspawn
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 15:19 | |
| Que sa retombe a zero n est pas un soucis mais e veux rentabiliser mon bouton credit | |
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 19:47 | |
| Il faut éditer le fichier C:\Visual Pinball\VPinSPA\spagb100\gbnv.txt : FreePlay:1 ou 0 pour mode payantVolume:80 Language:0 ou 2 pour FranceBallsPerGame:3 Ce fichier contient les paramètres qui ne sont pas sauvegardés par la "fausse ROM" spagb_100 ++ | |
moviemaniac52
| Sujet: Re: [TABLE] Ghostbuster Stern Mar 20 Mar 2018 - 19:52 | |
| Quelle table quand meme...quelq'un a deja eu le mode Scare??? | |
