| | [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO | |
+26krusty milani73 benben Sebcemoi josmagerotte andersonleite mcdmofr yoyofr Titeuf01800 MAXxXAM Arcaxe arnoz seregon VroOnsh doraj90 vietscong Snorky Dantes917 leopold vnguyenquangdo bobox59 zedrummer khinyo tyra38 ebor leguluc 30 participants | |
leguluc
Messages : 91 Département : 56230
| Sujet: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 16:37 | |
| avec le tuto arnoz ca ne ce lance pas non plus mais j ai ce log - Code:
--------------------------------------------------------------------------------- DirectOutput Version 3.1.6999.23272, built 2019.03.01 12:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | [Vous devez être inscrit et connecté pour voir ce lien]2020.08.03 16:33:55.929 DirectOutput Logger initialized 2020.08.03 16:33:55.912 Global config filename is "C:\DirectOutput\Config\GlobalConfig.xml" 2020.08.03 16:33:55.929 Global config loaded from: C:\DirectOutput\Config\GlobalConfig.xml 2020.08.03 16:33:55.929 Loading Pinball parts 2020.08.03 16:33:55.929 Loading cabinet 2020.08.03 16:33:55.931 Will load cabinet config file: C:\DirectOutput\Config\cabinet.xml 2020.08.03 16:33:56.024 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2020.08.03 16:33:56.025 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2020.08.03 16:33:56.026 Cabinet auto configuration started 2020.08.03 16:33:56.050 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2020.08.03 16:33:56.050 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16 2020.08.03 16:33:56.057 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2020.08.03 16:33:56.066 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.03 16:33:56.066 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.03 16:33:56.066 HID caps: usage page=1, usage=4, number of link collection nodes=1, output report byte length=9 2020.08.03 16:33:56.068 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.03 16:33:56.068 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.03 16:33:56.069 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.03 16:33:56.069 HID caps: usage page=12, usage=1, number of link collection nodes=1, output report byte length=0 2020.08.03 16:33:56.070 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.03 16:33:56.071 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.03 16:33:56.072 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.03 16:33:56.072 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.03 16:33:56.075 Opening 32-bit LedWiz driver... 2020.08.03 16:33:56.075 Detected and added LedWiz Nr. 1 with name LedWiz 01 2020.08.03 16:33:56.075 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1 2020.08.03 16:33:56.080 Cabinet auto configuration finished 2020.08.03 16:33:56.080 Autoconfig complete. 2020.08.03 16:33:56.080 Cabinet config loaded successfully from C:\DirectOutput\Config\cabinet.xml 2020.08.03 16:33:56.080 Cabinet loaded 2020.08.03 16:33:56.080 Loading table config 2020.08.03 16:33:56.081 Warning: No table config file found. Will try to load config from LedControl file(s). 2020.08.03 16:33:56.081 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName afm 2020.08.03 16:33:56.084 Loading LedControl file C:\DirectOutput\Config\directoutputconfig.ini 2020.08.03 16:33:56.088 Min DOF Version is 0.8 for file directoutputconfig.ini 2020.08.03 16:33:56.285 Loading LedControl file C:\DirectOutput\Config\directoutputconfig30.ini 2020.08.03 16:33:56.315 Min DOF Version is 0.8 for file directoutputconfig30.ini 2020.08.03 16:33:59.587 Loading LedControl file C:\DirectOutput\Config\directoutputconfig51.ini 2020.08.03 16:33:59.589 Min DOF Version is 0.8 for file directoutputconfig51.ini 2020.08.03 16:33:59.785 3 directoutputconfig.ini or ledcontrol.ini files loaded. 2020.08.03 16:33:59.787 Config for RomName afm exists in LedControl data. Updating cabinet and config. 2020.08.03 16:33:59.829 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.03 16:33:59.830 Table config loading finished: romname=afm, tablename=Attack from Mars (1995) 2020.08.03 16:33:59.832 Pinball parts loaded 2020.08.03 16:33:59.833 Starting processes 2020.08.03 16:33:59.833 Initializing cabinet 2020.08.03 16:33:59.833 Debug: Initializing output controllers 2020.08.03 16:33:59.837 TeensyStripController TeensyStripController intialized and updater thread started. 2020.08.03 16:33:59.837 Pinscape Pinscape Controller 01 intialized and updater thread started. 2020.08.03 16:33:59.838 Debug: Initializing LedWiz Nr. 01 2020.08.03 16:33:59.838 TeensyStripController TeensyStripController updater thread started. 2020.08.03 16:33:59.838 Pinscape Pinscape Controller 01 updater thread started. 2020.08.03 16:33:59.838 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2020.08.03 16:33:59.840 LedWiz Nr. 01 initialized and updater thread initialized. 2020.08.03 16:33:59.840 Debug: Output controllers initialized 2020.08.03 16:33:59.840 Updater thread for LedWiz 01 started. 2020.08.03 16:33:59.846 Cabinet initialized 2020.08.03 16:33:59.847 Loading shape definition file: C:\DirectOutput\Config\DirectOutputShapes.xml 2020.08.03 16:33:59.885 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:80), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:4, Width:30, Height:5) 2020.08.03 16:33:59.886 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:80), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:4, Width:30, Height:5) 2020.08.03 16:33:59.886 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:65, W:100, H:15), Matrix(W:6, H:30), ResultArea(Left: 0, Top:3, Right:29, Bottom:4, Width:30, Height:2) 2020.08.03 16:33:59.886 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:70, W:100, H:20), Matrix(W:6, H:30), ResultArea(Left: 0, Top:4, Right:29, Bottom:5, Width:30, Height:2) 2020.08.03 16:33:59.887 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.890 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.913 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.916 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.916 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.916 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.916 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.916 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.917 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.918 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.919 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.919 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.919 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.03 16:33:59.919 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.03 16:33:59.919 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:100), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:5, Width:30, Height:6) 2020.08.03 16:33:59.933 Framework initialized. 2020.08.03 16:33:59.933 Have fun! 2020.08.03 16:34:07.723 Finishing framework 2020.08.03 16:34:07.726 Finishing cabinet 2020.08.03 16:34:07.726 Debug: Finishing output controllers 2020.08.03 16:34:08.734 EXCEPTION: TeensyStripController TeensyStripController updater thread could not connect to the controller. Thread will quit. 2020.08.03 16:34:08.734 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.03 16:34:08.734 EXCEPTION: Message: ThreadAbortException --> Le thread a été abandonné. 2020.08.03 16:34:08.742 EXCEPTION: Stacktrace: à System.Threading.Thread.SleepInternal(Int32 millisecondsTimeout) 2020.08.03 16:34:08.742 EXCEPTION: Stacktrace: à System.Threading.Thread.Sleep(Int32 millisecondsTimeout) 2020.08.03 16:34:08.742 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.ConnectToController() 2020.08.03 16:34:08.742 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.03 16:34:08.742 EXCEPTION: Targetsite: Void SleepInternal(Int32) 2020.08.03 16:34:08.741 Warning: TeensyStripController TeensyStripController updater thread did not quit. Forcing abort. 2020.08.03 16:34:08.743 TeensyStripController TeensyStripController finished and updater thread stopped. 2020.08.03 16:34:08.744 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2020.08.03 16:34:08.744 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2020.08.03 16:34:08.744 Debug: Finishing LedWiz Nr. 01 2020.08.03 16:34:08.744 EXCEPTION: A exception has occured in TeensyStripController TeensyStripController updater thread . Thread will quit. Message: Le thread a été abandonné. 2020.08.03 16:34:08.744 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.03 16:34:08.744 EXCEPTION: Message: ThreadAbortException --> Le thread a été abandonné. 2020.08.03 16:34:08.745 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.03 16:34:08.745 EXCEPTION: Targetsite: Void UpdaterThreadDoIt() 2020.08.03 16:34:08.744 Updater thread for LedWiz 01 terminated. 2020.08.03 16:34:08.747 LedWiz Nr. 01 finished and updater thread stopped. 2020.08.03 16:34:08.748 Debug: Output controllers finished 2020.08.03 16:34:08.748 Cabinet finished 2020.08.03 16:34:08.748 DirectOutput framework finished. 2020.08.03 16:34:08.748 Bye and thanks for using! 2020.08.03 16:34:08.769 Debug: Disposing LedWiz instance 01. | |
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 17:17 | |
| Et tes fichiers sont sur le C: ou le D: ? Dans le log, il y a marqué C: alors que tu parlais auparavant du D: | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 17:48 | |
| J ai refais l install sur c: en espérant que ca fonctionne La partie pup est sur d car trop volumineux | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 17:52 | |
| Le problème vient vraiment du dof.j aurais dû acheter une teensy | |
| | | tyra38
Messages : 226 Département : 38
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 18:05 | |
| Dans le device WS2811 1 - directoutputconfigini30 le combo 1 , la backboard est bien sûr le port 1 du dof. De mémoire c'est bien la sortie d5 de la weemos. Courage , il m'a fallut plusieurs jours pour faire fonctionner le bidule......le problème c'est qu'à force de bidouiller on ne souvient pas de tout ce qu l'on a fait..... | |
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 18:15 | |
| Et juste pour reprendre sur les bases,
- Tes leds s'allument bien lorsque tu rebranches la Wemos ou que tu la flashes ?
- Lorsque tu fais le test via DirectOutputConfigTester, tu as enfin quelque chose pour la table AFM par exemple ?
- Le plugin DirectOutput est toujours bien activé ?
Tu peux faire un test en mettant sur le D6 et modifier en conséquence le port dans le DOF (4) ? Et du coup, modifier aussi le xml. | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 18:38 | |
| Dof est a la racine de c.je le désinstalle proprement a chaque nouvelle install | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 18:54 | |
| Lors du demarrage du pc mes les led s'allume,pareil pour le flashage.j ai jamais reussi a faire fonctionner le dof modifié malgré le tuto de pincabpassion et celui d arnoz. Je refais un test ce soir.en passant par un dof officiel j arrive a faire fonctionner mes toys | |
| | | khinyo
Messages : 237 Département : 69
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 19:40 | |
| [Vous devez être inscrit et connecté pour voir ce lien] salut a toi Évite de reposter juste après un de tes messages sinon tu vas finir par te faire souffler dans les bronches. J'ai survolé un peu tes messages. Si tes led s allument à la mise sous tension c'est déjà une bonne chose, le câblage est apparemment bon et la sortie D5 me semble etre la bonne. Tu aurais voulu une teensy?...et bien c'est exactement la même chose que la wemos. Et je t avoue que ma teensy m'a fait perdre le peu de cheveux qui me restait sur le crane. Tout ça parce que à un moment donner j'ai pas voulu faire comme tout le monde...répertoire, chemin d accès, câblage. Et puis pour un éventuel dépannage c'est pas évident pour celui qui te viens en aide. Avec quel soft tu modifies tes fichiers xml? J'ai eu le soucis avec notepad qui a un moment donné avait enregistré le cabinet au format texte mais avec l extension xml donc inexploitable par le DOF. Pour les modifs j utilise notepad++ qui a l avantage de mettre les paramètres modifiables dans une couleur différente.Je vais me replonger dans tes post et voir si j arrive à t aider | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Lun 3 Aoû 2020 - 20:14 | |
| J édite mes xml avec note++ également Le cablage est simple car j ai le kit wemos+tenmos+le voltV2.de ce coté là je pense que c est ok.le probleme je pense vien du dof qui communique mal avec vpx.pourquoi?je c est pas.le tuto dof modifié est pourtant si simple.jme relance dedans ce soir. | |
| | | zedrummer Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 9:13 | |
| Est-ce que ton DOF fonctionne déjà avec les autres toys, ceux branchés sur la KL25Z? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 10:29 | |
| Salut.oui mes toys fonctionnent bien .Je suis branché sur une klshield . Question!Sambuild peut il être a l origine de ce problème ? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 13:15 | |
| [Vous devez être inscrit et connecté pour voir ce lien]zedrummer voici mon log - Code:
DirectOutput Version 3.1.6999.23272, built 2019.03.01 12:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | [Vous devez être inscrit et connecté pour voir ce lien]2020.08.04 13:09:38.826 DirectOutput Logger initialized 2020.08.04 13:09:38.809 Global config filename is "C:\DirectOutput\Config\GlobalConfig.xml" 2020.08.04 13:09:38.826 Global config loaded from: C:\DirectOutput\Config\GlobalConfig.xml 2020.08.04 13:09:38.826 Loading Pinball parts 2020.08.04 13:09:38.826 Loading cabinet 2020.08.04 13:09:38.827 Will load cabinet config file: C:\DirectOutput\Config\Cabinet.xml 2020.08.04 13:09:38.940 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2020.08.04 13:09:38.945 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2020.08.04 13:09:38.946 Cabinet auto configuration started 2020.08.04 13:09:38.975 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2020.08.04 13:09:38.976 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16 2020.08.04 13:09:38.983 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2020.08.04 13:09:38.991 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.04 13:09:38.991 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.04 13:09:38.991 HID caps: usage page=1, usage=4, number of link collection nodes=1, output report byte length=9 2020.08.04 13:09:38.992 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.04 13:09:38.993 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.04 13:09:38.993 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.04 13:09:38.993 HID caps: usage page=12, usage=1, number of link collection nodes=1, output report byte length=0 2020.08.04 13:09:38.994 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.04 13:09:38.995 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.04 13:09:38.996 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.04 13:09:38.997 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.04 13:09:38.999 Opening 32-bit LedWiz driver... 2020.08.04 13:09:39.000 Detected and added LedWiz Nr. 1 with name LedWiz 01 2020.08.04 13:09:39.000 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1 2020.08.04 13:09:39.004 Cabinet auto configuration finished 2020.08.04 13:09:39.004 Autoconfig complete. 2020.08.04 13:09:39.004 Cabinet config loaded successfully from C:\DirectOutput\Config\Cabinet.xml 2020.08.04 13:09:39.004 Cabinet loaded 2020.08.04 13:09:39.004 Loading table config 2020.08.04 13:09:39.004 Warning: No table config file found. Will try to load config from LedControl file(s). 2020.08.04 13:09:39.004 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName afm 2020.08.04 13:09:39.008 Loading LedControl file C:\DirectOutput\Config\directoutputconfig30.ini 2020.08.04 13:09:39.039 Min DOF Version is 0.8 for file directoutputconfig30.ini 2020.08.04 13:09:42.318 Loading LedControl file C:\DirectOutput\Config\directoutputconfig51.ini 2020.08.04 13:09:42.319 Min DOF Version is 0.8 for file directoutputconfig51.ini 2020.08.04 13:09:42.512 2 directoutputconfig.ini or ledcontrol.ini files loaded. 2020.08.04 13:09:42.513 Config for RomName afm exists in LedControl data. Updating cabinet and config. 2020.08.04 13:09:42.554 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30 2020.08.04 13:09:42.555 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30 2020.08.04 13:09:42.556 Table config loading finished: romname=afm, tablename=Attack from Mars (1995) 2020.08.04 13:09:42.557 Pinball parts loaded 2020.08.04 13:09:42.558 Starting processes 2020.08.04 13:09:42.558 Initializing cabinet 2020.08.04 13:09:42.558 Debug: Initializing output controllers 2020.08.04 13:09:42.562 TeensyStripController TeensyStripController intialized and updater thread started. 2020.08.04 13:09:42.562 Pinscape Pinscape Controller 01 intialized and updater thread started. 2020.08.04 13:09:42.563 Debug: Initializing LedWiz Nr. 01 2020.08.04 13:09:42.563 TeensyStripController TeensyStripController updater thread started. 2020.08.04 13:09:42.563 Pinscape Pinscape Controller 01 updater thread started. 2020.08.04 13:09:42.563 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2020.08.04 13:09:42.564 LedWiz Nr. 01 initialized and updater thread initialized. 2020.08.04 13:09:42.564 Debug: Output controllers initialized 2020.08.04 13:09:42.565 Updater thread for LedWiz 01 started. 2020.08.04 13:09:42.570 Cabinet initialized 2020.08.04 13:09:42.573 Loading shape definition file: C:\DirectOutput\Config\DirectOutputShapes.xml 2020.08.04 13:09:42.611 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:80), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:4, Width:30, Height:5) 2020.08.04 13:09:42.611 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:80), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:4, Width:30, Height:5) 2020.08.04 13:09:42.611 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:65, W:100, H:15), Matrix(W:6, H:30), ResultArea(Left: 0, Top:3, Right:29, Bottom:4, Width:30, Height:2) 2020.08.04 13:09:42.612 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:70, W:100, H:20), Matrix(W:6, H:30), ResultArea(Left: 0, Top:4, Right:29, Bottom:5, Width:30, Height:2) 2020.08.04 13:09:42.613 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.615 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.638 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.641 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.641 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.641 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.642 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.643 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2) 2020.08.04 13:09:42.644 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 1, BMT: 18, BMW: 16, BMH: 16 2020.08.04 13:09:42.644 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:100), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:5, Width:30, Height:6) 2020.08.04 13:09:42.657 Framework initialized. 2020.08.04 13:09:42.657 Have fun! 2020.08.04 13:09:51.636 EXCEPTION: Could not put the controller on com-port COM8 into the commandmode. Will not send data to the controller. 2020.08.04 13:09:51.636 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.04 13:09:51.638 TeensyStripController TeensyStripController updater thread has connected to TeensyStripController TeensyStripController. 2020.08.04 13:09:51.638 EXCEPTION: TeensyStripController TeensyStripController updater thread could not send update for TeensyStripController TeensyStripController: Comport is not initialized. Will try again. 2020.08.04 13:09:51.638 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.04 13:09:51.638 EXCEPTION: Message: Exception --> Comport is not initialized 2020.08.04 13:09:51.640 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.UpdateOutputs(Byte[] OutputValues) 2020.08.04 13:09:51.640 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.04 13:09:51.640 EXCEPTION: Targetsite: Void UpdateOutputs(Byte[]) 2020.08.04 13:09:51.640 Warning: TeensyStripController TeensyStripController updater thread tries to reconnect to TeensyStripController TeensyStripController. 2020.08.04 13:09:53.916 Finishing framework 2020.08.04 13:09:53.919 Finishing cabinet 2020.08.04 13:09:53.920 Debug: Finishing output controllers 2020.08.04 13:09:54.908 EXCEPTION: TeensyStripController TeensyStripController updater thread could not reconnect to the controller. Thread will quit. 2020.08.04 13:09:54.908 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.04 13:09:54.908 EXCEPTION: Message: Exception --> A exception occured while trying to open the Com-port 'COM8'. Found the following Com-Ports: COM8. Will not send data to the controller. 2020.08.04 13:09:54.909 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.ConnectToController() 2020.08.04 13:09:54.909 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.04 13:09:54.909 EXCEPTION: Targetsite: Void ConnectToController() 2020.08.04 13:09:54.909 EXCEPTION: InnerException 1: ThreadAbortException --> Le thread a été abandonné. 2020.08.04 13:09:54.911 EXCEPTION: A exception has occured in TeensyStripController TeensyStripController updater thread . Thread will quit. Message: Le thread a été abandonné. 2020.08.04 13:09:54.911 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.04 13:09:54.911 EXCEPTION: Message: ThreadAbortException --> Le thread a été abandonné. 2020.08.04 13:09:54.911 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.04 13:09:54.911 EXCEPTION: Targetsite: Void UpdaterThreadDoIt() 2020.08.04 13:09:54.929 Warning: TeensyStripController TeensyStripController updater thread did not quit. Forcing abort. 2020.08.04 13:09:54.929 TeensyStripController TeensyStripController finished and updater thread stopped. 2020.08.04 13:09:54.929 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2020.08.04 13:09:54.930 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2020.08.04 13:09:54.930 Debug: Finishing LedWiz Nr. 01 2020.08.04 13:09:54.930 Updater thread for LedWiz 01 terminated. 2020.08.04 13:09:54.941 LedWiz Nr. 01 finished and updater thread stopped. 2020.08.04 13:09:54.941 Debug: Output controllers finished 2020.08.04 13:09:54.941 Cabinet finished 2020.08.04 13:09:54.941 DirectOutput framework finished. 2020.08.04 13:09:54.941 Bye and thanks for using! 2020.08.04 13:09:54.957 Debug: Disposing LedWiz instance 01. | |
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 13:43 | |
| Bizarre ça, pourquoi port 8 :
Tu as utilisé un Philips Hue ? Tu pourras nous montrer ce que ça donne ? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 13:49 | |
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 14:39 | |
| Là, il te dit clairement qu'il ne peut pas se connecter au port COM8. Pour info, voilà la version qui est affichée au début de mon log :DirectOutput Version 0.9.6474.38194 as of 2017.09.22 21:13 Pas grand chose à voir avec la tienne. Tu as bien pris la version modifiée qui est ICI ? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 15:14 | |
| avec ce dof ,j ai ce log et vpx ce lance plus - Code:
2020.08.04 15:12:21.140 DirectOutput Logger initialized 2020.08.04 15:12:21.140 DirectOutput Version 0.9.6474.38194 as of 2017.09.22 21:13 2020.08.04 15:12:21.140 Global config loaded from: C:\DirectOutput\Config\GlobalConfig.xml 2020.08.04 15:12:21.140 Loading Pinball parts 2020.08.04 15:12:21.140 Loading cabinet 2020.08.04 15:12:21.142 Will load cabinet config file: C:\DirectOutput\Config\Cabinet.xml 2020.08.04 15:12:21.220 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2020.08.04 15:12:21.220 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2020.08.04 15:12:21.221 Cabinet auto configuration started 2020.08.04 15:12:21.254 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2020.08.04 15:12:21.255 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16 2020.08.04 15:12:21.265 Debug: Ledwiz devicelist content. Handles: 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Num devices: 1 2020.08.04 15:12:21.265 Debug: Disposing LedWiz instance -01.
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 15:26 | |
| A ma connaissance, c'est le seul dof compatible wemos. Tu as qq chose de parlant dans le log de vpx pour voir ce qui le fait planter ? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mar 4 Aoû 2020 - 15:48 | |
| | | ebor Modérateur
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mer 5 Aoû 2020 - 8:34 | |
| C'est difficile de te suivre, tu es un coup sur le C:, puis sur le D: selon les extraits de Log que tu nous montres et donc selon les versions du DOF que tu prends. Ton raccourci 'DirectOutput' est bien mis à jour à chaque fois dans le répertoire Vpinmame\Plugins ? Avec le DirectOutput compatible Wemos et le bon raccourci, tu as quoi dans le crash.txt du répertoire Tables ? | |
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mer 5 Aoû 2020 - 11:42 | |
| Apres formatage complet .Le dof modifié ne fonctionne tjrs pas chez moi.Pire il empêche vpx de démarrer Si une personne l a déjà installé faites moi signe svp .Mon log dof: - Code:
2020.08.05 11:34:21.678 DirectOutput Logger initialized 2020.08.05 11:34:21.678 DirectOutput Version 0.9.6474.38194 as of 2017.09.22 21:13 2020.08.05 11:34:21.679 Global config loaded from: D:\PINBALLJUNE2020\Visual Pinball\Tables\plugins\DirectOutput\config\GlobalConfig.xml 2020.08.05 11:34:21.679 Loading Pinball parts 2020.08.05 11:34:21.679 Loading cabinet 2020.08.05 11:34:21.680 Will load cabinet config file: D:\PINBALLJUNE2020\Visual Pinball\Tables\plugins\DirectOutput\config\Cabinet.xml 2020.08.05 11:34:21.758 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2020.08.05 11:34:21.758 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2020.08.05 11:34:21.759 Cabinet auto configuration started 2020.08.05 11:34:21.789 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2020.08.05 11:34:21.789 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16 2020.08.05 11:34:21.826 Debug: Ledwiz devicelist content. Handles: 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Num devices: 1 2020.08.05 11:34:21.826 Debug: Disposing LedWiz instance -01.
| | | leguluc
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Ven 7 Aoû 2020 - 17:44 | |
| bonjours après formatage et réinstalle complète(le dof de mjr sur le site arnoz).VPX ce lance bien ainsi que tous mes toys. probleme toujours pas de led.Voici mon log dof - Code:
DirectOutput Version 3.1.6999.23272, built 2019.03.01 12:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | [Vous devez être inscrit et connecté pour voir ce lien]2020.08.07 17:37:51.212 DirectOutput Logger initialized 2020.08.07 17:37:51.194 Global config filename is "C:\DirectOutput\config\GlobalConfig.xml" 2020.08.07 17:37:51.212 Global config loaded from: C:\DirectOutput\config\GlobalConfig.xml 2020.08.07 17:37:51.212 Loading Pinball parts 2020.08.07 17:37:51.212 Loading cabinet 2020.08.07 17:37:51.213 Will load cabinet config file: C:\DirectOutput\config\Cabinet.xml 2020.08.07 17:37:51.315 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2020.08.07 17:37:51.316 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2020.08.07 17:37:51.317 Cabinet auto configuration started 2020.08.07 17:37:51.345 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2020.08.07 17:37:51.345 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16 2020.08.07 17:37:51.353 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2020.08.07 17:37:51.362 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.07 17:37:51.362 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.07 17:37:51.362 HID caps: usage page=1, usage=4, number of link collection nodes=1, output report byte length=9 2020.08.07 17:37:51.364 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.07 17:37:51.364 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.07 17:37:51.364 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet 2020.08.07 17:37:51.364 HID caps: usage page=12, usage=1, number of link collection nodes=1, output report byte length=0 2020.08.07 17:37:51.364 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech 2020.08.07 17:37:51.365 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.07 17:37:51.367 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.07 17:37:51.368 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available> 2020.08.07 17:37:51.370 Opening 32-bit LedWiz driver... 2020.08.07 17:37:51.371 Detected and added LedWiz Nr. 1 with name LedWiz 01 2020.08.07 17:37:51.371 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1 2020.08.07 17:37:51.375 Cabinet auto configuration finished 2020.08.07 17:37:51.375 Autoconfig complete. 2020.08.07 17:37:51.375 Cabinet config loaded successfully from C:\DirectOutput\config\Cabinet.xml 2020.08.07 17:37:51.375 Cabinet loaded 2020.08.07 17:37:51.375 Loading table config 2020.08.07 17:37:51.376 Warning: No table config file found. Will try to load config from LedControl file(s). 2020.08.07 17:37:51.376 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName cv 2020.08.07 17:37:51.378 Loading LedControl file C:\DirectOutput\config\directoutputconfig30.ini 2020.08.07 17:37:51.429 Min DOF Version is 0.8 for file directoutputconfig30.ini 2020.08.07 17:37:55.050 Loading LedControl file C:\DirectOutput\config\directoutputconfig51.ini 2020.08.07 17:37:55.052 Min DOF Version is 0.8 for file directoutputconfig51.ini 2020.08.07 17:37:55.230 2 directoutputconfig.ini or ledcontrol.ini files loaded. 2020.08.07 17:37:55.231 Config for RomName cv exists in LedControl data. Updating cabinet and config. 2020.08.07 17:37:55.269 Table config loading finished: romname=cv, tablename=Cirqus Voltaire (1997) 2020.08.07 17:37:55.270 Pinball parts loaded 2020.08.07 17:37:55.271 Starting processes 2020.08.07 17:37:55.271 Initializing cabinet 2020.08.07 17:37:55.271 Debug: Initializing output controllers 2020.08.07 17:37:55.275 TeensyStripController TeensyStripController intialized and updater thread started. 2020.08.07 17:37:55.275 Pinscape Pinscape Controller 01 intialized and updater thread started. 2020.08.07 17:37:55.276 Debug: Initializing LedWiz Nr. 01 2020.08.07 17:37:55.276 TeensyStripController TeensyStripController updater thread started. 2020.08.07 17:37:55.276 Pinscape Pinscape Controller 01 updater thread started. 2020.08.07 17:37:55.276 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2020.08.07 17:37:55.278 LedWiz Nr. 01 initialized and updater thread initialized. 2020.08.07 17:37:55.278 Debug: Output controllers initialized 2020.08.07 17:37:55.279 Updater thread for LedWiz 01 started. 2020.08.07 17:37:55.284 Cabinet initialized 2020.08.07 17:37:55.288 Loading shape definition file: C:\DirectOutput\config\DirectOutputShapes.xml 2020.08.07 17:37:55.321 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:15), Matrix(W:6, H:60), ResultArea(Left: 0, Top:0, Right:59, Bottom:0, Width:60, Height:1) 2020.08.07 17:37:55.321 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:85, W:100, H:15), Matrix(W:6, H:60), ResultArea(Left: 0, Top:5, Right:59, Bottom:5, Width:60, Height:1) 2020.08.07 17:37:55.322 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:15), Matrix(W:6, H:60), ResultArea(Left: 0, Top:0, Right:59, Bottom:0, Width:60, Height:1) 2020.08.07 17:37:55.322 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:85, W:100, H:15), Matrix(W:6, H:60), ResultArea(Left: 0, Top:5, Right:59, Bottom:5, Width:60, Height:1) 2020.08.07 17:37:55.333 Framework initialized. 2020.08.07 17:37:55.333 Have fun! 2020.08.07 17:38:00.902 Finishing framework 2020.08.07 17:38:00.904 Finishing cabinet 2020.08.07 17:38:00.905 Debug: Finishing output controllers 2020.08.07 17:38:01.906 EXCEPTION: TeensyStripController TeensyStripController updater thread could not connect to the controller. Thread will quit. 2020.08.07 17:38:01.906 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.07 17:38:01.907 EXCEPTION: Message: ThreadAbortException --> Le thread a été abandonné. 2020.08.07 17:38:01.915 EXCEPTION: Stacktrace: à System.Threading.Thread.SleepInternal(Int32 millisecondsTimeout) 2020.08.07 17:38:01.915 EXCEPTION: Stacktrace: à System.Threading.Thread.Sleep(Int32 millisecondsTimeout) 2020.08.07 17:38:01.916 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.ConnectToController() 2020.08.07 17:38:01.916 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.07 17:38:01.916 EXCEPTION: Targetsite: Void SleepInternal(Int32) 2020.08.07 17:38:01.918 EXCEPTION: A exception has occured in TeensyStripController TeensyStripController updater thread . Thread will quit. Message: Le thread a été abandonné. 2020.08.07 17:38:01.918 EXCEPTION: Thread: TeensyStripController TeensyStripController updater thread 2020.08.07 17:38:01.918 EXCEPTION: Message: ThreadAbortException --> Le thread a été abandonné. 2020.08.07 17:38:01.918 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt() 2020.08.07 17:38:01.918 EXCEPTION: Targetsite: Void UpdaterThreadDoIt() 2020.08.07 17:38:01.921 Warning: TeensyStripController TeensyStripController updater thread did not quit. Forcing abort. 2020.08.07 17:38:01.921 TeensyStripController TeensyStripController finished and updater thread stopped. 2020.08.07 17:38:01.922 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2020.08.07 17:38:01.922 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2020.08.07 17:38:01.922 Debug: Finishing LedWiz Nr. 01 2020.08.07 17:38:01.922 Updater thread for LedWiz 01 terminated. 2020.08.07 17:38:01.936 LedWiz Nr. 01 finished and updater thread stopped. 2020.08.07 17:38:01.936 Debug: Output controllers finished 2020.08.07 17:38:01.936 Cabinet finished 2020.08.07 17:38:01.936 DirectOutput framework finished. 2020.08.07 17:38:01.936 Bye and thanks for using! 2020.08.07 17:38:01.952 Debug: Disposing LedWiz instance 01. HELP ME !!!!! | |
| | | bobox59
Messages : 7 Département : 59
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mer 12 Aoû 2020 - 13:49 | |
| - ebor a écrit:
- A ma connaissance, c'est le seul dof compatible wemos.
Tu as qq chose de parlant dans le log de vpx pour voir ce qui le fait planter ? Bonjour a tous, je dois approfondir mes tests pour trouver le souci que je rencontre, mais j'aime aussi comprendre. de souvenir, quand je met le dof modifié, ca ne change pas, mon ledstrip s'allume a la couleur de la table, puis plus rien ne bouge par la suite. si j'ai bien compris, votre excellent travail fait sur wemos permet d'utiliser un wemos en lieu et place d'un teensy, et si j'ai compris, vous avez repris l'ensemble des fonctions origine du teensy. j'aimerai savoir quel est la modification faite entre le DOF et le DOF Modifié proposé ? Merci. | |
| | | vnguyenquangdo
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mer 12 Aoû 2020 - 14:19 | |
| La modification du DOF c'est quelques lignes qui correspondent au protocole d'échange entre le PC et la Wemos/Teensy. Cela fait effectivement apparaitre la Wemos comme une Teensy. Par contre il faut aussi un code spécial pour la Wemos, c'est ce que vous flashez avec l'Arduino. [Vous devez être inscrit et connecté pour voir ce lien], pour le message d'erreur remonté ci dessus: 2020.08.07 17:38:01.906 EXCEPTION: TeensyStripController TeensyStripController updater thread could not connect to the controller. Thread will quit.Cela signifie que le DOF n'arrive pas à se connecter à ta Wemos. Plusieurs causes potentielles: - Le port (COM3 ou COM4 généralement) défini dans ton cabinet.xml ne correspond pas au port physique (que l'on peut trouver dans le gestionnaire de périphérique) - la vitesse du port est trop élevée - Une Wemos defectueuse (ca m'est arrivé, un batch de deux cartes toutes deux défectueuses) Donc vérifies en premier lieu le numéro de port | |
| | | bobox59
| Sujet: Re: [EN COURS] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO Mer 12 Aoû 2020 - 17:27 | |
| Merci pour l'info. perso je suis assez fan de programmation dont de l'arduino, est-ce qu'il y aurai plus d'infos sur la modif du DOF ? le but ideal serait de modifier le code du wemos pour qu'il soit 100% compatible teensy de facon native, sans devoir avoir un DOF patché Je suis pret a mettre les mains dans le cambouis et serait ravi de partager cela Je pense également pondre un soft sous windows et le partager, pour pouvoir tester nos petites wemos avec ce protocole, de facon simple a utiliser parceque la perso ca galere pour moi, il y a quand meme beaucoup d'étapes (cabinet.xml, config du dof, integration de telle ou telle table plus ou moins complete) et vraiment je n'ai pas encore compris de facon claire dans mon esprit comment le DOF et les différentes sorties du wemos fonctionnent bref j'avance lentement mais avec motivation | |
Sujets similaires | |
