| | [TUTO] Teensy controller | |
+53David 17 Billy54 fredo67500 xavuis shellxy Edo75 doraj90 naaco zedrummer paf_prod SAM mikevirgil baller38 jep70 mikuslegrand BonZ@i Gate dom69 snwfrd38 Aetios kakou Gabin1er fauck manples leevuth DjcydNico firebrand007 Arkan07 bip-bip-72 Tetzzuo francois95470 Antho.breizh antifake13 ikari MatthGyver ste1073 Flip69 peskopat jawah Shadow_SHD crucho TylerDurden67 marco.flip blaaster luckyaa29 tetrafred Davidlinch razorbaxx lololol cox grandDD arngrim gech 57 participants | |
xavuis Modérateur
Messages : 614 Département : 62
| Sujet: Re: [TUTO] Teensy controller Jeu 12 Déc 2019 - 20:34 | |
| je viens de prendre un fichier cabinet (celui de rertro jeu !) maintenant j ai une ligne blanche qui s allume au démarrage d une table voici le log: - Code:
--------------------------------------------------------------------------------- DirectOutput Version 3.1.6656.21457, built 2018.03.23 11:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | https://github.com/mjrgh/DirectOutput 2019.12.12 12:27:58.797 DirectOutput Logger initialized 2019.12.12 12:27:53.480 Pre-loading DLL Ciloci.Flee.dll from C:\DIRECTOUTPUT\Ciloci.Flee.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL Extensions.dll from C:\DIRECTOUTPUT\Extensions.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL FTD2XX32.dll from C:\DIRECTOUTPUT\FTD2XX32.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL Newtonsoft.Json.dll from C:\DIRECTOUTPUT\Newtonsoft.Json.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL PacDrive32.dll from C:\DIRECTOUTPUT\PacDrive32.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL Q42.HueApi.ColorConverters.dll from C:\DIRECTOUTPUT\Q42.HueApi.ColorConverters.dll : ok 2019.12.12 12:27:53.480 Pre-loading DLL Q42.HueApi.dll from C:\DIRECTOUTPUT\Q42.HueApi.dll : ok 2019.12.12 12:27:58.774 Global config filename is "C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml" 2019.12.12 12:27:58.797 Global config loaded from: C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml 2019.12.12 12:27:58.797 Loading Pinball parts 2019.12.12 12:27:58.797 Loading cabinet 2019.12.12 12:27:58.799 Will load cabinet config file: C:\DirectOutput\Config\Cabinet.xml 2019.12.12 12:27:58.942 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2019.12.12 12:27:58.942 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2019.12.12 12:27:58.942 Cabinet auto configuration started 2019.12.12 12:27:58.970 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2019.12.12 12:27:58.970 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 22 2019.12.12 12:27:58.976 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2019.12.12 12:27:58.986 Opening 32-bit LedWiz driver... 2019.12.12 12:27:58.987 Detected and added LedWiz Nr. 8 with name LedWiz 08 2019.12.12 12:27:58.987 Added LedwizEquivalent Nr. 8 with name LedWiz 08 Equivalent for Ledwiz Nr. 8 2019.12.12 12:27:58.991 Cabinet auto configuration finished 2019.12.12 12:27:58.991 Autoconfig complete. 2019.12.12 12:27:58.991 Cabinet config loaded successfully from C:\DirectOutput\Config\Cabinet.xml 2019.12.12 12:27:58.991 Cabinet loaded 2019.12.12 12:27:58.991 Loading table config 2019.12.12 12:27:58.993 Warning: No table config file found. Will try to load config from LedControl file(s). 2019.12.12 12:27:58.993 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName trn_174h 2019.12.12 12:27:58.997 Loading LedControl file C:\DIRECTOUTPUT\config\directoutputconfig30.ini 2019.12.12 12:27:59.005 Min DOF Version is 0.8 for file directoutputconfig30.ini 2019.12.12 12:27:59.317 Failed: YELLOW 2019.12.12 12:27:59.317 Warning: Cant parse the trigger part YELLOW of the ledcontrol table config setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1. 2019.12.12 12:27:59.318 EXCEPTION: Could not parse setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1 in column data Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1/W86 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L1/W63 Green AH100 AL20 AT0 AW14 SHPLetterM L1/W64 Green AH100 AL40 AT0 AW14 SHPLetterT L1/W65 Green AH100 AL60 AT0 AW14 SHPLetterL L1. 2019.12.12 12:27:59.318 EXCEPTION: Thread: 2019.12.12 12:27:59.318 EXCEPTION: Message: Exception --> Cant parse the part YELLOW of the ledcontrol table config setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1. 2019.12.12 12:27:59.320 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting.ParseSettingData(String SettingData) 2019.12.12 12:27:59.320 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting..ctor(String SettingData) 2019.12.12 12:27:59.320 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigColumn.ParseColumnData(String ColumnData, Boolean ThrowExceptions) 2019.12.12 12:27:59.320 EXCEPTION: Targetsite: Void ParseSettingData(System.String) 2019.12.12 12:27:59.320 Warning: Previous exceptions occured in the line dm,Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1/W86 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L1/W63 Green AH100 AL20 AT0 AW14 SHPLetterM L1/W64 Green AH100 AL40 AT0 AW14 SHPLetterT L1/W65 Green AH100 AL60 AT0 AW14 SHPLetterL L1 of the ledcontrol file 2019.12.12 12:27:59.466 Failed: FD800 2019.12.12 12:27:59.466 Warning: Cant parse the trigger part FD800 of the ledcontrol table config setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13. 2019.12.12 12:27:59.466 EXCEPTION: Could not parse setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13 in column data S18 Red AH100 AL0 AT0 AW19 SHPCircle3 L5/S27 White AH100 AL0 AT0 AW19 SHPCircle3 L6/S29 Red AH100 AL0 AT0 AW19 SHPCircle3 L7/S16 White AH100 AL0 AT0 AW19 SHPCircle3 L8/S30 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L9/S31 White AH100 AL20 AT0 AW19 SHPCircle3 L10/W17 White f200 AH100 AL20 AT0 AW19 SHPCircle3 L11/S1 Red AH100 AL40 AT0 AW19 SHPCircle3 L12/ fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13/S11 Red AH100 AL40 AT0 AW19 SHPCircle3 L14/S25 White AH100 AL40 AT0 AW19 SHPCircle3 L15/W18 Yellow f200 AH100 AL40 AT0 AW19 SHPCircle3 L16/S28 White AH100 AL60 AT0 AW19 SHPCircle3 L17/S30 Yellow AH100 AL60 AT0 AW19 SHPCircle3 L18/S32 White AH100 AL60 AT0 AW19 SHPCircle3 L19/W19 White f200 AH100 AL60 AT0 AW19 SHPCircle3 L20/S16 White AH100 AL80 AT0 AW19 SHPCircle3 L21/S20 Red AH100 AL80 AT0 AW19 SHPCircle3 L22/S26 Yellow AH100 AL80 AT0 AW19 SHPCircle3 L23. 2019.12.12 12:27:59.466 EXCEPTION: Thread: 2019.12.12 12:27:59.466 EXCEPTION: Message: Exception --> Cant parse the part FD800 of the ledcontrol table config setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13. 2019.12.12 12:27:59.466 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting.ParseSettingData(String SettingData) 2019.12.12 12:27:59.466 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting..ctor(String SettingData) 2019.12.12 12:27:59.466 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigColumn.ParseColumnData(String ColumnData, Boolean ThrowExceptions) 2019.12.12 12:27:59.466 EXCEPTION: Targetsite: Void ParseSettingData(System.String) 2019.12.12 12:27:59.467 Warning: Previous exceptions occured in the line gs,S18 Red AH100 AL0 AT0 AW19 SHPCircle3 L5/S27 White AH100 AL0 AT0 AW19 SHPCircle3 L6/S29 Red AH100 AL0 AT0 AW19 SHPCircle3 L7/S16 White AH100 AL0 AT0 AW19 SHPCircle3 L8/S30 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L9/S31 White AH100 AL20 AT0 AW19 SHPCircle3 L10/W17 White f200 AH100 AL20 AT0 AW19 SHPCircle3 L11/S1 Red AH100 AL40 AT0 AW19 SHPCircle3 L12/ fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13/S11 Red AH100 AL40 AT0 AW19 SHPCircle3 L14/S25 White AH100 AL40 AT0 AW19 SHPCircle3 L15/W18 Yellow f200 AH100 AL40 AT0 AW19 SHPCircle3 L16/S28 White AH100 AL60 AT0 AW19 SHPCircle3 L17/S30 Yellow AH100 AL60 AT0 AW19 SHPCircle3 L18/S32 White AH100 AL60 AT0 AW19 SHPCircle3 L19/W19 White f200 AH100 AL60 AT0 AW19 SHPCircle3 L20/S16 White AH100 AL80 AT0 AW19 SHPCircle3 L21/S20 Red AH100 AL80 AT0 AW19 SHPCircle3 L22/S26 Yellow AH100 AL80 AT0 AW19 SHPCircle3 L23 of the ledcontrol file 2019.12.12 12:27:59.952 Loading LedControl file C:\DIRECTOUTPUT\config\directoutputconfig8.ini 2019.12.12 12:27:59.955 Min DOF Version is 0.8 for file directoutputconfig8.ini 2019.12.12 12:28:00.443 2 directoutputconfig.ini or ledcontrol.ini files loaded. 2019.12.12 12:28:00.446 Config for RomName trn_174h exists in LedControl data. Updating cabinet and config. 2019.12.12 12:28:00.492 Table config loading finished: romname=trn_174h, tablename=Tron Legacy Le 2019.12.12 12:28:00.493 Pinball parts loaded 2019.12.12 12:28:00.494 Starting processes 2019.12.12 12:28:00.494 Initializing cabinet 2019.12.12 12:28:00.494 Debug: Initializing output controllers 2019.12.12 12:28:00.497 TeensyStripController LedStripController intialized and updater thread started. 2019.12.12 12:28:00.498 TeensyStripController LedStripController updater thread started. 2019.12.12 12:28:00.508 Pinscape Pinscape Controller 01 updater thread started. 2019.12.12 12:28:00.508 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2019.12.12 12:28:00.508 Pinscape Pinscape Controller 01 intialized and updater thread started. 2019.12.12 12:28:00.509 Debug: Initializing LedWiz Nr. 08 2019.12.12 12:28:00.511 LedWiz Nr. 08 initialized and updater thread initialized. 2019.12.12 12:28:00.511 Debug: Output controllers initialized 2019.12.12 12:28:00.511 Updater thread for LedWiz 08 started. 2019.12.12 12:28:00.517 Cabinet initialized 2019.12.12 12:28:00.521 Loading shape definition file: C:\DIRECTOUTPUT\config\DirectOutputShapes.xml 2019.12.12 12:28:00.577 Framework initialized. 2019.12.12 12:28:00.577 Have fun! 2019.12.12 12:28:00.629 TeensyStripController LedStripController updater thread has connected to TeensyStripController LedStripController. 2019.12.12 12:29:30.144 Finishing framework 2019.12.12 12:29:30.146 Finishing cabinet 2019.12.12 12:29:30.147 Debug: Finishing output controllers 2019.12.12 12:29:30.165 TeensyStripController LedStripController updater thread has disconnected from TeensyStripController LedStripController and will terminate. 2019.12.12 12:29:30.166 TeensyStripController LedStripController finished and updater thread stopped. 2019.12.12 12:29:30.167 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2019.12.12 12:29:30.168 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2019.12.12 12:29:30.168 Debug: Finishing LedWiz Nr. 08 2019.12.12 12:29:30.168 Updater thread for LedWiz 08 terminated. 2019.12.12 12:29:30.181 LedWiz Nr. 08 finished and updater thread stopped. 2019.12.12 12:29:30.181 Debug: Output controllers finished 2019.12.12 12:29:30.181 Cabinet finished 2019.12.12 12:29:30.181 DirectOutput framework finished. 2019.12.12 12:29:30.181 Bye and thanks for using!
bonsoir pincabiens, pincabienes toujours coincé, il y a du progrès: [Vous devez être inscrit et connecté pour voir cette image]voici mon fichier log et j essaye de me dépatouiller quelqu'un peut me dire ? a: 2019.12.12 20:17:12.240 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) a: 2019.12.12 20:17:12.257 Warning: No table config file found. Will try to load config from LedControl file(s). a: 2019.12.12 20:17:12.581 Failed: YELLOW a voir impossible d afficher du jaune ?, ensuite je comprends qu il est aussi impossible d affiche les cercles .... - Code:
--------------------------------------------------------------------------------- DirectOutput Version 3.1.6656.21457, built 2018.03.23 11:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | https://github.com/mjrgh/DirectOutput 2019.12.12 20:17:11.789 DirectOutput Logger initialized 2019.12.12 20:17:06.679 Pre-loading DLL Ciloci.Flee.dll from C:\DIRECTOUTPUT\Ciloci.Flee.dll : ok 2019.12.12 20:17:06.679 Pre-loading DLL Extensions.dll from C:\DIRECTOUTPUT\Extensions.dll : ok 2019.12.12 20:17:06.686 Pre-loading DLL FTD2XX32.dll from C:\DIRECTOUTPUT\FTD2XX32.dll : ok 2019.12.12 20:17:06.686 Pre-loading DLL Newtonsoft.Json.dll from C:\DIRECTOUTPUT\Newtonsoft.Json.dll : ok 2019.12.12 20:17:06.686 Pre-loading DLL PacDrive32.dll from C:\DIRECTOUTPUT\PacDrive32.dll : ok 2019.12.12 20:17:06.686 Pre-loading DLL Q42.HueApi.ColorConverters.dll from C:\DIRECTOUTPUT\Q42.HueApi.ColorConverters.dll : ok 2019.12.12 20:17:06.686 Pre-loading DLL Q42.HueApi.dll from C:\DIRECTOUTPUT\Q42.HueApi.dll : ok 2019.12.12 20:17:11.764 Global config filename is "C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml" 2019.12.12 20:17:11.789 Global config loaded from: C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml 2019.12.12 20:17:11.789 Loading Pinball parts 2019.12.12 20:17:11.789 Loading cabinet 2019.12.12 20:17:11.791 Will load cabinet config file: C:\DirectOutput\Config\Cabinet.xml 2019.12.12 20:17:12.207 1 output controller defnitions and 2 toy definitions loaded from cabinet config. 2019.12.12 20:17:12.207 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig. 2019.12.12 20:17:12.208 Cabinet auto configuration started 2019.12.12 20:17:12.234 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2019.12.12 20:17:12.234 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 22 2019.12.12 20:17:12.240 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2019.12.12 20:17:12.251 Opening 32-bit LedWiz driver... 2019.12.12 20:17:12.251 Detected and added LedWiz Nr. 8 with name LedWiz 08 2019.12.12 20:17:12.251 Added LedwizEquivalent Nr. 8 with name LedWiz 08 Equivalent for Ledwiz Nr. 8 2019.12.12 20:17:12.255 Cabinet auto configuration finished 2019.12.12 20:17:12.255 Autoconfig complete. 2019.12.12 20:17:12.255 Cabinet config loaded successfully from C:\DirectOutput\Config\Cabinet.xml 2019.12.12 20:17:12.255 Cabinet loaded 2019.12.12 20:17:12.255 Loading table config 2019.12.12 20:17:12.257 Warning: No table config file found. Will try to load config from LedControl file(s). 2019.12.12 20:17:12.257 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName trn_174h 2019.12.12 20:17:12.260 Loading LedControl file C:\DIRECTOUTPUT\config\directoutputconfig30.ini 2019.12.12 20:17:12.275 Min DOF Version is 0.8 for file directoutputconfig30.ini 2019.12.12 20:17:12.581 Failed: YELLOW 2019.12.12 20:17:12.581 Warning: Cant parse the trigger part YELLOW of the ledcontrol table config setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1. 2019.12.12 20:17:12.582 EXCEPTION: Could not parse setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1 in column data Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1/W86 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L1/W63 Green AH100 AL20 AT0 AW14 SHPLetterM L1/W64 Green AH100 AL40 AT0 AW14 SHPLetterT L1/W65 Green AH100 AL60 AT0 AW14 SHPLetterL L1. 2019.12.12 20:17:12.582 EXCEPTION: Thread: 2019.12.12 20:17:12.582 EXCEPTION: Message: Exception --> Cant parse the part YELLOW of the ledcontrol table config setting Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1. 2019.12.12 20:17:12.583 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting.ParseSettingData(String SettingData) 2019.12.12 20:17:12.583 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting..ctor(String SettingData) 2019.12.12 20:17:12.583 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigColumn.ParseColumnData(String ColumnData, Boolean ThrowExceptions) 2019.12.12 20:17:12.583 EXCEPTION: Targetsite: Void ParseSettingData(System.String) 2019.12.12 20:17:12.584 Warning: Previous exceptions occured in the line dm,Yellow AH100 AL0 AT0 AW19 SHPCircle3 L1/W86 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L1/W63 Green AH100 AL20 AT0 AW14 SHPLetterM L1/W64 Green AH100 AL40 AT0 AW14 SHPLetterT L1/W65 Green AH100 AL60 AT0 AW14 SHPLetterL L1 of the ledcontrol file 2019.12.12 20:17:12.716 Failed: FD800 2019.12.12 20:17:12.716 Warning: Cant parse the trigger part FD800 of the ledcontrol table config setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13. 2019.12.12 20:17:12.717 EXCEPTION: Could not parse setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13 in column data S18 Red AH100 AL0 AT0 AW19 SHPCircle3 L5/S27 White AH100 AL0 AT0 AW19 SHPCircle3 L6/S29 Red AH100 AL0 AT0 AW19 SHPCircle3 L7/S16 White AH100 AL0 AT0 AW19 SHPCircle3 L8/S30 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L9/S31 White AH100 AL20 AT0 AW19 SHPCircle3 L10/W17 White f200 AH100 AL20 AT0 AW19 SHPCircle3 L11/S1 Red AH100 AL40 AT0 AW19 SHPCircle3 L12/ fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13/S11 Red AH100 AL40 AT0 AW19 SHPCircle3 L14/S25 White AH100 AL40 AT0 AW19 SHPCircle3 L15/W18 Yellow f200 AH100 AL40 AT0 AW19 SHPCircle3 L16/S28 White AH100 AL60 AT0 AW19 SHPCircle3 L17/S30 Yellow AH100 AL60 AT0 AW19 SHPCircle3 L18/S32 White AH100 AL60 AT0 AW19 SHPCircle3 L19/W19 White f200 AH100 AL60 AT0 AW19 SHPCircle3 L20/S16 White AH100 AL80 AT0 AW19 SHPCircle3 L21/S20 Red AH100 AL80 AT0 AW19 SHPCircle3 L22/S26 Yellow AH100 AL80 AT0 AW19 SHPCircle3 L23. 2019.12.12 20:17:12.717 EXCEPTION: Thread: 2019.12.12 20:17:12.717 EXCEPTION: Message: Exception --> Cant parse the part FD800 of the ledcontrol table config setting fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13. 2019.12.12 20:17:12.717 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting.ParseSettingData(String SettingData) 2019.12.12 20:17:12.717 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigSetting..ctor(String SettingData) 2019.12.12 20:17:12.717 EXCEPTION: Stacktrace: à DirectOutput.LedControl.Loader.TableConfigColumn.ParseColumnData(String ColumnData, Boolean ThrowExceptions) 2019.12.12 20:17:12.717 EXCEPTION: Targetsite: Void ParseSettingData(System.String) 2019.12.12 20:17:12.717 Warning: Previous exceptions occured in the line gs,S18 Red AH100 AL0 AT0 AW19 SHPCircle3 L5/S27 White AH100 AL0 AT0 AW19 SHPCircle3 L6/S29 Red AH100 AL0 AT0 AW19 SHPCircle3 L7/S16 White AH100 AL0 AT0 AW19 SHPCircle3 L8/S30 Yellow AH100 AL20 AT0 AW19 SHPCircle3 L9/S31 White AH100 AL20 AT0 AW19 SHPCircle3 L10/W17 White f200 AH100 AL20 AT0 AW19 SHPCircle3 L11/S1 Red AH100 AL40 AT0 AW19 SHPCircle3 L12/ fd800 AH100 AL40 AT0 AW19 SHPCircle3 L13/S11 Red AH100 AL40 AT0 AW19 SHPCircle3 L14/S25 White AH100 AL40 AT0 AW19 SHPCircle3 L15/W18 Yellow f200 AH100 AL40 AT0 AW19 SHPCircle3 L16/S28 White AH100 AL60 AT0 AW19 SHPCircle3 L17/S30 Yellow AH100 AL60 AT0 AW19 SHPCircle3 L18/S32 White AH100 AL60 AT0 AW19 SHPCircle3 L19/W19 White f200 AH100 AL60 AT0 AW19 SHPCircle3 L20/S16 White AH100 AL80 AT0 AW19 SHPCircle3 L21/S20 Red AH100 AL80 AT0 AW19 SHPCircle3 L22/S26 Yellow AH100 AL80 AT0 AW19 SHPCircle3 L23 of the ledcontrol file 2019.12.12 20:17:13.181 Loading LedControl file C:\DIRECTOUTPUT\config\directoutputconfig8.ini 2019.12.12 20:17:13.190 Min DOF Version is 0.8 for file directoutputconfig8.ini 2019.12.12 20:17:13.639 2 directoutputconfig.ini or ledcontrol.ini files loaded. 2019.12.12 20:17:13.642 Config for RomName trn_174h exists in LedControl data. Updating cabinet and config. 2019.12.12 20:17:13.674 Table config loading finished: romname=trn_174h, tablename=Tron Legacy Le 2019.12.12 20:17:13.675 Pinball parts loaded 2019.12.12 20:17:13.676 Starting processes 2019.12.12 20:17:13.676 Initializing cabinet 2019.12.12 20:17:13.676 Debug: Initializing output controllers 2019.12.12 20:17:13.710 TeensyStripController LedStripController intialized and updater thread started. 2019.12.12 20:17:13.711 Pinscape Pinscape Controller 01 intialized and updater thread started. 2019.12.12 20:17:13.711 Debug: Initializing LedWiz Nr. 08 2019.12.12 20:17:13.712 TeensyStripController LedStripController updater thread started. 2019.12.12 20:17:13.712 Pinscape Pinscape Controller 01 updater thread started. 2019.12.12 20:17:13.712 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2019.12.12 20:17:13.714 LedWiz Nr. 08 initialized and updater thread initialized. 2019.12.12 20:17:13.714 Debug: Output controllers initialized 2019.12.12 20:17:13.715 Updater thread for LedWiz 08 started. 2019.12.12 20:17:13.724 Cabinet initialized 2019.12.12 20:17:13.728 Loading shape definition file: C:\DIRECTOUTPUT\config\DirectOutputShapes.xml 2019.12.12 20:17:13.782 Framework initialized. 2019.12.12 20:17:13.782 Have fun! 2019.12.12 20:17:13.850 TeensyStripController LedStripController updater thread has connected to TeensyStripController LedStripController. 2019.12.12 20:18:35.610 Finishing framework 2019.12.12 20:18:35.612 Finishing cabinet 2019.12.12 20:18:35.614 Debug: Finishing output controllers 2019.12.12 20:18:35.636 TeensyStripController LedStripController updater thread has disconnected from TeensyStripController LedStripController and will terminate. 2019.12.12 20:18:35.637 TeensyStripController LedStripController finished and updater thread stopped. 2019.12.12 20:18:35.638 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2019.12.12 20:18:35.639 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2019.12.12 20:18:35.639 Debug: Finishing LedWiz Nr. 08 2019.12.12 20:18:35.639 Updater thread for LedWiz 08 terminated. 2019.12.12 20:18:35.651 LedWiz Nr. 08 finished and updater thread stopped. 2019.12.12 20:18:35.651 Debug: Output controllers finished 2019.12.12 20:18:35.651 Cabinet finished 2019.12.12 20:18:35.651 DirectOutput framework finished. 2019.12.12 20:18:35.651 Bye and thanks for using!
le cabinet xml: - Code:
<?xml version="1.0"?> <Cabinet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Name>Pincab</Name> <OutputControllers>
<TeensyStripController> <Name>LedStripController</Name> <NumberOfLedsStrip1>576</NumberOfLedsStrip1> <NumberOfLedsStrip2>0</NumberOfLedsStrip2> <NumberOfLedsStrip3>0</NumberOfLedsStrip3> <NumberOfLedsStrip4>0</NumberOfLedsStrip4> <NumberOfLedsStrip5>0</NumberOfLedsStrip5> <NumberOfLedsStrip6>0</NumberOfLedsStrip6> <NumberOfLedsStrip7>0</NumberOfLedsStrip7> <NumberOfLedsStrip8>0</NumberOfLedsStrip8> <ComPortName>COM5</ComPortName> </TeensyStripController>
</OutputControllers>
<Toys>
<LedStrip> <Name>BackBoard</Name> <Width>72</Width> <Height>8</Height> <LedStripArrangement>RightLeftAlternateTopDown</LedStripArrangement> <ColorOrder>GRB</ColorOrder> <FirstLedNumber>1</FirstLedNumber> <FadingCurveName>Linear0To16</FadingCurveName> <OutputControllerName>LedStripController</OutputControllerName> </LedStrip> <LedWizEquivalent>
<Name>LedWizEquivalent 30</Name> <Outputs>
<LedWizEquivalentOutput> <OutputName>BackBoard</OutputName> <LedWizEquivalentOutputNumber>1</LedWizEquivalentOutputNumber> </LedWizEquivalentOutput>
</Outputs> <LedWizNumber>30</LedWizNumber> </LedWizEquivalent> </Toys>
</Cabinet>
Dernière édition par Shadow_SHD le Dim 5 Jan 2020 - 14:44, édité 1 fois (Raison : messages successifs fusionnés) | |
| | | xavuis Modérateur
| Sujet: Re: [TUTO] Teensy controller Dim 15 Déc 2019 - 12:34 | |
| un grand merci a sebinouse qui m'a donner la solution de toutes les leds blanche ou partiel au démarrage et sous une table : [Vous devez être inscrit et connecté pour voir ce lien]mon problème est résolu enfin | |
| | | fredo67500
Messages : 60 Département : 67
| Sujet: Re: [TUTO] Teensy controller Ven 27 Déc 2019 - 23:44 | |
| Salut à tous,
je viens vous demander un peu d'aide... J'essaye tant bien que mal d'installer et de configurer un Teensy + octo....
J'ai connecté dessus une bande de 30 LEDS qui restent définitivement allumée... en blanch/bleu
Le Teensy a été flashé et est reconnu sur le port COM4 (Périphérique Série USB), mais après le flash rien ne se passe au niveau des LEDS. Elles sont allumées fixes dès l'allumage du PC
Dans le DOF, rien ne se passe, les LED restent allumées fixes.
J'ai ponté le port 15 et 16 du Teensy mais toujours pareil.
Comment être sûr que la carte Teensy fonctionne bien, là elle n'a pas l'air... Je suis sus WIN10
D'avance merci ! | |
| | | xavuis Modérateur
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 12:05 | |
| En mode normal (sous vpx) la led de la teensy flash très rapidement | |
| | | fredo67500
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 12:18 | |
| Chez moi il ne se passe rien....
Les LEDS restent allumées, rien de plus, rien de moins. Elles sont allumées à partir du boot du PC
J'ai branché mon Teensy sur un autre PC, et là curieusement aucune LED ne s'allume. Par contre impossible de jouer le programme Blinker en mémoire par exemple. Il ne se passe rien
Je sèche | |
| | | xavuis Modérateur
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 12:35 | |
| | | fredo67500
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 12:58 | |
| OK mais là c'est le DOF qui fait le job. Moi je n'en suis même pas encore là. A priori mon Teensy n'est pas fonctionnel. Sous Win10, ton PC voit le Teensy comme un port COM de type Serial USB ou il le voit sous le nom "Teensy..." ? J'avance à pas de loup... J'ai réussi à programmer mon Teensy avec les code Blink Fast & Blink Slow et je vois la différence. Mon Teensy clignote rapidement ou lentement. Je vais retenter pour la nième fois le flash du ledstrip... Mon Teensy semble donc OK Wait & See J'ai reflashé mon Teensy via le loader avec le fichier "TeensyStripController.Beta.V1.02.1601021351.hex". Pas d'erreur, le Teensy reboot. Suite à cela je branche mon câble RJ45 au connecteur de droite du Teensy et là mes LED sont toutes allumées fixes Normal ?
Dernière édition par Shadow_SHD le Dim 5 Jan 2020 - 14:36, édité 1 fois (Raison : messages successifs fusionnés) | |
| | | Gate
Messages : 225 Département : Montréal (Québec, Canada)
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 14:36 | |
| Il faut regarder la led orange sur la teensy. Si elle clignote lentement elle est en attente d'instruction du pc donc tu a un DOF mal configuré. Si elle clignote vite c'est quelle envois bien le signale à tes led donc tu a une mauvaise connexion entre tes les et la teensy (ou tu as grillé le port de ta teensy) | |
| | | fredo67500
| Sujet: Re: [TUTO] Teensy controller Sam 28 Déc 2019 - 17:54 | |
| Alors voilà le statut. Au boot de mon PC, la LED orange du Teensy clignote de manière régulière. Une fois sur le bureau Windows idem. Par contre à présent quand PinballX se lance je vois la LED du Teensy s'affoler puis elle clignote double en séquence régulière. ça bouge.... Par contre comment griller la sortie ? j'ai vérifié 15 fois mon câblage avant de tout brancher, et le câblage est bon. Je viens de tester avec une nouvelle bande LED idem elles restent allumées fixes. Par contre que je branche sur le port RJ45 de droite ou de gauche mes LEDS sont allumées, normal ? Je viens de me rendre compte que mon câble est un Cat5, ça pourrait être la cause de mes problèmes ? P*tain blasé.... J'avais laissé mon problème de Teensy de côté et je m'étais attelé à ajouter 2 boutons Magna Save. Ordinateur éteint je câble tout propre, je branche mes câbles sur mon KL25Z, je reboot et ... rien... Mon PC ne démarre plus, je suis blasé. J'ai tout vérifié, et tout est OK, j'ai retiré le max de truc branché à la carte mère (USB, carte graphique Geforce, etc...) il démarre plus. Juste les ventilos qui tournent et basta... Je suis bla-sé... Pourtant j'ai encore fait quelques parties de AFM avant de l'éteindre proprement et d'attaquer mes boutons magna-save... Incompréhensible... EDIT : vieille technique d'informaticien, j'ai booté sans la RAM. J'ai remis la RAM, et là il a bossé, s'est arrêté après 5s et a redémarré normalement après 5s Depuis plus de problème? J'ai fait quelques arrêts/redémarrage et tout est ok J'ai vérifié la RAM, les 2x4 Go sont toujours là
Dernière édition par Shadow_SHD le Dim 5 Jan 2020 - 14:38, édité 1 fois (Raison : messages successifs fusionnés) | |
| | | baller38
Messages : 30 Département : Isère
| Sujet: Re: [TUTO] Teensy controller Sam 4 Jan 2020 - 21:56 | |
| c'est le shéma 3 qu'il faut suivre. je ne sais pas quel type d'alimentation tu as pris mais le mieux est de prendre les alimentations à découpage type Meanwell LRS ....en 5Vdc 70 A ou alors alim chinoise comme la S 350 S disponible sur banggood par exemple ou amazon. .. ça permet d'alimenter toutes les cartes de ton cab qui nécessite du 5v en plus des ledstrips. Le gnd ne sert à rien il ne faut pas relier le V- au gnd . Si tu as as plusieurs alim une bonne chose est de relier tous les V- de toutes les alims ensemble(en chaîne). en plus de cela pour les ledstrip ou les bandes RGB (par exemple BTF-LIGHTING WS2812B (en 8x8 ou en 8x32 arrangement en zig zag haut bas ) il faut tirer des câbles d'alimentation 5V (donc +V pour le +5V et V- pour le zero) sur les entrées d’alimentation présentes sur les faces arrière de ces panneaux rgb). Le programme basic test sert à vérifier la direction des ledstrip haut bas, bas haut, gauche droite, droite gauche etc... . Pour tester les leds il faut lancer basic test et bien renseigner le champs ou tu rentres le nombre de leds à tester .Vérifier /téléverser puis dans l'ordre brancher l'alimentation , controler entre V- et V+ que tu as bien +5V. éteindre l'alimentation. brancher les câbles d'alimentation un par un sur tes bandes RGB et connecter la liaison de com à la teensy. qui est elle alimenter par ton port usb, pas par ton alim 5V. puis brancher l'alim. pour enfin admirer le spectacle . une fois les tests concluant : débrancher l'alimentation et constater que toutes les leds s'éteignent correctement , débrancher la liaison de com de la teensy aux ledstrip. téléverser le programme teensycontroller (attention il y a deux versions et i faut parfois s'y prendre à plusieurs fois (téléverser) pour réussir à faire fonctionner correctement sa configuration.)
| | | fredo67500
| Sujet: Re: [TUTO] Teensy controller Dim 5 Jan 2020 - 13:28 | |
| Salut, merci d'avoir pris le temps de me répondre. J'ai testé mon ruban de LED avec un arduino et cette fois j'arrive à piloter mes LEDS correctement. J'arrive à allumer 60 LEDS sans problème juste avec le 5V de mon USB. Faut croire que mon Teensy est HS ?! Je vais encore tester avec un vrai câble RJ45 Cat6 (au lieu du Cat5) mais j'y crois pas trop. Je vous tiendrai informé
Dernière édition par Shadow_SHD le Dim 5 Jan 2020 - 14:35, édité 1 fois (Raison : merci de ne pas citer le dernier message pour répondre ;)) | |
| | | Shadow_SHD Admin
| Sujet: Re: [TUTO] Teensy controller Dim 5 Jan 2020 - 14:42 | |
| [Vous devez être inscrit et connecté pour voir ce lien] désolé je vais être désagréable quelques instants mais c'est pour le bien du forum - Merci de ne pas poster plusieurs messages d'affilée dans le même sujet, ça s'appelle du flood et c'est très mal perçu ; le bouton Éditer sert justement à modifier un message que l'on vient de poster afin d'y apporter des modifications ou mises à jour. - Merci de ne pas citer en intégralité le dernier message en date pour répondre, le bouton... RÉPONDRE présent un peu partout dans chaque page de chaque sujet sert justement à... répondre ++ | |
| | | xavuis Modérateur
| Sujet: Re: [TUTO] Teensy controller Dim 5 Jan 2020 - 21:22 | |
| bon tu en ais ou ? si tu a utilisé le programme arduino que je t ai fais c est normal que tu puisse te passer d alimentation car j ai mis presque aux mini les leds, pour info dans le programme il y a 0,0,5 RGB donc 0 pour R, 0 pour G et 5 pour B, la valeur et de 0 a 255 , 0 pour 0% et 255 pour 100% je te rassure j ai galere un max avec cette teensy diabolique, maintenant change de port teensy si tu as un doute et oublie pas de refaire ton cabinet.xml en conséquence. | |
| | | fredo67500
| Sujet: Re: [TUTO] Teensy controller Lun 6 Jan 2020 - 18:47 | |
| J'ai utilisé la librairie adafruit, pas la tienne désolé. J'arrive à faire allumer mes 60 1ère LED sans soucis, ça change de couleur, ça clignote etc.. c'est joli. Je n'ai pas avancé depuis par rapport à l'intégration dans mon Pincab, je vous tiendrai informé. [Vous devez être inscrit et connecté pour voir ce lien], bien reçu | |
| | | baller38
| Sujet: Re: [TUTO] Teensy controller Dim 19 Jan 2020 - 12:10 | |
| - doraj90 a écrit:
- Merci dom69.(mais je ne comprends pas ton schéma, je ne suis pas électronicien ou électro technicien et je ne vois pas du tout ce que je peux en faire.)
Personne à un schéma du branchement entre la "teensy" avec son "octows2811" et les ledstrips. Histoire de savoir comment et ou est branché le GND.
J'ai fais quatre schémas , y en a un t il de bon ?
Schéma 1 (la photo qu'on voie dans le tutos page 1) mais je ne pige le retour du GND [Vous devez être inscrit et connecté pour voir cette image]
Schéma 2 Si on relie le gnd aussi à l'alim 5 Volts , je comprends mieux le retour de la tension. Enfin dans ma logique et sur mes compétences de 1 sur une échelle de 10 en électricité. [Vous devez être inscrit et connecté pour voir cette image]
Schéma 3 Peut être qu'il faut relié le GND sur la teensy , un peu comme sur les schéma de la weemos ! [Vous devez être inscrit et connecté pour voir cette image]
Schéma 4 Le GND passe par la teensy , par les fils blanc des câbles RJ45 ... [Vous devez être inscrit et connecté pour voir cette image]
bonjour doraj90, pour répondre à ta question j'utile personnellement le shéma 3. J'y apporterai une modification: les ledstrips sont alimentés en V+(5V) V-(zéro si tu préfères, la reference que tu peux chaîner sur chaque alim à découpage sur les sortie V-) . le GND sert à être relié à toute partie métallique du flipper en contacts avec tes mains comme lockdown bar receiver ou les équerres de fixation des pieds de flipper . C'est le GND de la prise secteur 'Phase neutre et ground (la terre). our être alimenter, les toys, ont besoin que de ces tensions V+ V- issus des alimentation a découpage. Pour résumer, la teensy n'a pas besoin d'être alimenter en V+ et V- délivrer par l'alimentation à découpage , elle a juste besoin d'une liaison vers le pc par câble USB pour fonctionner. Sur plusieurs shéma électronique on voit des réferences GND sur les lignes mais le GND n'est pas forcément relié au V-. | |
| | | Billy54
Messages : 216 Département : 54
| Sujet: Re: [TUTO] Teensy controller Jeu 20 Fév 2020 - 18:49 | |
| bonsoir à tous je passe par ici car je rencontre un petit problème avec le teensy ou plutôt avec la configue DOF j'ai tous installer le matériel et bien configurer le DOF et tout fonctionne correctement pour information j utilise une matrice led toute faite de 8X32 donc 256 bits* et deux rubans de 78 leds de chaque coté du playfield voici donc mon petit problème dans le configtool du DOF , dans l'onglet Ledstripvariable ( la ou nous pouvons choisir dimensions , emplacement et forme des effets lumineux ) [Vous devez être inscrit et connecté pour voir cette image]si je laisse les paramètres par défaut et bien j ai des motifs qui ce chevauche ( 5 cercles ) si je modifie la dimension et bien les figures sont plus ou moi espacé mais avec un décalage d'une ligne et ne sont pas centré sur la matrice j'ai essayer moult réglages différents et rien n'y fait , il y a toujours un truc qui cloche je m'adresse donc aux personnes qui utilisent une matrice 8X32 [Vous devez être inscrit et connecté pour voir ce lien] peux tu me donner tes réglages STP bonne soirée à vous | |
| | | David 17
Messages : 19 Département : 17
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 11:43 | |
| Bonjour à tous, Je reviens vers vous car je sèche sur le sujet de ma Teensy, avant de connaitre ce forum j'ai regardé des vidéos sur YouTube et cela m'a donné l'envie de réaliser mon pincab (rêve d'enfant), pour le moment grace à vos nombreux conseils je profite bien de mon pincab, ça prend vie peu à peu avec les contacteurs et les strobes, donc pour être encore plus dans le réel je souhaite utiliser ma Teensy. J'ai suivi à la lettre cette vidéo https://www.youtube.com/watch?v=GYT0G_k8_kM , voici mon Cabinet.xml à savoir que c'est la même disposition que sur la vidéo 150 leds pour le BackBoard, et 72 Leds pour les Sideboard ne change que le dernier sens de disposition de celui de droite pour limiter les câbles, j'ai alimenté en 5V chaque éléments soit 150 + 52 + 52 - Code:
<?xml version="1.0"?> <Cabinet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Name>Pincab</Name> <OutputControllers> - Code:
<TeensyStripController> <Name>LedStripController</Name> <NumberOfLedsStrip1>150</NumberOfLedsStrip1> <NumberOfLedsStrip2>0</NumberOfLedsStrip2> <NumberOfLedsStrip3>0</NumberOfLedsStrip3> <NumberOfLedsStrip4>52</NumberOfLedsStrip4> <NumberOfLedsStrip5>0</NumberOfLedsStrip5> <NumberOfLedsStrip6>0</NumberOfLedsStrip6> <NumberOfLedsStrip7>52</NumberOfLedsStrip7> <NumberOfLedsStrip8>0</NumberOfLedsStrip8> <ComPortName>COM4</ComPortName> </TeensyStripController> - Code:
</OutputControllers> - Code:
<Toys> - Code:
<LedStrip> <Name>BackBoard</Name> <Width>30</Width> <Height>5</Height> <LedStripArrangement>RightLeftTopDown</LedStripArrangement> <ColorOrder>GRB</ColorOrder> <FirstLedNumber>1</FirstLedNumber> <FadingCurveName>Linear0to16</FadingCurveName> <OutputControllerName>LedStripController</OutputControllerName> </LedStrip> <LedStrip> <Name>Sideboard Left</Name> <Width>1</Width> <Height>52</Height> <LedStripArrangement>TopDownLeftRight</LedStripArrangement> <ColorOrder>GRB</ColorOrder> <FirstLedNumber>151</FirstLedNumber> <FadingCurveName>Linear0to16</FadingCurveName> <OutputControllerName>LedStripController</OutputControllerName> </LedStrip> <LedStrip> <Name>Sideboard Right</Name> <Width>1</Width> <Height>52</Height> <LedStripArrangement>TopDownLeftRight</LedStripArrangement> <ColorOrder>GRB</ColorOrder> <FirstLedNumber>203</FirstLedNumber> <FadingCurveName>SwissLizardsLedCurve</FadingCurveName> <OutputControllerName>LedStripController</OutputControllerName> </LedStrip> - Code:
<LedWizEquivalent> - Code:
<Name>LedWizEquivalent 30</Name> <Outputs> - Code:
<LedWizEquivalentOutput> <OutputName>BackBoard</OutputName> <LedWizEquivalentOutputNumber>1</LedWizEquivalentOutputNumber> </LedWizEquivalentOutput> - Code:
<LedWizEquivalentOutput> <OutputName>Sideboard Right</OutputName> <LedWizEquivalentOutputNumber>4</LedWizEquivalentOutputNumber> </LedWizEquivalentOutput> - Code:
<LedWizEquivalentOutput> <OutputName>Sideboard Left</OutputName> <LedWizEquivalentOutputNumber>7</LedWizEquivalentOutputNumber> </LedWizEquivalentOutput> - Code:
</Outputs> <LedWizNumber>30</LedWizNumber> </LedWizEquivalent> </Toys> - Code:
</Cabinet> Le GlobalConfig.xml - Code:
<?xml version="1.0" encoding="utf-8"?> <!--Global configuration for the DirectOutput framework.--> <!--Saved by DirectOutput Version 3.1.7011.27968: 2020-04-13 11-04-01--> <GlobalConfig> <LedWizDefaultMinCommandIntervalMs>10</LedWizDefaultMinCommandIntervalMs> <LedControlMinimumEffectDurationMs>60</LedControlMinimumEffectDurationMs> <LedControlMinimumRGBEffectDurationMs>120</LedControlMinimumRGBEffectDurationMs> <PacLedDefaultMinCommandIntervalMs>10</PacLedDefaultMinCommandIntervalMs> <IniFilesPath /> <CabinetConfigFilePattern>C:\DirectOutput\Config\Cabinet.xml</CabinetConfigFilePattern> <TableConfigFilePatterns /> <EnableLogging>true</EnableLogging> <ClearLogOnSessionStart>true</ClearLogOnSessionStart> <LogFilePattern>.\DirectOutput.log</LogFilePattern> </GlobalConfig> Je suis bien sur le port COM4, j'ai vérifié dans Arduino J'ai bien tout fait comme dans la vidéo, alors les symptômes - si je mets les fichiers GlobalConfig.xml et GlobalConfig_B2SServer.xml et que je lance une table et bien ma KL25Z ne fonctionne plus, si je les enlève tout est normal au niveau de la KL25Z - aucune Led ne s'allume, lorsque j'allume l'alimentation juste avant d'alumer le PC et aussi lorsque je téléverse avec Arduino j'ai 144 Leds qui s'allument ? J'ai bien vérifié mes soudures, mes câblages mais là je ne sais plus d'où vient le problème ??? j'ai vraiment besoin d'aide David EDIT : c'est bien 52 et non 72, désolé erreur de frappe
| | | ste1073
Messages : 225 Département : 51
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 13:42 | |
| Je n'ai pas regardé plus loin et ce n'est pas ça qui fait planter ta KL25Z, mais tu déclares avoir 150 leds pour ta backboard puis 72 pour chacune de tes sideboards et dans la 2ième partie de tes lignes de codes on voit que tu mets 150 leds pour ta backboard mais seulement 52 et 52 pour tes sideboards, ça ce n'est pas bon déjà. Dans ton fichier GlobalConfig.xml qui doit normalement s'appeler GlobalConfig_1.xml et GlobalConfig_B2SServer.xml au passage, il y a cette ligne qui n'est pas correctement renseigné : - Code:
<IniFilesPath /> Il faudrait qu'il y ai le chemin de ton répertoire Config comme cela, si le chemin est le même : - Code:
<IniFilesPath>C:\DirectOutput\Config</IniFilesPath> Et si c'est bien 72 leds que tu as sur tes 2 sideboards, il faut que tu modifies aussi ceci pour ta sideboard droite: - Code:
<FirstLedNumber>203</FirstLedNumber par : - Code:
<FirstLedNumber>223</FirstLedNumber> Tiens nous au courant. | |
| | | dom69
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 15:39 | |
| Salut Sans parler des leds, est-ce que ta teensy démarre ? | |
| | | David 17
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 15:58 | |
| Je suppose qu'elle fonctionne, comment pouvoir le prouver ? j'ai procédé comme sur le tuto par l'Arduino ……….
Au repos elle clignote lentement
| | | dom69
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 17:08 | |
| En temps normal elle clignote lentement, au lancement d’une table elle clignote rapidement | |
| | | Kaleo
Messages : 1 Département : innovation et développement
| Sujet: Re: [TUTO] Teensy controller Lun 13 Avr 2020 - 21:44 | |
| - mikuslegrand a écrit:
- Pour le DOF j'ai bien les meme paramètres. Pour les effets ça dépend des branchements. Donc on peut changer comme on veut.
Tu sais comment allumer la backboard pour tester les LED. Merci Bon j'ai testé ma backboard avec la table AFM et je me suis rendu compte que la première LED de la première bande ne fonctionné pas. Du coup je me suis commandé une nouvelle bande. Je vous dit des que c'est changé. Bonjour à tous, Ma config : SideBoard Right (de 1 à 50 led) + SideBoardLeft (de 51 à 100) en séries sur la sortie 1 BackBoard (29x6) sur la sortie 2 J'ai le même problème que mikuslegrand: la première LED de CHAQUE ligne du Teenstripcontroller refuse de s'allumer sous DOF. Elles sont fonctionnelles puisque le programme BasicTest directement envoyé sous arduino les contrôle sans problèmes. J'ai également un problème d'adressage: je devrais démarrer mes bandes en 1,51, et 101 mais pour éviter tout décalage, je dois mettre 0(ou1),50 et 100. Ce sont les mêmes symptômes que mikuslegrand (décalage et non illumination) et ma configuration semble la même. En dehors de ces 2 leds et du décalage d'adressage, tout fonctionne nickel. Une idée? EDIT:RESOLU!!! Après plusieurs heures de recherche... la version du Firmware! Certains liens mènent à la version 1.01 ou 1.02 de TeensyStripController, prenez soins de bien prendre la 1.03 ici: https://github.com/DirectOutput/TeensyStripController J'ai édité et non supprimé, ça peut servir! Bon courage à tous. Kaléo | |
| | | David 17
| Sujet: Re: [TUTO] Teensy controller Mar 14 Avr 2020 - 19:55 | |
| Bonjour à tous,
J'avance un peu, mes soudures sont bonnes, mes branchements aussi, lorsque dans Arduino je lance le test avec mes 254 leds tout fonctionne dans le sens que j'avais défini, de ce coté là génial !!!!!
Maintenant, Avant la programmation mes outputs de la KL25Z fonctionnent parfaitement et c'est un réel plaisir
- lorsque je produit le GlobalConfig_1.xml et le GlobalConfig_B2sserver.xml là tout va mal car la KL25Z ne travaille plus du tout Grrrrrrrrr !!!
J'ai alimenté les rubans led avec une autre alimentation que celle des toys et autres
Je pense que je ne suis pas très loin de la réussite mais si vous pouviez me donner un coup de pouce ce serait vraiment parfait
David
Lorsque je laisse uniquement le fichier GlobalConfig_1.xml la KL25Z fonctionne
| | | xavuis Modérateur
| Sujet: Re: [TUTO] Teensy controller Mar 14 Avr 2020 - 19:58 | |
| [Vous devez être inscrit et connecté pour voir ce lien] 17 tu utile un alimentions pour tes leds a tu fais une masse commune avec teensy ? | |
| | | khinyo
Messages : 237 Département : 69
| Sujet: Re: [TUTO] Teensy controller Mer 15 Avr 2020 - 16:53 | |
| Bonjour Pour ma teensy elle est branchée sur la même alim que les ledstrip via l octows2811 en prenant soin de bien couper le strap VIn sur la teensy sinon on rebalance du 5v sur l usb et je doute que le port usb ne le supporte. Pour la masse (ou GND ou encore V-) tout est relié ensemble. J utilise 3 ports sur la teensy car j ai mis des bandes led de 144led/m et le total des led dépassait ce que peux gérer un port de la teensy. J'ai repris le schema plus haut et je l'ai modifié pour mon installation. [Vous devez être inscrit et connecté pour voir cette image]Sur la photo suivante on peut voir le montage encore à l essai. [Vous devez être inscrit et connecté pour voir cette image]Les codes de couleurs sur mon cablage ne correspondent pas aux couleurs d'un cable rj45 ne pas en tenir compte. Des condensateurs ont été rajoutés sur l arrivée de l alim pour lisser un peu la tension. Des resistances de 220 Ohms sont insérées sur le fil de data, j avais vu quelque part qu'il fallait en mettre, de mon coté aucun changement avec ou sans. Pour tester le montage j ai utilisé un programme à insérer avec l arduino, ca allume toutes les leds ca permet de voir si le cablage est bon. Autre chose, afin de manipuler les fichiers xml, j utilise ce petit soft notepad++ en lien et place du notepad de windows. Il a le merite de mettre en evidence les valeurs que l'on peut changer. très pratique pour éviter les erreurs. [Vous devez être inscrit et connecté pour voir cette image] | |
Sujets similaires | |
