pour la video ou tu demandais comment c'est possible voilà l'explication in english in the text (ca necessite quand meme un gros bidouillage)
Maybe somewhat of a solution ... has anyone else tried this?
Below is a youtube link to a video of me playing Lights Camera Action using the Free Camera Mod. I've got 2 almost identical Dell monitors that support the same resolution (1280x1024). Same resolution in both monitors is key. I've got them both in portrait mode, and "stacked" vertically in the Windows Display Settings (not side by side) with the bottom monitor set as my primary display monitor.
I've got the Cabinet mode turned OFF (set to 0 in settings.ini) in the Free Camera Mod. Before launching the camera mod, I set the resolution in the SteamTPA configuration to 1024x2500 and I am running it in a Window (not full screen). When I run the Free Camera Mod and TPA opens, being that I have the monitors "stacked" vertically in Windows Display Settings, I simply stretch the window up into the upper monitor leaving just barely any room above and to the right of the window (this way it will not snap back into the primary display monitor). Then I adjust the camera so that the table is on bottom monitor and the backglass on top ... And wala ... I am able to run TPA using the working in-game back glass on my second monitor.
I chose Lights Camera Action for the vid because it is such an interactive backglass and really needs to be seen in action while playing this table
ocbbomb
Messages : 159 Département : 45
Sujet: Re: [TUTO] FreeCam Mod 26/4/2016, 17:53
ok c une prolongation de la resolution ok c moi sympa deja
ocbbomb
Sujet: Re: [TUTO] FreeCam Mod 26/4/2016, 18:09
khomodo a écrit:
ah oui ça le fait sur certains c'est pénible. Essaye avec celui d'attack from mars je n'avais pas trop de problème avec lui là. ET une fois positionné et augmenté comme tu le souhaites, clik droit sur le dmd, tu fais save state, ça te sauvegarde un fichier .dmd dans le repertoire dmd de pinballarcade avec les valeurs sauvegardées. Ensuite tu peux copier le fichier et le renommer avec le nom des autres tables ça évite d'avoir à te retaper tout pour chaque table.
ok ca marche sur afm mais y a pas moyen en 768x1360 dommage car en fhd mon ecran a pas une image terrible bon je sais pas si c modifiable dans les cams merci en tout cas pour la taille c ok mon probleme now et la resolution merci
ocbbomb
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 09:11
freecammod me demande 1.49.9 de pinball arcade je n'est fais aucune mise a jour.....?
khomodo
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 11:16
si ton pincab est connecté au net , le mod a du se mettre a jour en auto et peut etre qu une version 49.9 de pinball arcade est sortie ?
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 12:44
C'est ca.
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 13:36
Salut, j'ai le même soucis que toi et rien ne se met à jour pour moi, PA est passé en version 1.49.9 alors que FreeCam Mod est toujours en version 1.49.8. J'ai envoyé un mail pour demander si la version sera mise à jour prochainement car pour le moment impossible de l'utiliser. Et c'est vraiment embêtant rrrrrhh et franchement impossible de revenir à la version précédente. Je crois que nous allons devoir attendre........... [Vous devez être inscrit et connecté pour voir cette image][Vous devez être inscrit et connecté pour voir cette image]
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 13:45
Il n' y a pas de solution autre, moi je veux juste déporter mon backglass avec son DMD sur mon deuxième écran rien d'autre Je n'utilise même pas PinballX plus pour le moment.
khomodo
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 13:49
Freecammod est compatible 1.49.9 maintenant enfin c'est ce qui est marqué sur pinballarcadefans
oui version 49.9 pinballa arcade sortie
Version 1.49.9 (4/25/16) - Fixed Season 5 when trying to purchase some tables (was showing season 1) - Fixed crash in EM El Dorado - Fixed crash in Fireball - Fixed/Improved flippers on the following tables: Black Knight, Goin Nuts, Gorgar, Medieval Madness, No Good Gofers, Space Shuttle, Tee'd Off
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 13:55
À la fin du setting.. supprimer le numero de version. Cela force la mise à jour.
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 14:43
super il c'est mit à jour par compte je vois pas comment isoler sur mon 2me écran ?? Il doit manquer un truc je peux juste modifier avec les touches F1 F2... J'ai rien d'autre??
ocbbomb
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 16:28
quelqu'un peu m'envoyer le freecam mod pour la 1.49.8 de pa svp
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 17:14
Bon j'ai encore besoin d'un petit coup de main, j'ai réussi à mettre la version à jour, merci Gech. J'ai suivi le tuto et dans le réglage PBAConfig, il dise de mettre en 1080 et 2200, quand je fais cela et que je sauve, j'ai 1080 pour les 2? Je précise que j'ai étendu mon affichage au cas ou. Quand je lance FreeCamMod, j'ai une fenêtre qui s'ouvre. Les images sont ci dessous:
Ben ca marche. Publie ton setting je te dirait si c'est bon.
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 20:38
lol oui ça marche je voudrais avoir le backglass avec le DMD sur mon 2eme écran et je n'y arrive pas ...
Mon settings merci
Settings]
; Auto launch the game when the mod starts. LaunchGame=1
; Path to the game executable. GamePath=D:\Nouveau dossier\SteamApps\common\PinballArcade\PBAlaunch.bat
; Overlay is hidden when the game starts. StartHidden=1
; Opacity of the overlay (0 -> 1.0 / 0.1 range). Opacity=1.0
; Enable/disable the mod. FreeCameraMode=1
; Auto hide the ingame HUD when you click START button. AutoHideHUD=0
; The cam values are applied to the sliders when you click START button, otherwise sliders value are applied to the cam. AutoCamToSliders=1
; Check if a *.cam file exists for the current table and automatically loads it. AutoLoadCamFile=1
; Enable/disable Hotkeys. HotKeys=0
; The key (constant) defined in the game to manually hide the ingame HUD (default key: H) ; Keyboard scan code constants list: [Vous devez être inscrit et connecté pour voir ce lien] ; Take the hex value in the table (0x48) and convert it to an integer (72); HideHUDKey=72
; Backglass monitor number (as displayed in Windows/Nvidia/Ati display settings). BGMonitor=2
; Game window stretching value (to the second monitor) in pixels. WindowStretch=293
[DMD]
; ### DMD Settings (position is ignored when a table specific DMD file exists) ###
; DMD monitor number (as displayed in Windows/Nvidia/Ati display settings). DMDMonitor=3
; DMD Default X Position. DMDXPos=0
; DMD Default Y Position. DMDYPos=0
; DMD always on top of all windows. DMDTopMost=1
; DMD position is locked by default. DMDLockedPos=0
; DMD size is locked by default. DMDLockedSize=0
; ############################# HOTKEYS NOTE ############################### ; # For a complete list of usable keys, please visit: [Vous devez être inscrit et connecté pour voir ce lien] # ; # NumLock key should be ON to use NumPad keys. # ; # 'PageUp' key is also known as 'Prior' for backwards compatibility. # ; # 'PageDown' key is also known as 'Next' for backwards compatibility. # ; ##########################################################################
par compte je n'arrive plus à faire de screnn avec STEAM en appuyant sur F12, ça viens du Mode??
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 20:41
Comme sur la video ci-dessous
Sujet: Re: [TUTO] FreeCam Mod 27/4/2016, 21:18
Dmd monitor sur 2. Tu as bien les pack de camera et les backglass dans les dossier respectif??
Sujet: Re: [TUTO] FreeCam Mod 28/4/2016, 12:41
Je mettrais sur deux et oui j'ai bien les fichiers dans les dossiers respectif sauf DMD, il me manque peut être les derniers si vous avez plan pour les trouver je prends, j'ai suivi le tuto du mieux que j'ai pus. Pour le moment, je peux juste changer de plan en appuyant sur F1 jusqu'à F5 je crois et rien d'autre. Je n'ai pas le petit tableau qui s'affiche où on peut tout modifier, angle, perspective... ??
Sujet: Re: [TUTO] FreeCam Mod 28/4/2016, 12:58
Passe start hidden sur 0
Sujet: Re: [TUTO] FreeCam Mod 28/4/2016, 19:11
C'est ok gech, maintenant regarde comment je mets le Backglass sur mon ecran 2 ??
