| [TUTO] DOFlinx | |
+73rburel flanders moustic57 zack06007 nicofab18 flajolbass BABAS60 daniel6984 Benoit33 M4dd4M leguluc Moussounet Dantes917 Kada MAXxXAM Mick_03 GéraldB xavuis superdimi tiburtz vnguyenquangdo DamsBALL barto107 mikuslegrand mcdmofr Edo75 Gate Sebcemoi mameinabox ozywan coincoin80 xphilou29 tetrafred Chang-mick redmask1974 zedrummer gaetan92 glx sebinouse shynisaou dazer18 captflame2121 JEJE38 doraj90 stephane26101977 crapulax dom69 manples CAPTAINCAV davsouto Allan47 Stef26 arngrim xav71 raph1974 TheHighFlying Nnanard8 ste1073 Aetios kakou sebx Citron68 loftman44 khomodo PHILI50 grozby88 Davidlinch vulbas kwak ced Shadow_SHD peskopat razorbaxx 77 participants |
Davidlinch
Messages : 137 Département : 57
| Sujet: Re: [TUTO] DOFlinx Jeu 12 Jan 2017 - 21:15 | |
| [Vous devez être inscrit et connecté pour voir ce lien]Tu as essayé d'activer le debug pour savoir ce qu'il se passe (c'est assez explicite): - Debug:
12-janv.-17 21:11:55.924 - DOF Linx for Pinball Emulators - DOFLinx by DDH69 12-janv.-17 21:11:55.925 - Starting up - version 4.21 12-janv.-17 21:11:55.937 - 2 LEDWiz device(s) found 12-janv.-17 21:11:55.937 - DOFLinx device: 1 Initializing as LEDWiz #1 with ID=0 12-janv.-17 21:11:55.940 - DOFLinx device:1 LEDWiz setup with 32 outputs 12-janv.-17 21:11:55.940 - DOFLinx device: 2 Initializing as LEDWiz #8 with ID=1 12-janv.-17 21:11:55.941 - DOFLinx device:2 LEDWiz setup with 32 outputs 12-janv.-17 21:11:55.941 - 0 FTDI (Sainsmart) device(s) found 12-janv.-17 21:11:55.941 - DOFLinx device: 3 Initialising as PacLed64 #1 12-janv.-17 21:11:55.971 - DOFLinx device:3 PacLed64 setup with 64 outputs 12-janv.-17 21:11:55.971 - DOFLinx device: 4 Initialising as PacLed64 #2 12-janv.-17 21:11:55.971 - DOFLinx device:4 PacLed64 setup with 64 outputs 12-janv.-17 21:11:55.972 - Reading DOFLinx.INI startup config file details 12-janv.-17 21:11:55.978 - Reading DOF config file 12-janv.-17 21:11:55.984 - GAME_COLOUR item #2 is an invalid colour called ' Lime_Green' 12-janv.-17 21:11:55.985 - GAME_COLOUR item #3 is an invalid colour called ' Golden_Rod' 12-janv.-17 21:11:56.990 - Found valid process name of 'Future Pinball' 12-janv.-17 21:11:56.990 - Setting Future Pinball process ID 12-janv.-17 21:11:58.991 - Activated by process name : 'Future Pinball' 12-janv.-17 21:11:58.991 - Game name = '' 12-janv.-17 21:11:58.992 - Named process detected and startup commenced 12-janv.-17 21:11:58.993 - Process has administration rights 12-janv.-17 21:11:58.993 - 64 bit OS detected 12-janv.-17 21:11:59.001 - FP full name=D:\Emulators\Future Pinball\Future Pinball.exe Size=27446784 bytes, Dated 29/03/2013 18:18:24 12-janv.-17 21:11:59.003 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:02.001 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:04.000 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:06.001 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:08.002 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:10.000 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:12.002 - Starting scan of FP process for DOFLinx code 12-janv.-17 21:12:13.312 - FP table running DOFLInx code found and link established 12-janv.-17 21:12:13.313 - Using full colour palette 12-janv.-17 21:12:13.313 - Removing flasher from RGB list, device=1 port=23 12-janv.-17 21:12:13.314 - Removing flasher from RGB list, device=1 port=17 12-janv.-17 21:12:13.314 - Removing flasher from RGB list, device=1 port=20 12-janv.-17 21:12:13.314 - Removing flasher from RGB list, device=1 port=29 12-janv.-17 21:12:13.314 - Removing flasher from RGB list, device=1 port=26 12-janv.-17 21:12:17.820 - Link is turning off device #1 12-janv.-17 21:12:17.820 - Link is turning off device #2 12-janv.-17 21:12:18.784 - Link is turning on device #21 for 500 milliseconds 12-janv.-17 21:12:18.785 - Link is turning off device #22 12-janv.-17 21:12:18.904 - Link is turning on device #21 for 500 milliseconds 12-janv.-17 21:12:18.924 - Link is turning off device #22 12-janv.-17 21:12:19.411 - Link is turning off device #21 12-janv.-17 21:12:26.413 - Link is turning on device #7 for 50 milliseconds 12-janv.-17 21:12:26.468 - Link is turning off device #7 12-janv.-17 21:12:28.077 - Link is turning on device #2 for 10000 milliseconds 12-janv.-17 21:12:28.209 - Link is turning off device #2 12-janv.-17 21:12:28.394 - Link is turning on device #1 for 10000 milliseconds 12-janv.-17 21:12:28.577 - Link is turning off device #1 12-janv.-17 21:12:30.395 - Link is turning on device #4 for 50 milliseconds 12-janv.-17 21:12:30.395 - Link is turning on device #7 for 50 milliseconds 12-janv.-17 21:12:30.451 - Link is turning off device #4 12-janv.-17 21:12:30.452 - Link is turning off device #7 12-janv.-17 21:12:32.428 - Link is turning on device #2 for 50 milliseconds 12-janv.-17 21:12:32.489 - Link is turning off device #2 12-janv.-17 21:12:34.251 - Link is turning on device #21 for 500 milliseconds 12-janv.-17 21:12:34.364 - Link is turning off device #1
Messages : 1639 Département : 88
| Sujet: Re: [TUTO] DOFlinx Jeu 12 Jan 2017 - 23:41 | |
| Pour Razorbaxx et kwak : Mon info d'hier était fausse ... en fait, il faut renseigner uniquement le port rouge de l'éclairage undercab RGB à cet endroit là et rien d'autre (je n'en ai pas d'ailleurs !!!) en fait cela ne concerne pas du tout la lightbar !! Désolé pour l'erreur ...mais je suis comme vous ... je tâtonne et là, çà ne marche plus (pas même les solenoids flipper !!!) grrr EDIT 1 : Je viens de poster sur VPforums sur le forum dédié DOFlinx pour avancer ... je vous tiens au jus ! Mais apparemment, d'après ce que j'ai cru comprendre, le DOFlinx ne gère pas la prise en charge complète de nos toys pour les versions NON STEAM ! ... et après 2 jours de tests divers et variés, je commence à le croire !!! EDIT 2 : la configuration des toys pour PinballFX2 se passe au niveau de la section Future Pinball dans le DOFlinx.INI : 3 Setup Pinball FX2 3.1 Do nothing else (the LINK_xx) parameters in the Future Pinball section will take care of things), it is all setup! exemple de configuration : FP_ATTEMPT_LINK=1 LINK_LF=117,50,10000 LINK_RF=125,50,10000 LINK_LS=118,50,500 LINK_RS=126,50,500 LINK_ML=127,50,500 LINK_MC=128,50,500 LINK_MR=129,50,500 LINK_BL=130,50,500 LINK_BC=131,50,500 LINK_BR=132,50,500 LINK_SH=115,1000,5000 LINK_GR=116,750,10000 LINK_KN=124,120,500 LINK_SR=217,ON,0 LINK_BK=218,ON,0 LINK_FLOL=201 LINK_FLIL=204 LINK_FLCN=207 LINK_FLIR=210 LINK_FLOR=213 LINK_ST=102 LINK_EB=101 LINK_CN=106 LINK_EX=104 Les codes suivants peuvent être employés pour personnaliser son installation ! The devices that make up the XX in the LINK_XX above are; LF = Left flipper RF = Right flipper LS = Left slingshot RS= Right slingshot ML = Mid field left solenoid MC = Mid field centre solenoid MR = Mid field right solenoid BL = Back left solenoid BC = Back centre solenoid BR = Back right solenoid SH = Shaker motor GR = Gear motor KN = Knocker FN = Fan FLOL = Flasher outer left FLIL = Flasher Inner Left FLCN = Flasher Centre FLOR = Flasher Outer Right FLIR = Flasher Inner Right SR = Strobe BK = Beacon ST = Start button EB = Extra Ball button EX = Exit button CN = Coin button LB = Launch Ball button FR = Fire Button [Vous devez être inscrit et connecté pour voir ce lien] : c'est lci-dessous que tu dois renseigner tes paramètres de light bar ! LINK_FLOL=201 LINK_FLIL=204 LINK_FLCN=207 LINK_FLIR=210 LINK_FLOR=213 | |
razorbaxx Ancien du staff
| Sujet: Re: [TUTO] DOFlinx Ven 13 Jan 2017 - 18:24 | |
| ok grozby je modifie donc a nouveau le tuto c'est con si on peux pas avoir les autres contacteur sur pbfx2 sans une version steam officiel en tout cas c est pas ça qui va me faire acheter le jeu je le ferais seulement si zen pinball fait un effort pour integrer une vrai solution de compatibilité pour les toys et non un simple bidouillage [Vous devez être inscrit et connecté pour voir ce lien] tu est sur pour les rgb undercab car moi je pensais que ça se passait sur une autres ligne ( voir tuto ) du coup je suis un peu perdu mais chez moi j ai mis la valeur undercab au 2 endroit | |
| Sujet: Re: [TUTO] DOFlinx Ven 13 Jan 2017 - 23:54 | |
| Salut [Vous devez être inscrit et connecté pour voir ce lien]Oui, je suis sûr pour les RGB undercab ! # The button(s) to turn on when DOFLinx starts, ie the exit button LED BUTTONS_ON=102 104 ( ici il y a certainement quelques chose a faire mais je n'ai pas compris ??? ) Alors pour çà ... je pense avoir compris : en fait cette ligne permet d'allumer en fixe les boutons du cab si tu les as câblé sur la ledwiz bien sûr ... par exemple, chez moi, j'ai mis : BUTTONS_ON=101 102 103 104 Et donc quand je lance une table pinballFX2, bahhh çà allume les boutons CREDIT/START/EXIT/ et LAUNCH BALL Pour les lignes en dessous ... je suis comme toi, ... pas encore tout compris mais çà vient !!! lol [Vous devez être inscrit et connecté pour voir ce lien] :à priori, le DOFlinx fonctionne aussi avec une carte KL25 ... pourquoi çà ne marcherait pas pour toi ?
Dernière édition par peskopat le Sam 14 Jan 2017 - 21:28, édité 2 fois (Raison : Mise en forme , syntaxe , couleur etc ...) | |
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 0:16 | |
kwak
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 1:07 | |
| Je trouve pas les lignes faut les rajouté a la main ? | |
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 1:50 | |
kwak
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 2:04 | |
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 6:48 | |
| - razorbaxx a écrit:
- quel lignes kwak ???
je viens de tomber la dessus pour les versions non steam de pbfx2 mais j ai rien compris pourquoi j'ai dormis pendant les cours d anglais
[Vous devez être inscrit et connecté pour voir ce lien] J'ai bien sûr suivi l'intégralité de ce post ... mais rien à faire çà ne fonctionne pas chez moi pour l'instant ! je continue à creuser et je vous tiens au courant Je pense que cela concerne les versions standalone non steam de FX2 (comme par exemple la version de microsoft) ... si çà t'interresse, je peux te traduire la page [Vous devez être inscrit et connecté pour voir ce lien] : oui, il faut les rajouter à la main Voici la traduction intégrale made by grozby !!! :A côté de ma configuration de bureau PC normale avec FX2 Steam et connexion Internet, j'ai une configuration autonome pour mon pincab. Je suppose qu'il y a des gens qui ont comme moi une configuration pincab hors ligne sans un client Steam ni connexion Internet et qui gèrent une version non-Steam FX2 via PinballX. Cette configuration crée des défis quand il s'agit de la prise en charge FX2 DOFLinx complète. Je voulais partager ma configuration non-Steam qui fournit tous les effets DOFlinx pour FX2. C'est un peu délicat et exige de la patience et de la précision pour faire fonctionner les choses. Il y a essentiellement trois étapes principales: - s'assurer de l'utilisation des noms de table identiques entre FX2, DOFLinx et PinballX - Configuration DOFLinx - Configuration de PinballX J'ai inclus des captures d'écran et des fichiers de configuration pour supporter tout le processus de configuration. J'espère que çà aidera à comprendre comment j'ai configuré l'ensemble. Notez que j'ai renommé le fichier DOFlinx.ini en DOFlinx.txt sinon, je n'aurait pas pu télécharger le fichier (les fichiers .ini ne sont pas autorisés pour le téléchargement sur le forum). 1°) Différents noms de tables:L'une des différences est que la version non Steam que je lance a des noms de tables différents de ceux de la version Steam habituelle sur mon bureau. Pour le rendre compatible, j'ai dû renommer les fichiers FX2 fournis avec la dernière version de DOFLinx (4.21) pour faire correspondre les noms de tables à partir de la version non-Steam de FX2. J'ai inclus une capture d'écran du répertoire FX2 et le répertoire DOFLinx avec les noms alignés. Cela garantit que DOFLinx est capable de charger le fichier de configuration de table FX2 correct pour lire les différents effets prévus. Les mêmes noms de table sont également requis dans le fichier XML de base de données FX2 que PinballX utilise pour démarrer FX2 avec la bonne table. 2°) Configuration de DOFLinx:DOFLinx est configuré dans le mode «fire and forget». S'il vous plaît se référer au guide DOFLinx fourni avec le logiciel DOFLinx pour configurer ceci.C'est la meilleure façon à mon avis de configurer DOFLinx.Il ne se réveille que lorsqu'un processus FX2 est détecté et se met en veille lorsque le processus FX2 est terminé.Comme je lance FX2 via PinballX, j'ai eu besoin de rajouter du temps entre le moment ou DOFLinx identifie le processus FX2 et la sélection de la table réelle dans FX2.Cela se fait via le paramètre PROCESS_TO_ACTIVE_TIME (voir fichier DOFlinx.ini inclus en pièce jointe). Pour moi tout fonctionne en mettant 10000 millisecondes comme paramètre (soit 10 secondes).La vitesse avec laquelle une table est sélectionnée et chargée influence le temps d'attente requis.Il se pourrait que vous ayez besoin de jouer un peu avec ce paramètre pour trouver la bonne valeur pour votre configuration. J'utilise l'utilitaire DOFLinxmsg pour analyser le nom de table vers DOFLinx. Cela se fait via la configuration de PinballX. 3°) Configuration PinballX:Dans PinballX j'appelle l'utilitaire Nukelauncher pour démarrer FX2 et pour sélectionner la bonne table. C'est un utilitaire très agréable qui fonctionne très bien. Pour télécharger et installer les instructions s'il vous plaît visitez [Vous devez être inscrit et connecté pour voir ce lien] Reportez-vous à la capture d'écran de la configuration de PinballX. Le paramètre TABLEFILE est dérivé du fichier XML de base de données PinballX FX2, j'ai également inclus ce fichier XML dans le message.
NDLT : cet utilitaire n'est plus nécessaire car FX2 gère maintenant le lancement directLe DOFLinxmsg utilise également le paramètre TABLEFILE pour communiquer avec DOFLinx qui s'exécute en arrière-plan pour charger le fichier FX2 correspondant. Ceci est configuré dans la partie 'Launch Before' dans la configuration de PinballFX2 dans PinballX. (NDLT : voir capture d'écan configuration de pinballX fournie sur le site d'origine)4°) Dépannage:Avant de commencer, assurez-vous que votre configuration de PinballX avec Nukelauncher fonctionne comme prévu et que FX2 démarre via PinballX avec la table sélectionnée correctement. Lorsque vous essayez de faire fonctionner tout çà, assurez-vous d'activer le paramètre DEBUG = 1 dans votre configuration DOFLinx. Cela aide à voir si la communication s'établit bien entre DOFLIinx, le DOFLinxmsg et FX2 et de visualiser si quelque chose ne va pas comme prévu. 5°)Conclusion:Il semble qu'il y ait beaucoup de choses à digérer et qu'il faille un certain effort ... et c'est le cas. (NDLT : tu m'étonnes !!!) Mais ça vaut le coup! FX2 avec retour de force complet est génial et j'espère que ce tuto sera utile pour certains d'entre vous. Voili voilà les amis ... c'est quand même plus clair qu'avec les traductions internet non ??? Bon WE à tous ... j'y retourne à ce P... de DOFlinx !!!
Dernière édition par peskopat le Sam 14 Jan 2017 - 21:24, édité 1 fois (Raison : Message multiples fusionnés) | |
| Sujet: Re: [TUTO] DOFlinx Sam 14 Jan 2017 - 10:25 | |
| Salut et merci pour votre patience pour ma part tout pareil seulement mes 5 flashers et les deux flips qui fonctionnent......c'est deja pas mal mais c'est une version Skid... | |
| Sujet: Re: [TUTO] DOFlinx Dim 15 Jan 2017 - 18:42 | |
| Bon bahhh désolé les gars mais je viens de recevoir une fin de non recevoir de la part du développeur DDH69 sur le post de VPforum parce que j'utilise une version skid... Bref ... fin de l'aventure du full force feedback pour moi !!! dommage çà avait l'air sympa et relançait l'intérêt de PinballFX2 ... mais bon je ne me vois pas racheter toutes les tables juste pour le plaisir d'entendre clac clac !!! Allez ouste, on passe à autre chose ... ... comme continuer à intégrer les nouvelles tables VPX dans pinballX ... et y jouer tiens !!! | |
| Sujet: Re: [TUTO] DOFlinx Dim 15 Jan 2017 - 20:26 | |
| Ok Grosby au moins c'est clair et je comprends mieux maintenant. | |
khomodo
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 19:08 | |
| Bonjour, J"ai rallumé mon pincab après un long moment d'inactivité. Du coup je parcours les forums et je tombe sur le DOFlinx Jouer aux quelques tables future pinball que j'aime bien (celles de rom surtout) avec les toys. Génial Donc je lis le tuto, je bidouille un peu et ca fonctionne sur les tables future pinball (moddées evidemment) Bon par contre comme j'aime bien pinballfx2 mais sans les toys ça me laissait froid, j'essaye de faire marche le bouzin et là c'est l'echec total.. Déjà le truc que je ne pige pas c'est que dans le pdf de la doc, pour la configuration pinballx il demande de mettre un exe en prelaunch de pinballfx2 qui se trouverait dans le repertoire du DOF (c:\directouput) , DOFF2.exe... mais je le trouve nulle part cette exe ni dans le DOF R3, ni dans le DOFlinx dernière version... Quelqu'un sait il ou on peut le récupérer ce fameux exe ??? Merci !! Ps: oui je sais que ce n'est pas censé marcher avec une KL25 mais je veux essayer quand même ^^ avec une image c'est plus parlant [Vous devez être inscrit et connecté pour voir cette image]Edit: je viens de trouver , c'était l'ancien nom du doflinx.exe, je retourne a mes tests ^^ | |
khomodo
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 21:45 | |
| pour future pinball ça marche nickel par contre pour pbfx2 pour l'instant j'ai que tchi... pourtant dans le log, il recupère bien mon fichier de config fx2 avec le bon nom de table, mais apres pas de vie du dof.. même pas une loupiote et rien dans le log , pas de message d'erreur... | |
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 21:57 | |
| Nan [Vous devez être inscrit et connecté pour voir ce lien], dans ta phrase y'a la réponse : Future Pinball Ne m'en veuillez pas les gars, mais quand DOFLinx est apparu, je me suis dit "oh pinaize un truc qui peut relancer l'intérêt de PBFX2 et FP dans un pincab, j'ouvre illico presto un sous-forum on va bien se défouler ça va être grandiose " Et en fait nan, ça n'a fait ni chaud ni froid à personne, au point que j'ai supprimé le sous-forum et qu'au final tout ça est passé complètement inaperçu Bon je m'y suis intéressé quand même ne serait-ce que pour enrichir notre forum, et quand naïvement je me suis demandé "bon alors configuration des boutons des joysticks... ah nan c'est pas possible... p'tit tour sur le topic VPF... réponse de l'auteur à la question "à quand la prise en charge des joysticks ?" : jamais, point barre !"... ben clic gauche sur le dossier DOFbouzin, Shift+Del épicétou Et entre nous je me pose toujours la question de la pertinence de sa présence dans notre sujet des Logiciels pour pincab, car à mes yeux il est loin d'être indispensable et de mériter sa place dans un sujet destiné aux débutants ++ | |
khomodo
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 22:11 | |
| pour fp ça fonctionne parfaitement bien... ca me fait plaisir de rejouer a des tables fp sympa avec une physique pas si mal que ça maintenant (grâce à BAM et aux xmls) genre road girls revisited, master of the universe, jaws...
Bon pbfx2 ça a l'air plus tendu mais je vais insister et si ce sujet gêne ici, pas grave j'irais à la pêche aux infos sur ce sujet sur d'autres forums. | |
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 22:43 | |
| De ce que j'ai compris pour fx2 il faut la version non crackee pour que cela fonctionne ....ou alors se sera juste les flippers. | |
| Sujet: Re: [TUTO] DOFlinx Ven 3 Fév 2017 - 23:43 | |
| oui moi j ai une version craqué de pbfx2 et ça fonctionne tres bien mais juste les batteurs et les led rgb et non khomodo y a que shadow que le sujet gene pourtant je lui ai donne une solution mais il fait sa tete de mule essayé xpadder les gars si vous n avez pas d interface clavier ça prend une config au lancement de l exe et c est super simple a utilisé | |
| Sujet: Re: [TUTO] DOFlinx Sam 4 Fév 2017 - 0:19 | |
| - PHILI50 a écrit:
- De ce que j'ai compris pour fx2 il faut la version non crackee pour que cela fonctionne ....ou alors se sera juste les flippers.
... c'est exact je confirme ... et j'y ai passé du temps !!! ... cela dit je ne comprends toujours pas pourquoi une version crac... empêcherait DOFlinx d'intercepter les infos et de déclencher les toys ??? mystère !!! | |
loftman44
Messages : 22 Département : 44
| Sujet: Re: [TUTO] DOFlinx Sam 4 Fév 2017 - 8:40 | |
| Je trouve aussi que DOFlinx a relance l intérêt sur Futur Pinball et PBFX2, même si l animation des tous les toys ne se fait pas encore sur ce dernier. Toutefois, sous Futur Pinball, je le trouve complet et je remercie d ailleurs le travail de Slamt1lt, Terry RED et d autres encore ... car les tables avec des vidéos sont sympas. Je n arrive cependant pas a faire marcher les leds undercab avec teensy. Tous les autres commandes LINK avec mes 2 cartes KL25 sont OK. Quelqu'un a t il réussi et quel doit être le numéro ID de sa carte teensy ? Merci de. Votre aide | |
khomodo
| Sujet: Re: [TUTO] DOFlinx Sam 4 Fév 2017 - 9:51 | |
khomodo
| Sujet: Re: [TUTO] DOFlinx Sam 4 Fév 2017 - 10:03 | |
| [TUTO] DOFlinx | |
