DirectOutput Version 3.1.6999.23272, built 2019.03.01 12:55
MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy
DOF created by SwissLizard |
[Vous devez être inscrit et connecté pour voir ce lien]2020.08.12 20:22:14.550 DirectOutput Logger initialized
2020.08.12 20:22:14.532 Global config filename is "C:\DirectOutput\config\GlobalConfig.xml"
2020.08.12 20:22:14.550 Global config loaded from: C:\DirectOutput\config\GlobalConfig.xml
2020.08.12 20:22:14.550 Loading Pinball parts
2020.08.12 20:22:14.550 Loading cabinet
2020.08.12 20:22:14.551 Will load cabinet config file: C:\DirectOutput\config\cabinet.xml
2020.08.12 20:22:14.635 1 output controller defnitions and 2 toy definitions loaded from cabinet config.
2020.08.12 20:22:14.636 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig.
2020.08.12 20:22:14.637 Cabinet auto configuration started
2020.08.12 20:22:14.663 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01
2020.08.12 20:22:14.663 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 16
2020.08.12 20:22:14.670 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log)
2020.08.12 20:22:14.680 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available>
2020.08.12 20:22:14.680 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech
2020.08.12 20:22:14.682 LedWiz-like device at VID=3141, PID=30218, product string=USB Keyboard, manufacturer string=<not available>
2020.08.12 20:22:14.682 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet
2020.08.12 20:22:14.682 HID caps: usage page=1, usage=4, number of link collection nodes=1, output report byte length=9
2020.08.12 20:22:14.683 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech
2020.08.12 20:22:14.683 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet
2020.08.12 20:22:14.684 HID caps: usage page=12, usage=1, number of link collection nodes=1, output report byte length=0
2020.08.12 20:22:14.684 LedWiz-like device at VID=1133, PID=49278, product string=Gaming Mouse G402, manufacturer string=Logitech
2020.08.12 20:22:14.686 Opening 32-bit LedWiz driver...
2020.08.12 20:22:14.687 Detected and added LedWiz Nr. 1 with name LedWiz 01
2020.08.12 20:22:14.687 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1
2020.08.12 20:22:14.691 Cabinet auto configuration finished
2020.08.12 20:22:14.691 Autoconfig complete.
2020.08.12 20:22:14.691 Cabinet config loaded successfully from C:\DirectOutput\config\cabinet.xml
2020.08.12 20:22:14.691 Cabinet loaded
2020.08.12 20:22:14.691 Loading table config
2020.08.12 20:22:14.691 Warning: No table config file found. Will try to load config from LedControl file(s).
2020.08.12 20:22:14.691 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName cv
2020.08.12 20:22:14.694 Loading LedControl file C:\DirectOutput\config\directoutputconfig30.ini
2020.08.12 20:22:14.703 Min DOF Version is 0.8 for file directoutputconfig30.ini
2020.08.12 20:22:15.382 Loading LedControl file C:\DirectOutput\config\directoutputconfig51.ini
2020.08.12 20:22:15.385 Min DOF Version is 0.8 for file directoutputconfig51.ini
2020.08.12 20:22:15.572 2 directoutputconfig.ini or ledcontrol.ini files loaded.
2020.08.12 20:22:15.573 Config for RomName cv exists in LedControl data. Updating cabinet and config.
2020.08.12 20:22:15.632 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30
2020.08.12 20:22:15.633 Debug: Setting up shape effect for area. L: 0, T: 0, W: 9, H: 30
2020.08.12 20:22:15.633 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30
2020.08.12 20:22:15.643 Debug: Setting up shape effect for area. L: 91, T: 0, W: 9, H: 30
2020.08.12 20:22:15.644 Table config loading finished: romname=cv, tablename=Cirqus Voltaire (1997)
2020.08.12 20:22:15.646 Pinball parts loaded
2020.08.12 20:22:15.648 Starting processes
2020.08.12 20:22:15.648 Initializing cabinet
2020.08.12 20:22:15.648 Debug: Initializing output controllers
2020.08.12 20:22:15.652 TeensyStripController TeensyStripController intialized and updater thread started.
2020.08.12 20:22:15.653 Pinscape Pinscape Controller 01 intialized and updater thread started.
2020.08.12 20:22:15.653 Debug: Initializing LedWiz Nr. 01
2020.08.12 20:22:15.653 TeensyStripController TeensyStripController updater thread started.
2020.08.12 20:22:15.654 Pinscape Pinscape Controller 01 updater thread started.
2020.08.12 20:22:15.654 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01.
2020.08.12 20:22:15.655 LedWiz Nr. 01 initialized and updater thread initialized.
2020.08.12 20:22:15.655 Debug: Output controllers initialized
2020.08.12 20:22:15.656 Updater thread for LedWiz 01 started.
2020.08.12 20:22:15.661 Cabinet initialized
2020.08.12 20:22:15.664 Loading shape definition file: C:\DirectOutput\config\DirectOutputShapes.xml
2020.08.12 20:22:15.706 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:15), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:29, Bottom:0, Width:30, Height:1)
2020.08.12 20:22:15.706 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:85, W:100, H:15), Matrix(W:6, H:30), ResultArea(Left: 0, Top:5, Right:29, Bottom:5, Width:30, Height:1)
2020.08.12 20:22:15.707 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.710 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.725 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.728 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.728 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.728 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.729 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.729 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.729 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.730 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.730 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.730 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:0, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 0, Top:0, Right:2, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.730 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.730 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.731 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.731 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.731 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.732 Debug: BitmapEffectBase. Grabbing image clip: W: 3, H:2, BML: 35, BMT: 18, BMW: 16, BMH: 16
2020.08.12 20:22:15.732 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.732 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:91, T:0, W:9, H:30), Matrix(W:6, H:30), ResultArea(Left: 27, Top:0, Right:29, Bottom:1, Width:3, Height:2)
2020.08.12 20:22:15.743 Framework initialized.
2020.08.12 20:22:15.743 Have fun!
2020.08.12 20:22:21.189 TeensyStripController TeensyStripController updater thread has connected to TeensyStripController TeensyStripController.
2020.08.12 20:22:42.983 Finishing framework
2020.08.12 20:22:42.985 Finishing cabinet
2020.08.12 20:22:42.986 Debug: Finishing output controllers
2020.08.12 20:22:43.391 TeensyStripController TeensyStripController updater thread has disconnected from TeensyStripController TeensyStripController and will terminate.
2020.08.12 20:22:43.391 TeensyStripController TeensyStripController finished and updater thread stopped.
2020.08.12 20:22:43.392 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate.
2020.08.12 20:22:43.393 Pinscape Pinscape Controller 01 finished and updater thread stopped.
2020.08.12 20:22:43.393 Debug: Finishing LedWiz Nr. 01
2020.08.12 20:22:43.393 Updater thread for LedWiz 01 terminated.
2020.08.12 20:22:43.407 LedWiz Nr. 01 finished and updater thread stopped.
2020.08.12 20:22:43.407 Debug: Output controllers finished
2020.08.12 20:22:43.407 Cabinet finished
2020.08.12 20:22:43.407 DirectOutput framework finished.
2020.08.12 20:22:43.407 Bye and thanks for using!
2020.08.12 20:22:43.419 Debug: Disposing LedWiz instance 01.
