I also manufacture and sell NVRAM chips, compatible 6116 RAM and 6264/62256 RAM for pinball or another device with those RAM chips. NVRAM allow remove battery for ever, replace RAM and Battery by NVRAM and no more problems with acid damage and never more will need replace batteries.
Prices: 1 unit ------------ 19 euros/unit 5 units ----------- 18 euros/unit 10 unidades ----- 17 euros/unit 50 or more contact with me by private
Also I may provide the socket, 24 or 28 pin, price 0.7 Euros/unit.
To place order contact by private message, email pinballsp@gmail.com, Skype pinballsp, Whatsapp +34 693344445, Facebook messenger https://www.facebook.com/Pinballsp .
Compatibility list (for specific pinball or device contact to confirm)
this is very interesting ............. you how the branch on the pinball ?? I own a diner williams, a funhouse williams, two data east, jurassic ,last hero action and also a star wars data,
yes ........................!!!!!!!...........................my english is very well.................... ........................
on fait se que l'on peux.................................. :ji8: le problème c'est que le forum est devenu international..................ça va etre dur de délirer en anglais ................mais le faites que j'écris en anglais c'est déja le délire.................... on devrai imposer le Français sur le forum................la French touch..........quoi..............
I have 29 pinballs, unfortunately most are stored because of can not put at home currently. My idea in 2006 was to buy a big house, but then began the economical crisis and was not possible, so now all my pinballs except 4, are stored waiting for a bigger house.
Muy current collection in pinballowners http://www.pinballowners.com/planeta9999
Super collection congratulation ............... I am interested in NVRAM chips for the flippers I cited how do you install it in the pinball
To install NVRAM you must remove the RAM chip from CPU board, install a DIP socket and the connect the NVRAM. Also must remove for ever the batteries and even the battery holder.
In Petacos spanish forum a friend posted instructions with pictures to install NVRAM, its in spanish language but may use translator and even only with pictures may see how he made. This is the post link http://petacos.forumcommunity.net/?t=57953064
It is easy, but must to be careful because of the PCB tracks are very thin and may break it. I prefer always cut the RAM pins, remove it and solder a DIP socket.
At any rate in some pinballs, I think in System 11, RAM is in socket from factory, so simply remove RAM and put NVRAM in same socket.
very interesting ..... I'll take later NVRAM chips for my pinball, I will first put on my pinball pin2DMD of it will be available, warned me that it's available greeting André
Ok, dont worry André, I will warn you, more led panels will be here in about one week. Rest of components I have all in stock, PCB, electronic components, power supply, frames, cables, etc...
