DirectOutput Version 3.1.7776.42172, built 2021.04.16 23:25
MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy
DOF created by SwissLizard | https://github.com/mjrgh/DirectOutput
2021.07.18 09:26:13.602 DirectOutput Logger initialized
2021.07.18 09:26:13.586 Global config filename is "C:\DirectOutput\config\GlobalConfig_B2SServer.xml"
2021.07.18 09:26:13.602 Global config loaded from: C:\DirectOutput\config\GlobalConfig_B2SServer.xml
2021.07.18 09:26:13.602 Loading Pinball parts
2021.07.18 09:26:13.602 Loading cabinet
2021.07.18 09:26:13.609 Will load cabinet config file: C:\DirectOutput\Config\Cabinet Config.xml
2021.07.18 09:26:13.812 1 output controller defnitions and 4 toy definitions loaded from cabinet config.
2021.07.18 09:26:13.812 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig.
2021.07.18 09:26:13.812 Cabinet auto configuration started
2021.07.18 09:26:13.859 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01
2021.07.18 09:26:13.859 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 32
2021.07.18 09:26:13.874 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log)
2021.07.18 09:26:13.890 LedWiz-like device at VID=1133, PID=50475, product string=USB Receiver, manufacturer string=Logitech
2021.07.18 09:26:13.906 LedWiz-like device at VID=1133, PID=50475, product string=USB Receiver, manufacturer string=Logitech
2021.07.18 09:26:13.922 LedWiz-like device at VID=1133, PID=50475, product string=USB Receiver, manufacturer string=Logitech
2021.07.18 09:26:13.922 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet
2021.07.18 09:26:13.922 HID caps: usage page=1, usage=4, number of link collection nodes=1, output report byte length=9
2021.07.18 09:26:13.938 LedWiz-like device at VID=1133, PID=50475, product string=USB Receiver, manufacturer string=Logitech
2021.07.18 09:26:13.938 LedWiz-like device at VID=64250, PID=240, product string=Pinscape Controller, manufacturer string=mjrnet
2021.07.18 09:26:13.938 HID caps: usage page=12, usage=1, number of link collection nodes=1, output report byte length=0
2021.07.18 09:26:13.938 Opening 32-bit LedWiz driver...
2021.07.18 09:26:13.938 Detected and added LedWiz Nr. 1 with name LedWiz 01
2021.07.18 09:26:13.938 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1
2021.07.18 09:26:13.954 Cabinet auto configuration finished
2021.07.18 09:26:13.954 Autoconfig complete.
2021.07.18 09:26:13.954 Cabinet config loaded successfully from C:\DirectOutput\Config\Cabinet Config.xml
2021.07.18 09:26:13.954 Cabinet loaded
2021.07.18 09:26:13.954 Loading table config
2021.07.18 09:26:13.954 No TableFilename specified, will use empty tableconfig
2021.07.18 09:26:13.954 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName pinupmenu
2021.07.18 09:26:13.954 Loading LedControl file C:\DirectOutput\Config\directoutputconfig30.ini
2021.07.18 09:26:13.954 Min DOF Version is 0.8 for file directoutputconfig30.ini
2021.07.18 09:26:13.954 Resolving Tables Variables
2021.07.18 09:26:13.954 Resolving Global Variables
2021.07.18 09:26:14.672 Loading LedControl file C:\DirectOutput\Config\directoutputconfig51.ini
2021.07.18 09:26:14.688 Min DOF Version is 0.8 for file directoutputconfig51.ini
2021.07.18 09:26:14.688 Resolving Tables Variables
2021.07.18 09:26:14.688 Resolving Global Variables
2021.07.18 09:26:15.032 2 directoutputconfig.ini or ledcontrol.ini files loaded.
2021.07.18 09:26:15.032 Config for RomName pinupmenu exists in LedControl data. Updating cabinet and config.
2021.07.18 09:26:15.063 Debug: Setting up shape effect for area. L: 20, T: 0, W: 14, H: 100, Name: LETTERP
2021.07.18 09:26:15.063 Debug: Setting up shape effect for area. L: 40, T: 0, W: 14, H: 100, Name: LETTERL
2021.07.18 09:26:15.063 Debug: Setting up shape effect for area. L: 60, T: 0, W: 14, H: 100, Name: LETTERA
2021.07.18 09:26:15.063 Debug: Setting up shape effect for area. L: 80, T: 0, W: 14, H: 100, Name: LETTERY
2021.07.18 09:26:15.079 Table config loading finished: romname=pinupmenu, tablename=pinupmenu
2021.07.18 09:26:15.079 Pinball parts loaded
2021.07.18 09:26:15.079 Starting processes
2021.07.18 09:26:15.079 Initializing cabinet
2021.07.18 09:26:15.079 Debug: Initializing output controllers
2021.07.18 09:26:15.128 TeensyStripController LedStripController intialized and updater thread started.
2021.07.18 09:26:15.128 Pinscape Pinscape Controller 01 intialized and updater thread started.
2021.07.18 09:26:15.128 Debug: Initializing LedWiz Nr. 01
2021.07.18 09:26:15.128 TeensyStripController LedStripController updater thread started.
2021.07.18 09:26:15.128 Pinscape Pinscape Controller 01 updater thread started.
2021.07.18 09:26:15.128 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01.
2021.07.18 09:26:15.128 LedWiz Nr. 01 initialized and updater thread initialized.
2021.07.18 09:26:15.128 Debug: Output controllers initialized
2021.07.18 09:26:15.128 Updater thread for LedWiz 01 started.
2021.07.18 09:26:15.128 Initializing ComPort COM4 with these settings :
2021.07.18 09:26:15.128 BaudRate 9600, Parity None, DataBits 8, StopBits One, R/W Timeouts 200ms
2021.07.18 09:26:15.128 Handshake Timings : Open 50ms, Loop Start/End 20/50ms, DTR enable False
2021.07.18 09:26:15.128 Cabinet initialized
2021.07.18 09:26:15.128 Loading shape definition file: C:\DirectOutput\Config\DirectOutputShapes.xml
2021.07.18 09:26:15.159 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:20, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 14, Top:0, Right:24, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.159 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:20, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 14, Top:0, Right:24, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.175 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 377, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:40, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 28, Top:0, Right:38, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:40, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 28, Top:0, Right:38, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 345, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:60, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 43, Top:0, Right:53, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:60, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 43, Top:0, Right:53, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 257, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:80, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 57, Top:0, Right:67, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:80, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 57, Top:0, Right:67, Bottom:7, Width:11, Height:
2021.07.18 09:26:15.191 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 449, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:15.191 Framework initialized.
2021.07.18 09:26:15.191 Have fun!
2021.07.18 09:26:15.284 TeensyStripController LedStripController updater thread has connected to TeensyStripController LedStripController.
2021.07.18 09:26:36.732 Finishing framework
2021.07.18 09:26:36.732 Finishing cabinet
2021.07.18 09:26:36.732 Debug: Finishing output controllers
2021.07.18 09:26:36.779 TeensyStripController LedStripController updater thread has disconnected from TeensyStripController LedStripController and will terminate.
2021.07.18 09:26:36.779 TeensyStripController LedStripController finished and updater thread stopped.
2021.07.18 09:26:36.810 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate.
2021.07.18 09:26:36.810 Pinscape Pinscape Controller 01 finished and updater thread stopped.
2021.07.18 09:26:36.810 Debug: Finishing LedWiz Nr. 01
2021.07.18 09:26:36.810 Updater thread for LedWiz 01 terminated.
2021.07.18 09:26:36.825 LedWiz Nr. 01 finished and updater thread stopped.
2021.07.18 09:26:36.825 Debug: Output controllers finished
2021.07.18 09:26:36.825 Cabinet finished
2021.07.18 09:26:36.825 DirectOutput framework finished.
2021.07.18 09:26:36.825 Bye and thanks for using!
2021.07.18 09:26:50.925 Global config filename is "C:\DirectOutput\config\GlobalConfig_B2SServer.xml"
2021.07.18 09:26:50.946 Global config loaded from: C:\DirectOutput\config\GlobalConfig_B2SServer.xml
2021.07.18 09:26:50.946 Loading Pinball parts
2021.07.18 09:26:50.946 Loading cabinet
2021.07.18 09:26:50.946 Will load cabinet config file: C:\DirectOutput\Config\Cabinet Config.xml
2021.07.18 09:26:51.102 1 output controller defnitions and 4 toy definitions loaded from cabinet config.
2021.07.18 09:26:51.102 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig.
2021.07.18 09:26:51.102 Cabinet auto configuration started
2021.07.18 09:26:51.102 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01
2021.07.18 09:26:51.102 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 32
2021.07.18 09:26:51.102 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log)
2021.07.18 09:26:51.102 Opening 32-bit LedWiz driver...
2021.07.18 09:26:51.102 Detected and added LedWiz Nr. 1 with name LedWiz 01
2021.07.18 09:26:51.102 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1
2021.07.18 09:26:51.102 Cabinet auto configuration finished
2021.07.18 09:26:51.102 Autoconfig complete.
2021.07.18 09:26:51.102 Cabinet config loaded successfully from C:\DirectOutput\Config\Cabinet Config.xml
2021.07.18 09:26:51.102 Cabinet loaded
2021.07.18 09:26:51.102 Loading table config
2021.07.18 09:26:51.102 No TableFilename specified, will use empty tableconfig
2021.07.18 09:26:51.102 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName pinupmenu
2021.07.18 09:26:51.102 Loading LedControl file C:\DirectOutput\Config\directoutputconfig30.ini
2021.07.18 09:26:51.118 Min DOF Version is 0.8 for file directoutputconfig30.ini
2021.07.18 09:26:51.118 Resolving Tables Variables
2021.07.18 09:26:51.118 Resolving Global Variables
2021.07.18 09:26:51.244 Debug: Disposing LedWiz instance 01.
2021.07.18 09:26:51.820 Loading LedControl file C:\DirectOutput\Config\directoutputconfig51.ini
2021.07.18 09:26:51.820 Min DOF Version is 0.8 for file directoutputconfig51.ini
2021.07.18 09:26:51.820 Resolving Tables Variables
2021.07.18 09:26:51.820 Resolving Global Variables
2021.07.18 09:26:52.164 2 directoutputconfig.ini or ledcontrol.ini files loaded.
2021.07.18 09:26:52.164 Config for RomName pinupmenu exists in LedControl data. Updating cabinet and config.
2021.07.18 09:26:52.180 Debug: Setting up shape effect for area. L: 20, T: 0, W: 14, H: 100, Name: LETTERP
2021.07.18 09:26:52.180 Debug: Setting up shape effect for area. L: 40, T: 0, W: 14, H: 100, Name: LETTERL
2021.07.18 09:26:52.180 Debug: Setting up shape effect for area. L: 60, T: 0, W: 14, H: 100, Name: LETTERA
2021.07.18 09:26:52.180 Debug: Setting up shape effect for area. L: 80, T: 0, W: 14, H: 100, Name: LETTERY
2021.07.18 09:26:52.180 Table config loading finished: romname=pinupmenu, tablename=pinupmenu
2021.07.18 09:26:52.180 Pinball parts loaded
2021.07.18 09:26:52.180 Starting processes
2021.07.18 09:26:52.180 Initializing cabinet
2021.07.18 09:26:52.180 Debug: Initializing output controllers
2021.07.18 09:26:52.227 TeensyStripController LedStripController intialized and updater thread started.
2021.07.18 09:26:52.227 TeensyStripController LedStripController updater thread started.
2021.07.18 09:26:52.227 Initializing ComPort COM4 with these settings :
2021.07.18 09:26:52.227 BaudRate 9600, Parity None, DataBits 8, StopBits One, R/W Timeouts 200ms
2021.07.18 09:26:52.227 Handshake Timings : Open 50ms, Loop Start/End 20/50ms, DTR enable False
2021.07.18 09:26:52.227 Pinscape Pinscape Controller 01 intialized and updater thread started.
2021.07.18 09:26:52.227 Debug: Initializing LedWiz Nr. 01
2021.07.18 09:26:52.227 Pinscape Pinscape Controller 01 updater thread started.
2021.07.18 09:26:52.227 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01.
2021.07.18 09:26:52.227 LedWiz Nr. 01 initialized and updater thread initialized.
2021.07.18 09:26:52.227 Debug: Output controllers initialized
2021.07.18 09:26:52.227 Updater thread for LedWiz 01 started.
2021.07.18 09:26:52.227 Cabinet initialized
2021.07.18 09:26:52.227 Loading shape definition file: C:\DirectOutput\Config\DirectOutputShapes.xml
2021.07.18 09:26:52.227 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:20, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 14, Top:0, Right:24, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.227 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:20, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 14, Top:0, Right:24, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 377, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:40, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 28, Top:0, Right:38, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:40, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 28, Top:0, Right:38, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 345, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:60, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 43, Top:0, Right:53, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:60, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 43, Top:0, Right:53, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 257, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleShapeEffect. Calculated area size: AreaDef(L:80, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 57, Top:0, Right:67, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: MatrixBase for RGBAMatrixColorScaleBitmapEffect. Calculated area size: AreaDef(L:80, T:0, W:14, H:100), Matrix(W:8, H:72), ResultArea(Left: 57, Top:0, Right:67, Bottom:7, Width:11, Height:
2021.07.18 09:26:52.242 Debug: BitmapEffectBase. Grabbing image clip: W: 11, H:8, BML: 449, BMT: 254, BMW: 7, BMH: 7
2021.07.18 09:26:52.242 Framework initialized.
2021.07.18 09:26:52.242 Have fun!
2021.07.18 09:26:52.383 TeensyStripController LedStripController updater thread has connected to TeensyStripController LedStripController.
2021.07.18 09:27:31.348 Finishing framework
2021.07.18 09:27:31.363 Finishing cabinet
2021.07.18 09:27:31.363 Debug: Finishing output controllers
2021.07.18 09:27:31.395 TeensyStripController LedStripController updater thread has disconnected from TeensyStripController LedStripController and will terminate.
2021.07.18 09:27:31.395 TeensyStripController LedStripController finished and updater thread stopped.
2021.07.18 09:27:31.427 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate.
2021.07.18 09:27:31.428 Pinscape Pinscape Controller 01 finished and updater thread stopped.
2021.07.18 09:27:31.428 Debug: Finishing LedWiz Nr. 01
2021.07.18 09:27:31.428 Updater thread for LedWiz 01 terminated.
2021.07.18 09:27:31.444 LedWiz Nr. 01 finished and updater thread stopped.
2021.07.18 09:27:31.444 Debug: Output controllers finished
2021.07.18 09:27:31.444 Cabinet finished
2021.07.18 09:27:31.444 DirectOutput framework finished.
2021.07.18 09:27:31.444 Bye and thanks for using!
