| [RESOLU] Problème DMD by PinballSP | |
Mikael
Messages : 120 Département : Belgique (Marche-en-Famenne)
| Sujet: [RESOLU] Problème DMD by PinballSP Mar 27 Déc 2016 - 18:23 | |
Dernière édition par leevuth le Dim 1 Jan 2017 - 11:59, édité 2 fois (Raison : titre édité, ajout [EN COURS]) | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mar 27 Déc 2016 - 18:49 | |
| Quand tu l'allumes, sur la mire PIN2DMD tu as aussi ce souci ou pas ?
Mikael
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mar 27 Déc 2016 - 22:21 | |
| sur la mire Pin2DMD ... ??? Je comprends pas ce que tu veux dire
Dernière édition par shadow_shd le Mer 28 Déc 2016 - 9:22, édité 1 fois (Raison : suppression citation message précédent) | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mar 27 Déc 2016 - 23:18 | |
| contact le via message privé et tu lui envoie les photos | |
pinballsp
Messages : 161 Département : pinball
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 0:35 | |
| . Hello Mikael. Like I said you by email, do not need udpate firmware, its already preloaded. And really do not know what is your problem exactly. So, clarify. 1.- DMD first picture, is exactly what you see or its only look in picture (half screen and in red/orange) ??, DMD has a refresh speed, so if take a picture may look in picture display not full when really you see it perfect. So, tell me if what we see in first picture is exactly what you see there. Also confirm if you see image in colors or in red/orange like see in picture. When power supply is not connected, and only connect DMD by USB then leds are dimly lit and red/orange. Do you have connect the power supply cable to 220VAC ?? 2.- Do not need DFU USB now, firmware is already preloaded, so if you have apply already key license its ready to work. At any rate if you want enter in boot mode to update, simply config BOOT Switch in proper position, connect to PC, run DFUSe Demo and software will recognize it inmediately. Check full instructions in these links: https://www.pincabpassion.net/t4542-tuto-dmdst32-by-pinballsp?highlight=dmdst32 (french) https://www.pincabpassion.net/t4446p25-archive-dmdst32-dmd-concu-et-fabrique-par-pinballsp?highlight=dmdst32 (english) 3.- Only need run Zadig to config pin2dmd drivers, to work like a lib32 device. | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 9:27 | |
| - Mikael a écrit:
- sur la mire Pin2DMD ... ???
Je comprends pas ce que tu veux dire Quand ton DMDST32 s'alimente, il affiche : C'est ce qu'on appelle la mire, ce qui est affiché avant qu'un logiciel envoie un signal dessus ++ | |
Mikael
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 16:17 | |
| Merci pour vos infos ... La première photo du DMD est ce que je vois quand il est connecté via USB (3.0). Je travaille sur Win10.
Je vois que le DMD travaille derrière quand même... (des effets d'animations se produisent à l'arrière).
Je n'ai pas encore alimenter le DMD en 220VAC. L'activation est ok.
Par contre ce qui me tracasse, c'est de ne pas voir dans dFuSe "available DFU Devices" une liste défilante avec le DMD repris dans celle-ci???
DMDST32 affiché avec toutes les couleurs, on a seulement ça quand on l'alimente en 220VAC ?
Les switchs de update à l'arrière du DMD doivent être à quelle position en temps normal (1 et 2) sur OFF ?
Je vous tiens au jus ! | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 16:20 | |
| Non, surtout pas en 220 vac, c'est du 5v seulement. Pour ma part j'ai pris une alimentation du molex du pc, fil rouge 5v, pas la jaune qui est en 12v. les fils noirs c'est pour la masse.
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 16:21 | |
| Je pense qu'il parle du transfo qui lui s'alimente en 220v , mais si il a une image c'est qu'il est dèjà branché , sinon son dmd va pu ressembler à grand chose après
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 16:22 | |
| Bah de la fumée | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 16:24 | |
| Et un petit tas de poussière à 180 euros | |
pinballsp
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 18:04 | |
| - Mikael a écrit:
- Je vois que le DMD travaille derrière quand même... (des effets d'animations se produisent à l'arrière).
Par contre ce qui me tracasse, c'est de ne pas voir dans dFuSe "available DFU Devices" une liste défilante avec le DMD repris dans celle-ci??? DMDST32 affiché avec toutes les couleurs, on a seulement ça quand on l'alimente en 220VAC ? Les switchs de update à l'arrière du DMD doivent être à quelle position en temps normal (1 et 2) sur OFF ?
That is your problem, if you do not connect the power supply to AC, DMD can not work. Check your DMD, you will see a cable with two wires connected to power supply, you must connect it to 220VAC then your DMD will work perfect. DIP switch that print " Update" in board, you must change position to update firmware by DFU USB, then you will see device in DFUSedemo software. After update, change again switch to original position to run software. | |
Mikael
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Mer 28 Déc 2016 - 22:46 | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 7:19 | |
| C'est bien ca En fait tu alimentais uniquement avec le port USB, qui n'est pas assez puissant pour le faire fonctionner. | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 8:42 | |
| Ben ce câble gris, je le relierais au molex de l'alim du pc, sur un fil rouge et noir. | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 9:08 | |
| Euh Bah nan le fil gris doit aller sur du 220 V puisqu'il alimente le transfo 220 -> 5 V J'avais posé la question à Luis s'il était possible, pour m'éviter de tirer un câble et poser une prise 220 V dans mon fronton, de récupérer le 5 V qui alimentait mon ancien PinDMD v2, mais l'intensité en ampère était insuffisante (Luis préconise du 7 ampères minimum). ++ | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 9:13 | |
| Ben c'est comme ça sur mon pincab. On n'a pas besoin d'illuminer un boulevard non ? Celà veut dire que mon pin2dmd est sous tension alors ? | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 9:25 | |
| C'est un DMDST32 que tu as Leevuth ou un "Rappelbox" ? Dans mon cas je voulais me passer du transfo 220/5 que Luis fournit pour brancher directement les fils de ma Molex dédiée PinDMD v2, mais il m'a conseillé pour des questions de stabilité d'intensité électrique d'utiliser plutôt le transfo 220/5. Et comme en principe je ne suis pas trop contrariant, bah j'ai tiré un câble et posé une prise 220 V dans mon fronton pour alimenter mon DMDSt32 ++ | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 9:26 | |
| Sous tension ça veut dire qu'il y a du jus Je pense qu'il préconise 7A en prévoyant assez pour le dmd +cartes additionnelles mais ça doit faire bien moins Si tu n'utilises pas le transfo sur son dmd, tu economises du câble à 'forte'section | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 9:27 | |
| @Shadow_shdC'est un STM32 de chez Rap. Mais c'est la même chose, car cette carte est fournie par PinballSP (ils travaillaient ensemble, à l'époque je pense). Rap. ne faisait que d'assembler les pièces et les revendre. Je peux te montre ma carte, si je retrouve la photo (j'avais un souci de connecteur ubs qui se cassait) | |
Mikael
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 21:27 | |
| Tout à fait : ça fonctionne parfaitement ! Il manquait l'alimentation en 220V AC tout simplement ! Cadeau : Par contre j'ai encore un petit souci ... La vidéo DMD pour PinballX fonctionne lors d'un mode pause ou lors de la page d'accueil mais lorsque j'active une table, j'ai plus rien qui s'affiche ... seulement le DMD sur la table même ... Que dois-je faire ? Dois-je aller dans les settings PinballX ou Visual Pinball dans VPinMame ? | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 21:40 | |
| Je t'invite à lire le tuto sur Pin2dmd, et Vpinmame. Il "parait" qu'il faut cocher "use external DMD" dans l'option de Vpinmame. | |
Mikael
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 23:11 | |
| J'ai trouvé ... Merci tout de même ... Sur DMD de la table en question, click droit ... puis setup VPinMame, cocher "use DMD" et décocher "DMD Windows screen". et ça fonctionne parfaitement... seulement, il faut le faire pour toutes les tables individuellement ... et redémarrer une fois PinballX et puis c'est ok. Ce week-end, je fais une vidéo de mon pincab ... presque fini (hors toys), ce sera pour plus tard ^^maintenant place au potar et MAJ de la KL puis jeu jeu jeu A bientôt ... | |
| Sujet: Re: [RESOLU] Problème DMD by PinballSP Jeu 29 Déc 2016 - 23:14 | |
| Oui mais, il y a une solution en un seul clic . En lançant le setup qui se trouve dans le répertoire "vpinmame" et en allant dans l'option "setup defaults" tu le fais une seule fois pour toute. | |
