 [TUTO] roms colorisées Stern sur LCD et Pin2DMD
BorisFR
Mick_03
1962kafer
Snapouille
nicofab18
ocbbomb
MAXxXAM
djtete
flaype
jphil82
Memechke8
Carny_Priest
jeyspeed
Nnanard8
lglinux
belgarion41
khomodo
AnthozoA
DamsBALL
paraspeed
chucky87
32 participants
djtete
djtete
Département : 85710
[TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 Empty
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptySam 24 Nov 2018 - 12:45
voici mon dmddevice.ini
Code:
[global]
; how to downscale SEGA 192x64 pixel games to smaller displays: fit, fill or stretch
resize = fit
; flips the image horizontally
fliphorizontally = false
; flips the image vertically
flipvertically = false
; enable or disable frame-by-frame colorization (inactive in VPX bundle)
colorize = true
; a DMD that renders with nice dots on a computer monitor
[virtualdmd]
enabled = true
; virtual dmd stays on top of all other windows
stayontop = false
; hide the resize grip
hidegrip = true
; ignore the aspect ratio of the rendered dots when resizing
ignorear = true
; use VPM's registry values when positioning the virtual dmd
useregistry = true
; x-axis of the window position
left = 2243
; y-axis of the window position
top = 845
; width of the dmd in monitor pixels
width = 806
; height of the dmd in monitor pixels
height = 180
; scale the dot size (set to 0.8 for same size as pre-1.6.0)
dotsize = 1.0
[pindmd1]
; if false, doesn't bother looking for a pinDMD1
enabled = true
[pindmd2]
; if false, doesn't bother looking for a pinDMD2
enabled = true
[pindmd3]
; if false, doesn't bother looking for a pinDMD3
enabled = true
; COM port, e.g. COM3
port =
[pin2dmd]
; if false, doesn't bother looking for a PIN2DMD
enabled = true
[browserstream]
; if enabled, stream to your browser in your LAN
enabled = false
port = 9090
[vpdbstream]
; if enabled, stream DMD to https://test.vpdb.io/live
enabled = false
endpoint = https://api-test.vpdb.io/
[video]
; if enabled, writes frames to an .avi file
enabled = false
; path to folder or .avi file. if folder, gamename.avi is used.
path =
[pinup]
; if enabled, send frames to PinUP.
enabled = false
Et mon dmd device log config
Code:
 [1] 2018/11/22 12:58:25.008  INFO | Determined color path from assembly path: C:\Jeux et programmation flipper\Visual Pinball\VPinMAME\altcolor
 [1] 2018/11/22 12:58:25.043  INFO | Starting VPinMAME API through Setup.exe.
 [1] 2018/11/22 12:58:25.043  INFO | [vpm] Open()
 [1] 2018/11/22 12:58:25.043  INFO | [vpm] Set_4_Colors_Palette()
 [1] 2018/11/22 12:58:25.043  INFO | Setting palette to 4 colors...
 [1] 2018/11/22 12:58:25.051  INFO | [vpm] PM_GameSettings(1)
 [1] 2018/11/22 12:58:25.051  INFO | Enabling game colorization
 [1] 2018/11/22 12:58:25.051  INFO | Setting game name: acd_170hc
 [1] 2018/11/22 12:58:25.051  INFO | Setting color: #FFFF5820
 [1] 2018/11/22 12:58:25.066  INFO | Loading palette file at C:\Jeux et programmation flipper\Visual Pinball\VPinMAME\altcolor\acd_170hc\pin2dmd.pal...
 [1] 2018/11/22 12:58:25.066 TRACE | [1] Read version as 1
 [1] 2018/11/22 12:58:25.066 TRACE | [3] Read number of palettes as 15
 [1] 2018/11/22 12:58:25.066 TRACE |   [5] [palette] Read index as 0
 [1] 2018/11/22 12:58:25.066 TRACE |   [7] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.066 TRACE |   [8] [palette] Read type as 2
 [1] 2018/11/22 12:58:25.066 TRACE |   [56] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.066 TRACE |   [58] [palette] Read index as 1
 [1] 2018/11/22 12:58:25.066 TRACE |   [60] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.082 TRACE |   [61] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.082 TRACE |   [109] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.082 TRACE |   [111] [palette] Read index as 2
 [1] 2018/11/22 12:58:25.082 TRACE |   [113] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.082 TRACE |   [114] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.082 TRACE |   [162] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.082 TRACE |   [164] [palette] Read index as 3
 [1] 2018/11/22 12:58:25.082 TRACE |   [166] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.082 TRACE |   [167] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.082 TRACE |   [215] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.082 TRACE |   [217] [palette] Read index as 4
 [1] 2018/11/22 12:58:25.082 TRACE |   [219] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.082 TRACE |   [220] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.082 TRACE |   [268] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.098 TRACE |   [270] [palette] Read index as 5
 [1] 2018/11/22 12:58:25.098 TRACE |   [272] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.098 TRACE |   [273] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.098 TRACE |   [321] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.098 TRACE |   [323] [palette] Read index as 6
 [1] 2018/11/22 12:58:25.098 TRACE |   [325] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.098 TRACE |   [326] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.098 TRACE |   [374] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.098 TRACE |   [376] [palette] Read index as 7
 [1] 2018/11/22 12:58:25.098 TRACE |   [378] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.098 TRACE |   [379] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.098 TRACE |   [427] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.098 TRACE |   [429] [palette] Read index as 8
 [1] 2018/11/22 12:58:25.098 TRACE |   [431] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.098 TRACE |   [432] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.113 TRACE |   [480] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.113 TRACE |   [482] [palette] Read index as 9
 [1] 2018/11/22 12:58:25.113 TRACE |   [484] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.113 TRACE |   [485] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.113 TRACE |   [533] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.113 TRACE |   [535] [palette] Read index as 10
 [1] 2018/11/22 12:58:25.113 TRACE |   [537] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.113 TRACE |   [538] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.113 TRACE |   [586] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.113 TRACE |   [588] [palette] Read index as 11
 [1] 2018/11/22 12:58:25.113 TRACE |   [590] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.113 TRACE |   [591] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.113 TRACE |   [639] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.113 TRACE |   [641] [palette] Read index as 12
 [1] 2018/11/22 12:58:25.129 TRACE |   [643] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.129 TRACE |   [644] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.129 TRACE |   [692] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.129 TRACE |   [694] [palette] Read index as 13
 [1] 2018/11/22 12:58:25.129 TRACE |   [696] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.129 TRACE |   [697] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.129 TRACE |   [745] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.129 TRACE |   [747] [palette] Read index as 14
 [1] 2018/11/22 12:58:25.129 TRACE |   [749] [palette] Read number of colors as 16
 [1] 2018/11/22 12:58:25.129 TRACE |   [750] [palette] Read type as 0
 [1] 2018/11/22 12:58:25.129 TRACE |   [798] [palette] Read 48 bytes of color data
 [1] 2018/11/22 12:58:25.129 TRACE | [800] Read number of mappings as 65535
 [1] 2018/11/22 12:58:25.145  WARN | [65535] Missing 720885 bytes for 65535 masks, ignoring.
 [1] 2018/11/22 12:58:25.145 DEBUG | [colorize] Setting new palette: [ #FF000000 #FF272727 #FFFF8000 #FFFF6A6A #FF6B6B6B #FF005E2F #FFAAD5FF #FFC0C0C0 #FF770000 #FFFFFFFF #FF643200 #FFFFFF00 #FFFF9595 #FFFFBFBF #FF00468C #FFE60000 ]
 [1] 2018/11/22 12:58:25.145 DEBUG | [colorize] Initialized.
 [1] 2018/11/22 12:58:25.145  INFO | Opening virtual DMD...
 [8] 2018/11/22 12:58:25.254 DEBUG | PinDMDv1 device not found.
 [8] 2018/11/22 12:58:25.287 DEBUG | PinDMDv2 device not found.
 [8] 2018/11/22 12:58:25.287 DEBUG | Checking port COM1 for PinDMDv3...
 [8] 2018/11/22 12:58:25.371 DEBUG | Error: Paramètre incorrect.
 [8] 2018/11/22 12:58:25.371 DEBUG | PinDMDv3 device not found.
 [8] 2018/11/22 12:58:25.383 DEBUG | PIN2DMD device not found.
 [8] 2018/11/22 12:58:25.383  INFO | Added VirtualDMD renderer.
 [8] 2018/11/22 12:58:25.383  INFO | Transformation options: Resize=Fit, HFlip=False, VFlip=False
 [8] 2018/11/22 12:58:25.383  INFO | Just clearing palette, colorization is done by converter.
 [8] 2018/11/22 12:58:25.396  INFO | Resizing virtual DMD to 128x32
 [8] 2018/11/22 12:58:25.396  INFO | Setting up 2-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 12:58:25.460  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 12:58:25.460  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 12:58:25.473  INFO | Setting up 4-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 12:58:25.473  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 12:58:25.473  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 12:58:25.473  INFO | Setting up RGB24-bit VPM Graph for 1 destination(s)
 [8] 2018/11/22 12:58:25.473  INFO | Connecting VPM RGB24 Source to Dmd (Rgb24 => Rgb24)
 [8] 2018/11/22 12:58:25.492 ERROR | Value "1.0" for "dotsize" under [virtualdmd] must be a floating number.
 [1] 2018/11/22 13:00:25.020  INFO | [vpm] Close()
 [1] 2018/11/22 13:00:25.020  INFO | Closing up.
 [1] 2018/11/22 13:00:25.020 DEBUG | Disposing 2-bit Colored VPM Graph...
 [1] 2018/11/22 13:00:25.035  INFO | Source for 3 renderer(s) stopped.
 [1] 2018/11/22 13:00:25.035 DEBUG | Disposing 4-bit Colored VPM Graph...
 [1] 2018/11/22 13:00:25.035 DEBUG | Disposing RGB24-bit VPM Graph...
 [1] 2018/11/22 13:00:25.035  INFO | Source for 1 renderer(s) stopped.
 [3] 2018/11/22 13:00:49.552  INFO | [vpm] Open()
 [3] 2018/11/22 13:00:49.552  INFO | [vpm] Set_4_Colors_Palette()
 [3] 2018/11/22 13:00:49.552  INFO | Setting palette to 4 colors...
 [3] 2018/11/22 13:00:49.552  INFO | [vpm] PM_GameSettings(1)
 [3] 2018/11/22 13:00:49.552  INFO | Enabling game colorization
 [3] 2018/11/22 13:00:49.552  INFO | Setting game name: acd_170hc
 [3] 2018/11/22 13:00:49.552  INFO | Setting color: #FFFF5820
 [3] 2018/11/22 13:00:49.552  INFO | Loading palette file at C:\Jeux et programmation flipper\Visual Pinball\VPinMAME\altcolor\acd_170hc\pin2dmd.pal...
 [3] 2018/11/22 13:00:49.552 TRACE | [1] Read version as 1
 [3] 2018/11/22 13:00:49.552 TRACE | [3] Read number of palettes as 15
 [3] 2018/11/22 13:00:49.552 TRACE |   [5] [palette] Read index as 0
 [3] 2018/11/22 13:00:49.552 TRACE |   [7] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.552 TRACE |   [8] [palette] Read type as 2
 [3] 2018/11/22 13:00:49.552 TRACE |   [56] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.567 TRACE |   [58] [palette] Read index as 1
 [3] 2018/11/22 13:00:49.567 TRACE |   [60] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.567 TRACE |   [61] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.567 TRACE |   [109] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.567 TRACE |   [111] [palette] Read index as 2
 [3] 2018/11/22 13:00:49.567 TRACE |   [113] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.567 TRACE |   [114] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.567 TRACE |   [162] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.567 TRACE |   [164] [palette] Read index as 3
 [3] 2018/11/22 13:00:49.567 TRACE |   [166] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.567 TRACE |   [167] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.567 TRACE |   [215] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.567 TRACE |   [217] [palette] Read index as 4
 [3] 2018/11/22 13:00:49.567 TRACE |   [219] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.567 TRACE |   [220] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.582 TRACE |   [268] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.582 TRACE |   [270] [palette] Read index as 5
 [3] 2018/11/22 13:00:49.582 TRACE |   [272] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.582 TRACE |   [273] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.582 TRACE |   [321] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.582 TRACE |   [323] [palette] Read index as 6
 [3] 2018/11/22 13:00:49.582 TRACE |   [325] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.582 TRACE |   [326] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.582 TRACE |   [374] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.582 TRACE |   [376] [palette] Read index as 7
 [3] 2018/11/22 13:00:49.582 TRACE |   [378] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.582 TRACE |   [379] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.582 TRACE |   [427] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.582 TRACE |   [429] [palette] Read index as 8
 [3] 2018/11/22 13:00:49.582 TRACE |   [431] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.582 TRACE |   [432] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.598 TRACE |   [480] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.598 TRACE |   [482] [palette] Read index as 9
 [3] 2018/11/22 13:00:49.598 TRACE |   [484] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.598 TRACE |   [485] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.598 TRACE |   [533] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.598 TRACE |   [535] [palette] Read index as 10
 [3] 2018/11/22 13:00:49.598 TRACE |   [537] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.598 TRACE |   [538] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.598 TRACE |   [586] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.598 TRACE |   [588] [palette] Read index as 11
 [3] 2018/11/22 13:00:49.598 TRACE |   [590] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.598 TRACE |   [591] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.598 TRACE |   [639] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.598 TRACE |   [641] [palette] Read index as 12
 [3] 2018/11/22 13:00:49.598 TRACE |   [643] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.613 TRACE |   [644] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.613 TRACE |   [692] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.613 TRACE |   [694] [palette] Read index as 13
 [3] 2018/11/22 13:00:49.613 TRACE |   [696] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.613 TRACE |   [697] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.613 TRACE |   [745] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.613 TRACE |   [747] [palette] Read index as 14
 [3] 2018/11/22 13:00:49.613 TRACE |   [749] [palette] Read number of colors as 16
 [3] 2018/11/22 13:00:49.613 TRACE |   [750] [palette] Read type as 0
 [3] 2018/11/22 13:00:49.613 TRACE |   [798] [palette] Read 48 bytes of color data
 [3] 2018/11/22 13:00:49.613 TRACE | [800] Read number of mappings as 65535
 [3] 2018/11/22 13:00:49.613  WARN | [65535] Missing 720885 bytes for 65535 masks, ignoring.
 [3] 2018/11/22 13:00:49.613 DEBUG | [colorize] Setting new palette: [ #FF000000 #FF272727 #FFFF8000 #FFFF6A6A #FF6B6B6B #FF005E2F #FFAAD5FF #FFC0C0C0 #FF770000 #FFFFFFFF #FF643200 #FFFFFF00 #FFFF9595 #FFFFBFBF #FF00468C #FFE60000 ]
 [3] 2018/11/22 13:00:49.613 DEBUG | [colorize] Initialized.
 [8] 2018/11/22 13:00:49.629 DEBUG | PinDMDv1 device not found.
 [8] 2018/11/22 13:00:49.629 DEBUG | PinDMDv2 device not found.
 [8] 2018/11/22 13:00:49.629 DEBUG | Checking port COM1 for PinDMDv3...
 [8] 2018/11/22 13:00:49.718 DEBUG | Error: Paramètre incorrect.
 [8] 2018/11/22 13:00:49.718 DEBUG | PinDMDv3 device not found.
 [8] 2018/11/22 13:00:49.743 DEBUG | PIN2DMD device not found.
 [8] 2018/11/22 13:00:49.743  INFO | Added VirtualDMD renderer.
 [8] 2018/11/22 13:00:49.743  INFO | Transformation options: Resize=Fit, HFlip=False, VFlip=False
 [8] 2018/11/22 13:00:49.743  INFO | Just clearing palette, colorization is done by converter.
 [8] 2018/11/22 13:00:49.743  INFO | Resizing virtual DMD to 128x32
 [8] 2018/11/22 13:00:49.754  INFO | Setting up 2-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:00:49.754  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:00:49.754  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:00:49.754  INFO | Setting up 4-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:00:49.754  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:00:49.754  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:00:49.754  INFO | Setting up RGB24-bit VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:00:49.754  INFO | Connecting VPM RGB24 Source to Dmd (Rgb24 => Rgb24)
 [8] 2018/11/22 13:00:49.754 ERROR | Value "1.0" for "dotsize" under [virtualdmd] must be a floating number.
 [3] 2018/11/22 13:01:34.381  INFO | [vpm] Close()
 [3] 2018/11/22 13:01:34.381  INFO | Closing up.
 [3] 2018/11/22 13:01:34.381 DEBUG | Disposing 2-bit Colored VPM Graph...
 [3] 2018/11/22 13:01:34.381  INFO | Source for 3 renderer(s) stopped.
 [3] 2018/11/22 13:01:34.381 DEBUG | Disposing 4-bit Colored VPM Graph...
 [3] 2018/11/22 13:01:34.381 DEBUG | Disposing RGB24-bit VPM Graph...
 [3] 2018/11/22 13:01:34.381  INFO | Source for 1 renderer(s) stopped.
[11] 2018/11/22 13:01:39.118  INFO | [vpm] Open()
[11] 2018/11/22 13:01:39.118  INFO | [vpm] Set_4_Colors_Palette()
[11] 2018/11/22 13:01:39.118  INFO | Setting palette to 4 colors...
[11] 2018/11/22 13:01:39.118  INFO | [vpm] PM_GameSettings(1)
[11] 2018/11/22 13:01:39.118  INFO | Enabling game colorization
[11] 2018/11/22 13:01:39.118  INFO | Setting game name: acd_170hc
[11] 2018/11/22 13:01:39.118  INFO | Setting color: #FFFF5820
[11] 2018/11/22 13:01:39.118  INFO | Loading palette file at C:\Jeux et programmation flipper\Visual Pinball\VPinMAME\altcolor\acd_170hc\pin2dmd.pal...
[11] 2018/11/22 13:01:39.118 TRACE | [1] Read version as 1
[11] 2018/11/22 13:01:39.118 TRACE | [3] Read number of palettes as 15
[11] 2018/11/22 13:01:39.129 TRACE |   [5] [palette] Read index as 0
[11] 2018/11/22 13:01:39.129 TRACE |   [7] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.129 TRACE |   [8] [palette] Read type as 2
[11] 2018/11/22 13:01:39.129 TRACE |   [56] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.129 TRACE |   [58] [palette] Read index as 1
[11] 2018/11/22 13:01:39.129 TRACE |   [60] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.129 TRACE |   [61] [palette] Read type as 0
[11] 2018/11/22 13:01:39.129 TRACE |   [109] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.129 TRACE |   [111] [palette] Read index as 2
[11] 2018/11/22 13:01:39.129 TRACE |   [113] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.129 TRACE |   [114] [palette] Read type as 0
[11] 2018/11/22 13:01:39.129 TRACE |   [162] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.129 TRACE |   [164] [palette] Read index as 3
[11] 2018/11/22 13:01:39.129 TRACE |   [166] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.129 TRACE |   [167] [palette] Read type as 0
[11] 2018/11/22 13:01:39.129 TRACE |   [215] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.145 TRACE |   [217] [palette] Read index as 4
[11] 2018/11/22 13:01:39.145 TRACE |   [219] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.145 TRACE |   [220] [palette] Read type as 0
[11] 2018/11/22 13:01:39.145 TRACE |   [268] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.145 TRACE |   [270] [palette] Read index as 5
[11] 2018/11/22 13:01:39.145 TRACE |   [272] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.145 TRACE |   [273] [palette] Read type as 0
[11] 2018/11/22 13:01:39.145 TRACE |   [321] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.145 TRACE |   [323] [palette] Read index as 6
[11] 2018/11/22 13:01:39.145 TRACE |   [325] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.145 TRACE |   [326] [palette] Read type as 0
[11] 2018/11/22 13:01:39.145 TRACE |   [374] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.145 TRACE |   [376] [palette] Read index as 7
[11] 2018/11/22 13:01:39.145 TRACE |   [378] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.145 TRACE |   [379] [palette] Read type as 0
[11] 2018/11/22 13:01:39.145 TRACE |   [427] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.161 TRACE |   [429] [palette] Read index as 8
[11] 2018/11/22 13:01:39.161 TRACE |   [431] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.161 TRACE |   [432] [palette] Read type as 0
[11] 2018/11/22 13:01:39.161 TRACE |   [480] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.161 TRACE |   [482] [palette] Read index as 9
[11] 2018/11/22 13:01:39.161 TRACE |   [484] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.161 TRACE |   [485] [palette] Read type as 0
[11] 2018/11/22 13:01:39.161 TRACE |   [533] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.161 TRACE |   [535] [palette] Read index as 10
[11] 2018/11/22 13:01:39.161 TRACE |   [537] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.161 TRACE |   [538] [palette] Read type as 0
[11] 2018/11/22 13:01:39.161 TRACE |   [586] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.161 TRACE |   [588] [palette] Read index as 11
[11] 2018/11/22 13:01:39.161 TRACE |   [590] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.161 TRACE |   [591] [palette] Read type as 0
[11] 2018/11/22 13:01:39.176 TRACE |   [639] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.176 TRACE |   [641] [palette] Read index as 12
[11] 2018/11/22 13:01:39.176 TRACE |   [643] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.176 TRACE |   [644] [palette] Read type as 0
[11] 2018/11/22 13:01:39.176 TRACE |   [692] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.176 TRACE |   [694] [palette] Read index as 13
[11] 2018/11/22 13:01:39.176 TRACE |   [696] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.176 TRACE |   [697] [palette] Read type as 0
[11] 2018/11/22 13:01:39.176 TRACE |   [745] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.176 TRACE |   [747] [palette] Read index as 14
[11] 2018/11/22 13:01:39.176 TRACE |   [749] [palette] Read number of colors as 16
[11] 2018/11/22 13:01:39.176 TRACE |   [750] [palette] Read type as 0
[11] 2018/11/22 13:01:39.176 TRACE |   [798] [palette] Read 48 bytes of color data
[11] 2018/11/22 13:01:39.176 TRACE | [800] Read number of mappings as 65535
[11] 2018/11/22 13:01:39.176  WARN | [65535] Missing 720885 bytes for 65535 masks, ignoring.
[11] 2018/11/22 13:01:39.176 DEBUG | [colorize] Setting new palette: [ #FF000000 #FF272727 #FFFF8000 #FFFF6A6A #FF6B6B6B #FF005E2F #FFAAD5FF #FFC0C0C0 #FF770000 #FFFFFFFF #FF643200 #FFFFFF00 #FFFF9595 #FFFFBFBF #FF00468C #FFE60000 ]
[11] 2018/11/22 13:01:39.192 DEBUG | [colorize] Initialized.
[11] 2018/11/22 13:01:39.192 DEBUG | [colorize] Setting new palette: [ #FF000000 #FF272727 #FFFF8000 #FFFF6A6A #FF6B6B6B #FF005E2F #FFAAD5FF #FFC0C0C0 #FF770000 #FFFFFFFF #FF643200 #FFFFFF00 #FFFF9595 #FFFFBFBF #FF00468C #FFE60000 ]
 [8] 2018/11/22 13:01:39.192 DEBUG | PinDMDv1 device not found.
 [8] 2018/11/22 13:01:39.192 DEBUG | PinDMDv2 device not found.
 [8] 2018/11/22 13:01:39.192 DEBUG | Checking port COM1 for PinDMDv3...
 [8] 2018/11/22 13:01:39.283 DEBUG | Error: Paramètre incorrect.
 [8] 2018/11/22 13:01:39.286 DEBUG | PinDMDv3 device not found.
 [8] 2018/11/22 13:01:39.306 DEBUG | PIN2DMD device not found.
 [8] 2018/11/22 13:01:39.306  INFO | Added VirtualDMD renderer.
 [8] 2018/11/22 13:01:39.306  INFO | Transformation options: Resize=Fit, HFlip=False, VFlip=False
 [8] 2018/11/22 13:01:39.306  INFO | Just clearing palette, colorization is done by converter.
 [8] 2018/11/22 13:01:39.306  INFO | Resizing virtual DMD to 128x32
 [8] 2018/11/22 13:01:39.306  INFO | Setting up 2-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:39.306  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:01:39.317  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:01:39.317  INFO | Setting up 4-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:39.317  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:01:39.317  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:01:39.317  INFO | Setting up RGB24-bit VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:39.317  INFO | Connecting VPM RGB24 Source to Dmd (Rgb24 => Rgb24)
 [8] 2018/11/22 13:01:39.317 ERROR | Value "1.0" for "dotsize" under [virtualdmd] must be a floating number.
[11] 2018/11/22 13:01:54.489  INFO | [vpm] Close()
[11] 2018/11/22 13:01:54.489  INFO | Closing up.
[11] 2018/11/22 13:01:54.489 DEBUG | Disposing 2-bit Colored VPM Graph...
[11] 2018/11/22 13:01:54.489  INFO | Source for 3 renderer(s) stopped.
[11] 2018/11/22 13:01:54.489 DEBUG | Disposing 4-bit Colored VPM Graph...
[11] 2018/11/22 13:01:54.489 DEBUG | Disposing RGB24-bit VPM Graph...
[11] 2018/11/22 13:01:54.489  INFO | Source for 1 renderer(s) stopped.
[14] 2018/11/22 13:01:59.255  INFO | [vpm] Open()
[14] 2018/11/22 13:01:59.255  INFO | [vpm] Set_4_Colors_Palette()
[14] 2018/11/22 13:01:59.255  INFO | Setting palette to 4 colors...
[14] 2018/11/22 13:01:59.255  INFO | [vpm] PM_GameSettings(1)
[14] 2018/11/22 13:01:59.255  INFO | Enabling game colorization
[14] 2018/11/22 13:01:59.255  INFO | Setting game name: acd_170hc
[14] 2018/11/22 13:01:59.255  INFO | Setting color: #FFFF5820
[14] 2018/11/22 13:01:59.255  INFO | Loading palette file at C:\Jeux et programmation flipper\Visual Pinball\VPinMAME\altcolor\acd_170hc\pin2dmd.pal...
[14] 2018/11/22 13:01:59.255 TRACE | [1] Read version as 1
[14] 2018/11/22 13:01:59.255 TRACE | [3] Read number of palettes as 15
[14] 2018/11/22 13:01:59.255 TRACE |   [5] [palette] Read index as 0
[14] 2018/11/22 13:01:59.255 TRACE |   [7] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.270 TRACE |   [8] [palette] Read type as 2
[14] 2018/11/22 13:01:59.270 TRACE |   [56] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.270 TRACE |   [58] [palette] Read index as 1
[14] 2018/11/22 13:01:59.270 TRACE |   [60] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.270 TRACE |   [61] [palette] Read type as 0
[14] 2018/11/22 13:01:59.270 TRACE |   [109] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.270 TRACE |   [111] [palette] Read index as 2
[14] 2018/11/22 13:01:59.270 TRACE |   [113] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.270 TRACE |   [114] [palette] Read type as 0
[14] 2018/11/22 13:01:59.270 TRACE |   [162] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.270 TRACE |   [164] [palette] Read index as 3
[14] 2018/11/22 13:01:59.270 TRACE |   [166] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.270 TRACE |   [167] [palette] Read type as 0
[14] 2018/11/22 13:01:59.270 TRACE |   [215] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.285 TRACE |   [217] [palette] Read index as 4
[14] 2018/11/22 13:01:59.285 TRACE |   [219] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.285 TRACE |   [220] [palette] Read type as 0
[14] 2018/11/22 13:01:59.285 TRACE |   [268] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.285 TRACE |   [270] [palette] Read index as 5
[14] 2018/11/22 13:01:59.285 TRACE |   [272] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.285 TRACE |   [273] [palette] Read type as 0
[14] 2018/11/22 13:01:59.285 TRACE |   [321] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.285 TRACE |   [323] [palette] Read index as 6
[14] 2018/11/22 13:01:59.285 TRACE |   [325] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.285 TRACE |   [326] [palette] Read type as 0
[14] 2018/11/22 13:01:59.285 TRACE |   [374] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.285 TRACE |   [376] [palette] Read index as 7
[14] 2018/11/22 13:01:59.285 TRACE |   [378] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.285 TRACE |   [379] [palette] Read type as 0
[14] 2018/11/22 13:01:59.285 TRACE |   [427] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.285 TRACE |   [429] [palette] Read index as 8
[14] 2018/11/22 13:01:59.301 TRACE |   [431] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.301 TRACE |   [432] [palette] Read type as 0
[14] 2018/11/22 13:01:59.301 TRACE |   [480] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.301 TRACE |   [482] [palette] Read index as 9
[14] 2018/11/22 13:01:59.301 TRACE |   [484] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.301 TRACE |   [485] [palette] Read type as 0
[14] 2018/11/22 13:01:59.301 TRACE |   [533] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.301 TRACE |   [535] [palette] Read index as 10
[14] 2018/11/22 13:01:59.301 TRACE |   [537] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.301 TRACE |   [538] [palette] Read type as 0
[14] 2018/11/22 13:01:59.301 TRACE |   [586] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.301 TRACE |   [588] [palette] Read index as 11
[14] 2018/11/22 13:01:59.301 TRACE |   [590] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.301 TRACE |   [591] [palette] Read type as 0
[14] 2018/11/22 13:01:59.301 TRACE |   [639] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.301 TRACE |   [641] [palette] Read index as 12
[14] 2018/11/22 13:01:59.317 TRACE |   [643] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.317 TRACE |   [644] [palette] Read type as 0
[14] 2018/11/22 13:01:59.317 TRACE |   [692] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.317 TRACE |   [694] [palette] Read index as 13
[14] 2018/11/22 13:01:59.317 TRACE |   [696] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.317 TRACE |   [697] [palette] Read type as 0
[14] 2018/11/22 13:01:59.317 TRACE |   [745] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.317 TRACE |   [747] [palette] Read index as 14
[14] 2018/11/22 13:01:59.317 TRACE |   [749] [palette] Read number of colors as 16
[14] 2018/11/22 13:01:59.317 TRACE |   [750] [palette] Read type as 0
[14] 2018/11/22 13:01:59.317 TRACE |   [798] [palette] Read 48 bytes of color data
[14] 2018/11/22 13:01:59.317 TRACE | [800] Read number of mappings as 65535
[14] 2018/11/22 13:01:59.317  WARN | [65535] Missing 720885 bytes for 65535 masks, ignoring.
[14] 2018/11/22 13:01:59.317 DEBUG | [colorize] Setting new palette: [ #FF000000 #FF272727 #FFFF8000 #FFFF6A6A #FF6B6B6B #FF005E2F #FFAAD5FF #FFC0C0C0 #FF770000 #FFFFFFFF #FF643200 #FFFFFF00 #FFFF9595 #FFFFBFBF #FF00468C #FFE60000 ]
[14] 2018/11/22 13:01:59.317 DEBUG | [colorize] Initialized.
[14] 2018/11/22 13:01:59.333 DEBUG | [colorize] Initialized.
 [8] 2018/11/22 13:01:59.333 DEBUG | PinDMDv1 device not found.
 [8] 2018/11/22 13:01:59.333 DEBUG | PinDMDv2 device not found.
 [8] 2018/11/22 13:01:59.333 DEBUG | Checking port COM1 for PinDMDv3...
 [8] 2018/11/22 13:01:59.422 DEBUG | Error: Paramètre incorrect.
 [8] 2018/11/22 13:01:59.422 DEBUG | PinDMDv3 device not found.
 [8] 2018/11/22 13:01:59.446 DEBUG | PIN2DMD device not found.
 [8] 2018/11/22 13:01:59.446  INFO | Added VirtualDMD renderer.
 [8] 2018/11/22 13:01:59.446  INFO | Transformation options: Resize=Fit, HFlip=False, VFlip=False
 [8] 2018/11/22 13:01:59.446  INFO | Just clearing palette, colorization is done by converter.
 [8] 2018/11/22 13:01:59.458  INFO | Resizing virtual DMD to 128x32
 [8] 2018/11/22 13:01:59.458  INFO | Setting up 2-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:59.458  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:01:59.458  INFO | Connecting 2 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:01:59.458  INFO | Setting up 4-bit Colored VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:59.458  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray2 => Rgb24)
 [8] 2018/11/22 13:01:59.458  INFO | Connecting 4 Bit Colorizer to Dmd (ColoredGray4 => Rgb24)
 [8] 2018/11/22 13:01:59.473  INFO | Setting up RGB24-bit VPM Graph for 1 destination(s)
 [8] 2018/11/22 13:01:59.473  INFO | Connecting VPM RGB24 Source to Dmd (Rgb24 => Rgb24)
 [8] 2018/11/22 13:01:59.473 ERROR | Value "1.0" for "dotsize" under [virtualdmd] must be a floating number.
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptySam 24 Nov 2018 - 13:07
Euh il existe le bouton Code pour intégrer un Code donc [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 773715342 [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 773715342 je fais le ménage [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 3253257302
Donc déjà supprime tes dmddevice du syswow64 , ensuite modifie ton dmddevice en mettant false à tout les pindmd
djtete
djtete
Département : 85710
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptySam 24 Nov 2018 - 15:16
Bon du coup j'ai tout mis sur false les tables qui on un souci demarre mais après plante vpx.
Par contre celle d'ac\dc fonctionne.
Code:
[pindmd1]
enabled = false
[pindmd2]
enabled = false
[pindmd3]
enabled = false
port =
[pin2dmd]
enabled = false
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 25 Nov 2018 - 12:18
As tu débloqué dmd-ext.exe et les dll ?
djtete
djtete
Département : 85710
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 25 Nov 2018 - 20:17
comment les débloquer stp
Et j'ai vu qu'il y avait un dossier dmdext dans visual pinball faut t'il que je mets les fichiers dans ce dossier ?
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 26 Nov 2018 - 9:02
Clic droit -> propriétés et normalement en bas tu as débloquer [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 3253257302
djtete
djtete
Département : 85710
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 26 Nov 2018 - 10:23
Salut peskopat moi je n'ai rien de tout ça
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 26 Nov 2018 - 10:40
Donc c'est débloqué , et les dll c'est débloqué ou pas ?
djtete
djtete
Département : 85710
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 26 Nov 2018 - 10:57
oui et ce qui est bizzard c'est que quand je lance la table jurasik park je vois bien la rom coloriser je peux mettre des crédits mais dès que j’appuie sur start la table se fige et plante et j'ai ensuite le message d'erreur visual pinball a cessé de fonctionner.
possibilité de ce rejoindre sur le chat ?
MAXxXAM
MAXxXAM
Département : 27
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptySam 2 Fév 2019 - 0:28
salut à tous
j'ai récupéré le pack color complet et suivi le tuto pour tester sur ACDC avec la rom acd_170hc
 et ça plante à chaque fois dans le script en me mettant "game not found" malgré le fait d'avoir mis cGameName = "acd_170hc"
j'ai pourtant créé le dossier "altcolor" dans vpinmame, créé le dossier "ACD_170hc" et mis le fichier pin2dmd.pal qui va bien
j'ai surement loupé un truc....
please help
ocbbomb
Département : 45
MessageSujet: Bizarre   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 24 Mar 2019 - 4:01
bonjour j'ai suivi ce tuto et tout fonctionne ou presque !j'ai le même problème mon dmd reste sur le playfield  je relève les valeurs de setdmd je les rapportes dans le fichier dmddevice.ini je fais un test avec vpinmame tout est ok  .je lance vpx et la plus de dmd ...... je cherche et je me rend compte qu'il est pas du tout au bonne endroit !? ma question pourquoi? alors que les valeurs  de set dmd marche pour les roms monochrome et avec vpinmame c au bonne endroit (rom color) .Voila ma détresse la flemme de taper des chiffres au hasard pour arrivé a le placer  correctement si quelqu'un a une solution merci d'avance
http://cqfd-online.com/
MAXxXAM
MAXxXAM
Département : 27
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 24 Mar 2019 - 9:09
Salut
J’ai le problème aussi, moi c’est parce que j’avais 2 fichiers dmddevice.ini dans VPX un dans dmdext et un dans vpinmame, donc 1 de trop, et forcément, c’etait Le mauvais que je modifiais
Donc regardes si tu n’as plusieurs fichiers demddevice
ocbbomb
Département : 45
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 24 Mar 2019 - 13:34
[Vous devez être inscrit et connecté pour voir ce lien] merci pour ta réponse mais oui j'avais déjà vérifier ce point.les valeurs sont bonne pour vpinmame mais pas pour vpx bizarre quand meme
message edité
nicofab18
nicofab18
Département : 18
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 24 Mar 2019 - 14:03
évites de citer le message précédent, si tu veux répondre à quelqu'un en particulier, utilises @ devant le pseudo.
c'est expliqué dans le fonctionnement du forum. merci de ta comprehesion
ocbbomb
Département : 45
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyDim 24 Mar 2019 - 14:12
[Vous devez être inscrit et connecté pour voir ce lien] ok pas de problème j'ai pas relus les conditions depuis longtemps jy vais de ce pas
ps:Alors j'ai trouvé le probleme la prise a distance fais changé l'ordre de mes ecrans donc c le bordel Smile fais a la source du pincab tout est ok
merci all
Snapouille
Snapouille
Département : 83
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 8 Avr 2019 - 23:22
@[Vous devez être inscrit et connecté pour voir ce lien]  merci pour ce tuto
J'ai tout suivi à la lettre ainsi que le tread pour voir les différents problèmes rencontrés mais je n'ai pas trouvé le mien ou je bloque.
Quand je lance le setup.exe de VpinMame, je test la rom colorisé et elle s'affiche très bien.
Par contre quand je lance la table j'ai juste la rom standard en orange .
(Petites précisions "Colorize DMD" et "Use external DMD" sont bien cochés. Dans le script de la table la ligne "Const cGameName" indique bien la rom colorisé que je test avec le setup de VpinMame)
Auriez-vous des pistes concernant mon problème ? Merci
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 8 Avr 2019 - 23:27
[Vous devez être inscrit et connecté pour voir ce lien], tu utilises bien le dmddevice.dll 1.7.1 de freezy ?
Édit : et as-tu décoché « show dmd display ? Peut être que le dmd color est masqué par l’autre ?
Snapouille
Snapouille
Département : 83
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 8 Avr 2019 - 23:40
[Vous devez être inscrit et connecté pour voir ce lien] oui j'utilise bien le bien le dmddevice.dll 1.7.1 de freezy.
J'ai bien décoché show dmd display et c'est bien l'external dmd qui est affiché, j'ai fait le test en laissant les deux DMD affichés mais les deux sont juste orange.
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyLun 8 Avr 2019 - 23:43
Et tu as bien créé le dossier altcolor dans VPinMAME pour y mettre les palettes de tes tables ?
Snapouille
Snapouille
Département : 83
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 6:45
J'ai bien le répertoire altcolor dans VPinMAME avec le dossier qui porte le nom de la rom et les fichiers *.pal et *.vni à l'intérieur.
Sinon je ne pense pas que je pourrais voir la rom couleur quand je lance VpinMame.
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 8:07
[Vous devez être inscrit et connecté pour voir ce lien], oui tout à fait, j’avais fait abstraction de cette info [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 1502191233
Alors ça fonctionne avec le setup mais pas en lançant la table, étrange ...
Tu as installé la dernière version de vpx 10.6 bêta ?
 Tu as le problème pour toutes les tables ?
Snapouille
Snapouille
Département : 83
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 17:27
J'ai testé trois tables :
- Monster Bash (mb_106b)
- Medieval Madness (mm_109c)
- Terminator 2 (t2_l8)
Les trois se lancent avec les couleurs sur VpinMame mais aucune dans VPX.
Je suis sur VPX 10.6.0 et VPinMame 3.2
Je vois bien la fenêtre du DMD externe sans soucis, sauf qu'il n'y a pas les couleurs.
J'ai décoché le DMD interne, re-coché pour voir les 2 même temps, mais rien n'y change.
Je viens de tester une 4ème table avec World Cup Soccer, même constat Sad
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 18:19
Oui désolé j’ai supprimé mon précédent message car inutile on a dû se croiser ...
EDIT  [Vous devez être inscrit et connecté pour voir ce lien], vérifies dans le fichier DmdDevice.ini qui se trouve dans le dossier vpinmameque l'option colorize est bien =true ?
Si elle est sur false, tu modifie en true tu redémarre le pincab (perso je suis obligé de redémarrer lorsque je modifie cette option sinon vpx plante au lancement d'une table rom color ...)
Snapouille
Snapouille
Département : 83
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 18:41
oui oui colorize = true
MessageSujet: Re: [TUTO] roms colorisées Stern sur LCD et Pin2DMD   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 EmptyMar 9 Avr 2019 - 18:47
Bon ... si avec le setup de vpinmame ça fonctionne mais lorsque la table est lancée ya pu couleur, c'est que le soucis vient plutôt de vpx ?.... scratch
Je suppose que oui, mais est-ce que tu as la dernière version de 10.6 bêta avec les scripts vbs, exe en administrateur et dll débloquées, etc ? ...
EDIT  ah je viens de voir que tu l'avais déjà précisé plus haut, je m'y perds  !!  boum   [TUTO] roms colorisées Stern sur LCD et Pin2DMD - Page 4 722859262
Page 4 sur 6Aller à la page : Précédent  1, 2, 3, 4, 5, 6  Suivant
» [TUTO] Mod Color ROMs pour PIN2DMD
» [PIN2DMD] Tutos/Mods/Dumps de Roms
» [RÉSOLU] Pb affichage roms colorisées depuis upgrade Nucléo
» [TUTO VPM] Configuration et test des ROMs VPM
