 [TUTO] Installer PROC et la table evil dead
naaco
Suby
chris62700
MAXxXAM
ilveropaolone
Bluetooth
Stéphanas
jphil82
DamsBALL
snwfrd38
bruce8374
kakou
Carny_Priest
moviemaniac52
firebrand007
jeyspeed
khomodo
horsepin
garath
kwak
32 participants
Aller à la page : Précédent  1 ... 6 ... 8, 9, 10 ... 16 ... 23  Suivant
Département : Paris et RP
[TUTO] Installer PROC et la table evil dead - Page 9 Empty
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:03
horsepin a écrit:
Don't feel obliged to.... but anything you may spot whilst playing, and if you remember about it.
Doesn't matter if it's a small problem, it makes it easier to fix and come back to.
I have trouble remembering things while playing, it sucks me into the game as well.
Do your profiles work? Is it saving correct times?
EvilDead\config\profiles\yourname.yaml
"Total Game Time"  .... This one I worry about in France maybe. You should have a time format like 00:12:00
hello, just installed your wonderful table. had some issues configuring p-roc but with the tuto here, finally made it worked. MASTERPIECE ! However just got an error after few seconds playing
am i missing something ?
edit oh forget it can t be able to get this bug again for the moment
one question though when i quit the table the dmd still lives i have to quit pinballx to kill it anyway for it to close with the table (controller.stop in the script ?)
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:05
shadow_shd a écrit:
Well, I must be silly, but I can't seem to find the right key to save my profile's name : I enter S H A D O W, then I put the cursor on =, I validate by pressing the 1 key, I can hear Thank you, but my profile isn't saved scratch
shadow une fois que tu as cree un profil il faut faire un load pour qu il apparaisse  [Vous devez être inscrit et connecté pour voir cette image]
edit: euh je viens de me rendre compte j ecris avec le profil de namsan mais c est khomodo la, ses loggings ont du rester sur le pincab et je n ai pas fait attention en me connectant au forum  [Vous devez être inscrit et connecté pour voir cette image]
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:11
shadow_shd a écrit:
Our founding administrator is Bip-Bip Wink
I write SHADOW, and the only way I found to save my profile is to press the 0 button, but that puts the game in settings mode lol!
I'll try again Smile
Citer, thanks. I created a profile called SHADOW it was ok.
Did you have the name PLAYER 1 when you started the game?
If you did I think maybe you didn't GiT PULL ?
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:16
Nevermind I managed to create my profile Chepas - once in the settings menu of the game, I pressed the B key to add a ball, and I could play Wink
Here it is :
At the end of the game, after I've lost the third ball, I did get this error :
The log :
Code:
2016-02-20 17:09:12,918 - vpcom - INFO - Traceback (most recent call last):
2016-02-20 17:09:12,918 - vpcom - INFO -   File "c:\P-ROC\tools\register_vpcom.py", line 286, in RunGame
2016-02-20 17:09:12,918 - vpcom - INFO -     self.game.run_loop()
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 956, in run_loop
2016-02-20 17:09:12,920 - vpcom - INFO -     super(SkeletonGame, self).run_loop(min_seconds_per_cycle)
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\game\game.py", line 721, in run_loop
2016-02-20 17:09:12,920 - vpcom - INFO -     self.process_event(event)
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\game\game.py", line 593, in process_event
2016-02-20 17:09:12,920 - vpcom - INFO -     self.dmd_event()
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 908, in dmd_event
2016-02-20 17:09:12,920 - vpcom - INFO -     self.dmd.update()
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\displaycontroller.py", line 77, in update
2016-02-20 17:09:12,920 - vpcom - INFO -     layer.composite_next(self.frame)
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\dmd.py", line 412, in composite_next
2016-02-20 17:09:12,920 - vpcom - INFO -     src = self.next_frame()
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 765, in next_frame
2016-02-20 17:09:12,920 - vpcom - INFO -     frame = layer.composite_next(self.buffer)
2016-02-20 17:09:12,920 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 663, in next_frame
2016-02-20 17:09:12,920 - vpcom - INFO -     layer.composite_next(self.buffer)
2016-02-20 17:09:12,921 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\transitionlayer.py", line 132, in next_frame
2016-02-20 17:09:12,921 - vpcom - INFO -     f = self.transitionMgr.next_frame(self.layer_A_wrapped.next_frame(),self.layer_B_wrapped.next_frame())
2016-02-20 17:09:12,921 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 54, in next_frame
2016-02-20 17:09:12,921 - vpcom - INFO -     return self.transition_frame(from_frame=from_frame, to_frame=to_frame)
2016-02-20 17:09:12,921 - vpcom - INFO -   File "c:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 273, in transition_frame
2016-02-20 17:09:12,921 - vpcom - INFO -     frame = from_frame.copy()
2016-02-20 17:09:12,921 - vpcom - INFO - AttributeError: 'NoneType' object has no attribute 'copy'
Thank you again mister Wink
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:18
There is a controller.stop but it was commented out, yes you can use that still but when VP closes, it will close proc as well.
That is weird to get that error early in the game.....it can give that randomly if build up of memory maybe, you would have to tell me where it happened. Theres also a log in p-roc/shared/log.txt
 I fixed an issue similar earlier but that was at the same point in the game, not early on.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:22
Both randomly at 273 ? Sure you have the latest master GIT?
273 crashing there means nothing to me. To fix the shed I had to look at the screen and what was happening at the time of crash.
From that point I could trace it......if you see the log you will see the current modes running before crash.
Spoiler:
You should not have any errors so early in game. If you open command prompt in game folder and type GIT PULL.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:26
One thing I can think of maybe is to search your folder for .pyc as well and delete all these.
These are compiled python and they are built when game is run. It may help.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:40
Python print statements can cause random things like this. I had a file not commited. Hope that is it!.
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:50
I downloaded this file Chepas : [Vous devez être inscrit et connecté pour voir ce lien]
I also deleted all the pyc file.
I'll try with the dc3dd07 commit Wink
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 17:58
Cheers, it's the one I'm using, it should be fine.
If you get problem with backglass I can see now its using a different name, for what reason?
B2SController.B2SName=("EvilDead")
PinballX should take care of this though from xml.
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:06
just got the same error again, frame copy on dmd, was gotten an ash letter and was in bridge mode
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:13
here is the log
Code:
2016-02-20 17:59:51,091 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:51,091 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:51,091 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:51,346 - game - INFO - rightReturn:   open     (2)
2016-02-20 17:59:51,346 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D907E70>'; will search in 10s.
2016-02-20 17:59:52,122 - game - INFO - flipperLwR:   closed   (1)
2016-02-20 17:59:52,122 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D996050>'
2016-02-20 17:59:52,405 - game - INFO - leftRamp:   closed   (1)
2016-02-20 17:59:52,434 - game - INFO - leftRamp:   open     (2)
2016-02-20 17:59:52,434 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 17:59:52,940 - game - INFO - flipperLwR:   open     (2)
2016-02-20 17:59:52,957 - game - INFO - leftRampFull:   closed   (1)
2016-02-20 17:59:52,959 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:52,959 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 17:59:52,960 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 17:59:52,960 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 17:59:52,960 - game.modes - INFO -  99  Tilt          -
2016-02-20 17:59:52,960 - game.modes - INFO -  90  Trough        -
2016-02-20 17:59:52,960 - game.modes - INFO -  21  ModeTimeLayer  GroupedLayer
2016-02-20 17:59:52,960 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 17:59:52,960 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 17:59:52,960 - game.modes - INFO -  8    BallSearch    -
2016-02-20 17:59:52,961 - game.modes - INFO -  7    LeftRamp      GroupedLayer
2016-02-20 17:59:52,961 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 17:59:52,961 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 17:59:52,961 - game.modes - INFO -  6    Cards          -
2016-02-20 17:59:52,961 - game.modes - INFO -  6    Workshed      -
2016-02-20 17:59:52,961 - game.modes - INFO -  5    AshRollover    -
2016-02-20 17:59:52,961 - game.modes - INFO -  5    Targets        -
2016-02-20 17:59:52,961 - game.modes - INFO -  5    Pages          GroupedLayer
2016-02-20 17:59:52,961 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 17:59:52,961 - game.modes - INFO -  4    ModeInfo      -
2016-02-20 17:59:52,961 - game.modes - INFO -  3    BallSave      -
2016-02-20 17:59:52,961 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 17:59:52,961 - game.modes - INFO -  3    LampShowMode  -
2016-02-20 17:59:52,961 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:52,961 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:52,961 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:53,003 - game - INFO - leftRampFull:   open     (2)
2016-02-20 17:59:53,003 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D996330>'; will search in 10s.
2016-02-20 17:59:53,994 - game - INFO - rightReturn:   closed   (1)
2016-02-20 17:59:53,996 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:53,996 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 17:59:54,003 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 17:59:54,003 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 17:59:54,003 - game.modes - INFO -  99  Tilt          -
2016-02-20 17:59:54,003 - game.modes - INFO -  90  Trough        -
2016-02-20 17:59:54,003 - game.modes - INFO -  21  ModeTimeLayer  GroupedLayer
2016-02-20 17:59:54,003 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 17:59:54,003 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 17:59:54,003 - game.modes - INFO -  8    BallSearch    -
2016-02-20 17:59:54,003 - game.modes - INFO -  7    LeftRamp      GroupedLayer
2016-02-20 17:59:54,003 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 17:59:54,003 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 17:59:54,003 - game.modes - INFO -  6    Cards          -
2016-02-20 17:59:54,003 - game.modes - INFO -  6    Workshed      -
2016-02-20 17:59:54,003 - game.modes - INFO -  5    AshRollover    -
2016-02-20 17:59:54,003 - game.modes - INFO -  5    Targets        -
2016-02-20 17:59:54,003 - game.modes - INFO -  5    Pages          GroupedLayer
2016-02-20 17:59:54,003 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 17:59:54,003 - game.modes - INFO -  4    ModeInfo      -
2016-02-20 17:59:54,003 - game.modes - INFO -  3    BallSave      -
2016-02-20 17:59:54,003 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 17:59:54,003 - game.modes - INFO -  3    LampShowMode  -
2016-02-20 17:59:54,003 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:54,003 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:54,003 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:54,255 - game - INFO - rightReturn:   open     (2)
2016-02-20 17:59:54,255 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D907E70>'; will search in 10s.
2016-02-20 17:59:55,051 - game - INFO - flipperLwR:   closed   (1)
2016-02-20 17:59:55,051 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D996050>'
2016-02-20 17:59:55,331 - game - INFO - leftRamp:   closed   (1)
2016-02-20 17:59:55,345 - game - INFO - leftRamp:   open     (2)
2016-02-20 17:59:55,346 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 17:59:55,763 - game - INFO - flipperLwR:   open     (2)
2016-02-20 17:59:55,809 - game - INFO - leftRampFull:   closed   (1)
2016-02-20 17:59:55,809 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:55,811 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 17:59:55,812 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 17:59:55,812 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 17:59:55,812 - game.modes - INFO -  99  Tilt          -
2016-02-20 17:59:55,812 - game.modes - INFO -  90  Trough        -
2016-02-20 17:59:55,812 - game.modes - INFO -  21  ModeTimeLayer  GroupedLayer
2016-02-20 17:59:55,812 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 17:59:55,812 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 17:59:55,812 - game.modes - INFO -  8    BallSearch    -
2016-02-20 17:59:55,812 - game.modes - INFO -  7    LeftRamp      GroupedLayer
2016-02-20 17:59:55,812 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 17:59:55,812 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 17:59:55,812 - game.modes - INFO -  6    Cards          -
2016-02-20 17:59:55,812 - game.modes - INFO -  6    Workshed      -
2016-02-20 17:59:55,812 - game.modes - INFO -  5    AshRollover    -
2016-02-20 17:59:55,812 - game.modes - INFO -  5    Targets        -
2016-02-20 17:59:55,813 - game.modes - INFO -  5    Pages          GroupedLayer
2016-02-20 17:59:55,813 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 17:59:55,813 - game.modes - INFO -  4    ModeInfo      -
2016-02-20 17:59:55,813 - game.modes - INFO -  3    BallSave      -
2016-02-20 17:59:55,813 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 17:59:55,813 - game.modes - INFO -  3    LampShowMode  -
2016-02-20 17:59:55,813 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:55,813 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:55,813 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:55,838 - game - INFO - leftRampFull:   open     (2)
2016-02-20 17:59:55,839 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D996330>'; will search in 10s.
2016-02-20 17:59:56,812 - game - INFO - rightReturn:   closed   (1)
2016-02-20 17:59:56,813 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:56,813 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 17:59:56,815 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 17:59:56,815 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 17:59:56,815 - game.modes - INFO -  99  Tilt          -
2016-02-20 17:59:56,815 - game.modes - INFO -  90  Trough        -
2016-02-20 17:59:56,815 - game.modes - INFO -  21  ModeTimeLayer  GroupedLayer
2016-02-20 17:59:56,815 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 17:59:56,815 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 17:59:56,815 - game.modes - INFO -  8    BallSearch    -
2016-02-20 17:59:56,815 - game.modes - INFO -  7    LeftRamp      GroupedLayer
2016-02-20 17:59:56,816 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 17:59:56,816 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 17:59:56,816 - game.modes - INFO -  6    Cards          -
2016-02-20 17:59:56,816 - game.modes - INFO -  6    Workshed      -
2016-02-20 17:59:56,816 - game.modes - INFO -  5    AshRollover    -
2016-02-20 17:59:56,816 - game.modes - INFO -  5    Targets        -
2016-02-20 17:59:56,816 - game.modes - INFO -  5    Pages          GroupedLayer
2016-02-20 17:59:56,816 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 17:59:56,816 - game.modes - INFO -  4    ModeInfo      -
2016-02-20 17:59:56,816 - game.modes - INFO -  3    BallSave      -
2016-02-20 17:59:56,816 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 17:59:56,816 - game.modes - INFO -  3    LampShowMode  -
2016-02-20 17:59:56,816 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:56,816 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:56,816 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:57,078 - game - INFO - rightReturn:   open     (2)
2016-02-20 17:59:57,078 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D907E70>'; will search in 10s.
2016-02-20 17:59:57,829 - game - INFO - flipperLwR:   closed   (1)
2016-02-20 17:59:57,829 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D996050>'
2016-02-20 17:59:58,164 - game - INFO - bumperL:   closed   (1)
2016-02-20 17:59:58,210 - game - INFO - bumperL:   open     (2)
2016-02-20 17:59:58,210 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 17:59:58,246 - game - INFO - bumperR:   closed   (1)
2016-02-20 17:59:58,292 - game - INFO - bumperR:   open     (2)
2016-02-20 17:59:58,292 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 17:59:58,526 - game - INFO - topRolloverL:   closed   (1)
2016-02-20 17:59:58,549 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:58,549 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 17:59:58,549 - root - INFO - Pages mode start Saved Bonus:
2016-02-20 17:59:58,549 - root - INFO - 5000000
2016-02-20 17:59:58,549 - game.modes - INFO - Added DisplayModeEndings  pri=22.
2016-02-20 17:59:58,572 - game.modes - INFO - Removed Pages  pri=5.
2016-02-20 17:59:58,575 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 17:59:58,576 - game - INFO - isDeadByDawnReady = False
2016-02-20 17:59:58,576 - game.modes - INFO - Removed ModeTimeLayer  pri=21.
2016-02-20 17:59:58,576 - game.modes - INFO - Removed DisplayModeEndings  pri=22.
2016-02-20 17:59:58,576 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 17:59:58,578 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 17:59:58,578 - game.modes - INFO -  99  Tilt          -
2016-02-20 17:59:58,578 - game.modes - INFO -  90  Trough        -
2016-02-20 17:59:58,578 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 17:59:58,578 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 17:59:58,578 - game.modes - INFO -  8    BallSearch    -
2016-02-20 17:59:58,578 - game.modes - INFO -  7    LeftRamp      -
2016-02-20 17:59:58,578 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 17:59:58,578 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 17:59:58,578 - game.modes - INFO -  6    Cards          -
2016-02-20 17:59:58,578 - game.modes - INFO -  6    Workshed      -
2016-02-20 17:59:58,578 - game.modes - INFO -  5    AshRollover    TransitionLayer
2016-02-20 17:59:58,578 - game.modes - INFO -  5    Targets        -
2016-02-20 17:59:58,578 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 17:59:58,578 - game.modes - INFO -  4    ModeInfo      ScriptlessLayer
2016-02-20 17:59:58,578 - game.modes - INFO -  3    BallSave      -
2016-02-20 17:59:58,578 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 17:59:58,578 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 17:59:58,578 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 17:59:58,578 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 17:59:58,605 - game - INFO - topRolloverL:   open     (2)
2016-02-20 17:59:58,605 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 17:59:58,671 - game - INFO - flipperLwR:   open     (2)
2016-02-20 18:00:00,724 - game - INFO - topRolloverR:   closed   (1)
2016-02-20 18:00:00,736 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:00:00,737 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:00:00,737 - game.modes - INFO -  100  TrophyMode    -
2016-02-20 18:00:00,737 - game.modes - INFO -  99  Tilt          -
2016-02-20 18:00:00,739 - game.modes - INFO -  90  Trough        -
2016-02-20 18:00:00,739 - game.modes - INFO -  15  Shelly        GroupedLayer
2016-02-20 18:00:00,739 - game.modes - INFO -  12  DMDHelper      -
2016-02-20 18:00:00,739 - game.modes - INFO -  8    BallSearch    -
2016-02-20 18:00:00,739 - game.modes - INFO -  7    LeftRamp      -
2016-02-20 18:00:00,739 - game.modes - INFO -  7    CellarRamp    -
2016-02-20 18:00:00,739 - game.modes - INFO -  6    Bumpers        GroupedLayer
2016-02-20 18:00:00,739 - game.modes - INFO -  6    Cards          -
2016-02-20 18:00:00,739 - game.modes - INFO -  6    Workshed      -
2016-02-20 18:00:00,739 - game.modes - INFO -  5    AshRollover    TransitionLayer
2016-02-20 18:00:00,739 - game.modes - INFO -  5    Targets        -
2016-02-20 18:00:00,739 - game.modes - INFO -  4    SpellEvilDead  -
2016-02-20 18:00:00,739 - game.modes - INFO -  4    ModeInfo      ScriptlessLayer
2016-02-20 18:00:00,739 - game.modes - INFO -  3    BallSave      -
2016-02-20 18:00:00,739 - game.modes - INFO -  3    BaseGameMode  -
2016-02-20 18:00:00,739 - game.modes - INFO -  3    LampShowMode  -
2016-02-20 18:00:00,739 - game.modes - INFO -  2    SwitchMonitor  -
2016-02-20 18:00:00,739 - game.modes - INFO -  1    OSC_Mode      -
2016-02-20 18:00:00,739 - game.modes - INFO -  0    ScoreDisplay  ScoreLayer
2016-02-20 18:00:00,974 - game - INFO - topRolloverR:   open     (2)
2016-02-20 18:00:00,974 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D996550>'; will search in 10s.
2016-02-20 18:00:01,285 - game - INFO -
Total Time: 622.707 Seconds
2016-02-20 18:00:01,285 - game - INFO - Loops: 3734969
2016-02-20 18:00:01,285 - game - INFO - Overall loop rate: 6056.526Hz
2016-02-20 18:00:01,285 - game - INFO - Frame rate: 23.981FPS
2016-02-20 18:00:01,285 - game - INFO - DMD Updates: 14789
2016-02-20 18:00:01,285 - game - INFO - loops between dmd updates: 252.000
2016-02-20 18:00:01,285 - game - INFO - Waiting for the OSC Server thread to finish
2016-02-20 18:00:01,285 - game - INFO - OSC Server thread is done.
2016-02-20 18:00:01,289 - vpcom - INFO - PYTHON FAILURE (Visual Pinball Bridge is now broken)
2016-02-20 18:00:01,289 - vpcom - INFO - Exception Name AttributeError: 'NoneType' object has no attribute 'copy'
2016-02-20 18:00:01,289 - vpcom - INFO - Traceback (most recent call last):
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\tools\register_vpcom.py", line 286, in RunGame
2016-02-20 18:00:01,289 - vpcom - INFO -    self.game.run_loop()
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 956, in run_loop
2016-02-20 18:00:01,289 - vpcom - INFO -    super(SkeletonGame, self).run_loop(min_seconds_per_cycle)
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\game\game.py", line 721, in run_loop
2016-02-20 18:00:01,289 - vpcom - INFO -    self.process_event(event)
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\game\game.py", line 593, in process_event
2016-02-20 18:00:01,289 - vpcom - INFO -    self.dmd_event()
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 908, in dmd_event
2016-02-20 18:00:01,289 - vpcom - INFO -    self.dmd.update()
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\displaycontroller.py", line 77, in update
2016-02-20 18:00:01,289 - vpcom - INFO -    layer.composite_next(self.frame)
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\dmd.py", line 412, in composite_next
2016-02-20 18:00:01,289 - vpcom - INFO -    src = self.next_frame()
2016-02-20 18:00:01,289 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 765, in next_frame
2016-02-20 18:00:01,289 - vpcom - INFO -    frame = layer.composite_next(self.buffer)
2016-02-20 18:00:01,290 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\dmd.py", line 412, in composite_next
2016-02-20 18:00:01,290 - vpcom - INFO -    src = self.next_frame()
2016-02-20 18:00:01,290 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 663, in next_frame
2016-02-20 18:00:01,290 - vpcom - INFO -    layer.composite_next(self.buffer)
2016-02-20 18:00:01,290 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\transitionlayer.py", line 132, in next_frame
2016-02-20 18:00:01,290 - vpcom - INFO -    f = self.transitionMgr.next_frame(self.layer_A_wrapped.next_frame(),self.layer_B_wrapped.next_frame())
2016-02-20 18:00:01,290 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 54, in next_frame
2016-02-20 18:00:01,290 - vpcom - INFO -    return self.transition_frame(from_frame=from_frame, to_frame=to_frame)
2016-02-20 18:00:01,290 - vpcom - INFO -  File "C:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 273, in transition_frame
2016-02-20 18:00:01,290 - vpcom - INFO -    frame = from_frame.copy()
2016-02-20 18:00:01,290 - vpcom - INFO - AttributeError: 'NoneType' object has no attribute 'copy'
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:15
my table is named evildead like the b2S
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:18
Thanks I've never had it crash there before and mine is ok. I did miss another file, but I don't think that was too important either.
The Bridge (LeftRamp.py) did have a small change, you pulled in latest GIT?
Yes that will be fine, I can see your BG is loaded, but angrim had it named proc_evildead.
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:32
ok i will try rename my b2s.  [Vous devez être inscrit et connecté pour voir cette image]
just got the error again
Code:
2016-02-20 18:27:39,388 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:39,451 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:39,836 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:27:40,551 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:27:40,552 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:40,805 - game - INFO - Target6: closed (1)
2016-02-20 18:27:40,851 - game - INFO - Target6: open   (2)
2016-02-20 18:27:40,851 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:41,237 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:27:41,371 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:41,371 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:41,997 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:42,056 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:27:42,058 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:42,846 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:27:44,482 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:27:44,482 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:44,645 - game - INFO - slingR: closed (1)
2016-02-20 18:27:44,690 - game - INFO - slingR: open   (2)
2016-02-20 18:27:44,690 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:44,931 - game - INFO - Target5: closed (1)
2016-02-20 18:27:44,970 - game - INFO - Target5: open   (2)
2016-02-20 18:27:44,970 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:45,201 - game - INFO - Target1: closed (1)
2016-02-20 18:27:45,250 - game - INFO - Target1: open   (2)
2016-02-20 18:27:45,250 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:45,395 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:27:45,667 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:27:45,667 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:45,815 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:45,815 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:46,012 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:46,265 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:46,265 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:46,266 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:27:47,009 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:48,615 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:48,617 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:48,930 - game - INFO - eVil: closed (1)
2016-02-20 18:27:48,930 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:27:48,931 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:27:48,931 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:48,931 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:48,931 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:48,931 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:48,931 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:48,933 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:48,933 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:48,933 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:48,933 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:48,933 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:48,933 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:48,933 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:48,933 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:48,933 - game.modes - INFO -   4    SpellEvilDead  TransitionLayer
2016-02-20 18:27:48,933 - game.modes - INFO -   4    ModeInfo       ScriptlessLayer
2016-02-20 18:27:48,933 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:48,933 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:48,933 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:27:48,933 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:48,933 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:48,933 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:48,960 - game - INFO - leftEject: closed (1)
2016-02-20 18:27:48,961 - game - INFO - eVil: open   (2)
2016-02-20 18:27:48,961 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:49,509 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:49,960 - game.modes - INFO - Added ModeSelect  pri=15.
2016-02-20 18:27:49,969 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:27:49,971 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:27:50,023 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:50,023 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:50,023 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:50,023 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:50,023 - game.modes - INFO -   15   ModeSelect     GroupedLayer
2016-02-20 18:27:50,023 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:50,023 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:50,023 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:50,023 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:50,023 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:50,023 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:50,023 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:50,023 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:50,023 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:50,023 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:27:50,023 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:27:50,023 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:50,023 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:50,023 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:27:50,023 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:50,023 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:50,023 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:51,112 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:51,301 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:52,523 - game.modes - INFO - Added Shelly  pri=15.
2016-02-20 18:27:52,697 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:27:52,697 - game.modes - INFO - Removed ModeSelect  pri=15.
2016-02-20 18:27:52,697 - game - INFO - Mode Select: (mode_stopped)
2016-02-20 18:27:52,700 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:52,700 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:52,700 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:52,700 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:52,700 - game.modes - INFO -   15   Shelly         -
2016-02-20 18:27:52,700 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:52,700 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:52,700 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:52,700 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:52,700 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:52,700 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:52,700 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:52,700 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:52,700 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:52,700 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:27:52,700 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:27:52,700 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:52,700 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:52,700 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:52,701 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:52,701 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:52,842 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:27:52,842 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:52,842 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:52,844 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:52,844 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:52,844 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:27:52,844 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:52,844 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:52,844 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:52,844 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:52,844 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:52,844 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:52,844 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:52,844 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:52,844 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:52,844 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:27:52,844 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:27:52,844 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:52,844 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:52,844 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:27:52,844 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:52,845 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:52,845 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:55,897 - game.modes - INFO - Added ModeTimeLayer  pri=21.
2016-02-20 18:27:55,898 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:55,898 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:55,898 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:55,898 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:55,898 - game.modes - INFO -   21   ModeTimeLayer  -
2016-02-20 18:27:55,898 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:27:55,898 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:55,898 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:55,898 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:55,900 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:55,900 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:55,900 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:55,900 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:55,900 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:55,900 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:55,900 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:27:55,900 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:27:55,900 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:55,900 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:55,900 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:27:55,900 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:55,900 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:55,900 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:55,904 - game - INFO - leftEject: open   (2)
2016-02-20 18:27:55,904 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D6401B0>'; will search in 10s.
2016-02-20 18:27:57,983 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:57,984 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:58,367 - game - INFO - eVil: closed (1)
2016-02-20 18:27:58,367 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:27:58,368 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:27:58,368 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:27:58,368 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:27:58,368 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:27:58,368 - game.modes - INFO -   90   Trough         -
2016-02-20 18:27:58,368 - game.modes - INFO -   21   ModeTimeLayer  GroupedLayer
2016-02-20 18:27:58,368 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:27:58,368 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:27:58,368 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:27:58,368 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:27:58,368 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:27:58,368 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:27:58,368 - game.modes - INFO -   6    Cards          -
2016-02-20 18:27:58,368 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:27:58,368 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:27:58,368 - game.modes - INFO -   5    Targets        -
2016-02-20 18:27:58,368 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:27:58,368 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:27:58,368 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:27:58,368 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:27:58,368 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:27:58,368 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:27:58,368 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:27:58,368 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:27:58,414 - game - INFO - eVil: open   (2)
2016-02-20 18:27:58,414 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:58,766 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:27:58,858 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:27:58,858 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:27:58,890 - game - INFO - slingL: closed (1)
2016-02-20 18:27:58,934 - game - INFO - slingL: open   (2)
2016-02-20 18:27:58,934 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:27:59,239 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:27:59,239 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:27:59,302 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:28:00,190 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:00,875 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:28:00,875 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:28:01,428 - game - INFO - kickOut: closed (1)
2016-02-20 18:28:01,434 - game - INFO - Kickout Active 5ms
2016-02-20 18:28:01,434 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:28:01,436 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:28:01,436 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:28:01,436 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:28:01,436 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:28:01,436 - game.modes - INFO -   90   Trough         -
2016-02-20 18:28:01,436 - game.modes - INFO -   21   ModeTimeLayer  GroupedLayer
2016-02-20 18:28:01,436 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:28:01,436 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:28:01,436 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:28:01,436 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:28:01,436 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:28:01,436 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:28:01,437 - game.modes - INFO -   6    Cards          -
2016-02-20 18:28:01,437 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:28:01,437 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:28:01,437 - game.modes - INFO -   5    Targets        -
2016-02-20 18:28:01,437 - game.modes - INFO -   4    SpellEvilDead  GroupedLayer
2016-02-20 18:28:01,437 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:28:01,437 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:28:01,437 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:28:01,437 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:28:01,437 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:28:01,437 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:28:01,437 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:28:01,440 - game - INFO - kickOut: open   (2)
2016-02-20 18:28:01,441 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:28:01,812 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:01,967 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:28:01,967 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:28:01,997 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:28:01,997 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:28:02,464 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:28:02,513 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:02,615 - game - INFO - outhole: closed (1)
2016-02-20 18:28:02,621 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:28:02,621 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:28:02,622 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:28:02,622 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:28:02,622 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:28:02,622 - game.modes - INFO -   90   Trough         -
2016-02-20 18:28:02,622 - game.modes - INFO -   21   ModeTimeLayer  GroupedLayer
2016-02-20 18:28:02,624 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:28:02,624 - game.modes - INFO -   12   DMDHelper      GroupedLayer
2016-02-20 18:28:02,624 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:28:02,624 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:28:02,624 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:28:02,624 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:28:02,624 - game.modes - INFO -   6    Cards          -
2016-02-20 18:28:02,624 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:28:02,624 - game.modes - INFO -   5    AshRollover    -
2016-02-20 18:28:02,624 - game.modes - INFO -   5    Targets        -
2016-02-20 18:28:02,624 - game.modes - INFO -   4    SpellEvilDead  GroupedLayer
2016-02-20 18:28:02,624 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:28:02,624 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:28:02,624 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:28:02,624 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:28:02,624 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:28:02,624 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:28:02,625 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:28:02,632 - game - INFO - trough2: open   (2)
2016-02-20 18:28:02,632 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640170>'; will search in 10s.
2016-02-20 18:28:02,645 - game - INFO - outhole: open   (2)
2016-02-20 18:28:02,645 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640070>'; will search in 10s.
2016-02-20 18:28:02,766 - game - INFO - trough2: closed (1)
2016-02-20 18:28:02,911 - game - INFO - trough1: closed (1)
2016-02-20 18:28:03,411 - game - INFO - trough: launch_balls 1
2016-02-20 18:28:03,411 - game - INFO - trough: pulse trough
2016-02-20 18:28:03,441 - game - INFO - trough4: open   (2)
2016-02-20 18:28:03,441 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640190>'; will search in 10s.
2016-02-20 18:28:03,496 - game - INFO - shooter: closed (1)
2016-02-20 18:28:03,497 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640470>'
2016-02-20 18:28:03,796 - game - INFO - trough: saw shooter lane -launch successful
2016-02-20 18:28:03,796 - game - INFO - BaseGameMode: BALL SAVED from Trough callback
2016-02-20 18:28:03,805 - game - INFO - shooter: open   (2)
2016-02-20 18:28:03,805 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640470>'; will search in 10s.
2016-02-20 18:28:03,941 - game - INFO - isWizardREady
2016-02-20 18:28:04,434 - game - INFO - trough2: open   (2)
2016-02-20 18:28:04,434 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640170>'; will search in 10s.
2016-02-20 18:28:04,434 - game - INFO - trough1: open   (2)
2016-02-20 18:28:04,436 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640110>'; will search in 10s.
2016-02-20 18:28:04,436 - game - INFO - trough3: open   (2)
2016-02-20 18:28:04,436 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D6401F0>'; will search in 10s.
2016-02-20 18:28:04,477 - game - INFO - trough2: closed (1)
2016-02-20 18:28:04,490 - game - INFO - trough4: closed (1)
2016-02-20 18:28:04,490 - game - INFO - trough3: closed (1)
2016-02-20 18:28:04,848 - game - INFO - topDropTarget: closed (1)
2016-02-20 18:28:04,892 - game - INFO - topDropTarget: open   (2)
2016-02-20 18:28:04,892 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640390>'; will search in 10s.
2016-02-20 18:28:04,990 - game - INFO - isWizardREady
2016-02-20 18:28:06,894 - game - INFO - topRolloverR: closed (1)
2016-02-20 18:28:06,926 - game.modes - INFO - Removed LampShowMode  pri=3.
2016-02-20 18:28:06,927 - game.modes - INFO - Added LampShowMode  pri=3.
2016-02-20 18:28:06,941 - game.modes - INFO - Modes changed in last run loop cycle, now:
2016-02-20 18:28:06,941 - game.modes - INFO -   100  TrophyMode     -
2016-02-20 18:28:06,941 - game.modes - INFO -   99   Tilt           -
2016-02-20 18:28:06,941 - game.modes - INFO -   90   Trough         -
2016-02-20 18:28:06,941 - game.modes - INFO -   21   ModeTimeLayer  GroupedLayer
2016-02-20 18:28:06,943 - game.modes - INFO -   15   Shelly         GroupedLayer
2016-02-20 18:28:06,943 - game.modes - INFO -   12   DMDHelper      -
2016-02-20 18:28:06,943 - game.modes - INFO -   8    BallSearch     -
2016-02-20 18:28:06,943 - game.modes - INFO -   7    LeftRamp       -
2016-02-20 18:28:06,943 - game.modes - INFO -   7    CellarRamp     -
2016-02-20 18:28:06,943 - game.modes - INFO -   6    Bumpers        GroupedLayer
2016-02-20 18:28:06,943 - game.modes - INFO -   6    Cards          -
2016-02-20 18:28:06,943 - game.modes - INFO -   6    Workshed       -
2016-02-20 18:28:06,943 - game.modes - INFO -   5    AshRollover    TransitionLayer
2016-02-20 18:28:06,943 - game.modes - INFO -   5    Targets        -
2016-02-20 18:28:06,943 - game.modes - INFO -   4    SpellEvilDead  -
2016-02-20 18:28:06,943 - game.modes - INFO -   4    ModeInfo       -
2016-02-20 18:28:06,943 - game.modes - INFO -   3    BallSave       -
2016-02-20 18:28:06,944 - game.modes - INFO -   3    BaseGameMode   -
2016-02-20 18:28:06,944 - game.modes - INFO -   3    LampShowMode   -
2016-02-20 18:28:06,944 - game.modes - INFO -   2    SwitchMonitor  -
2016-02-20 18:28:06,944 - game.modes - INFO -   1    OSC_Mode       -
2016-02-20 18:28:06,944 - game.modes - INFO -   0    ScoreDisplay   ScoreLayer
2016-02-20 18:28:07,187 - game - INFO - topRolloverR: open   (2)
2016-02-20 18:28:07,188 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x2D640550>'; will search in 10s.
2016-02-20 18:28:07,607 - game - INFO - bumperM: closed (1)
2016-02-20 18:28:07,651 - game - INFO - bumperM: open   (2)
2016-02-20 18:28:07,651 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x25EFAD10>'; will search in 10s.
2016-02-20 18:28:08,302 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:28:08,302 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:28:08,361 - game - INFO - bumperL: closed (1)
2016-02-20 18:28:08,417 - game - INFO - bumperL: open   (2)
2016-02-20 18:28:08,417 - game - INFO - BallSearch: RESET via '%s'; next search is not scheduled.
2016-02-20 18:28:08,437 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:08,960 - game - INFO - bumperL: closed (1)
2016-02-20 18:28:09,006 - game - INFO - bumperL: open   (2)
2016-02-20 18:28:09,006 - game - INFO - BallSearch: RESET via '<procgame.game.gameitems.Switch object at 0x25EFAE70>'; will search in 10s.
2016-02-20 18:28:09,065 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:28:09,066 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:28:09,219 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:09,538 - game - INFO - flipperLwR: closed (1)
2016-02-20 18:28:09,539 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640050>'
2016-02-20 18:28:09,582 - game - INFO - flipperLwL: closed (1)
2016-02-20 18:28:09,584 - game - INFO - BallSearch: countdown STOPPED via '<procgame.game.gameitems.Switch object at 0x2D640030>'
2016-02-20 18:28:09,674 - game - INFO - flipperLwR: open   (2)
2016-02-20 18:28:09,884 - game - INFO - flipperLwL: open   (2)
2016-02-20 18:28:10,186 - game - INFO -
Total Time: 343.171 Seconds
2016-02-20 18:28:10,186 - game - INFO - Loops: 1970904
2016-02-20 18:28:10,186 - game - INFO - Overall loop rate: 5844.148Hz
2016-02-20 18:28:10,186 - game - INFO - Frame rate: 23.983FPS
2016-02-20 18:28:10,186 - game - INFO - DMD Updates: 8088
2016-02-20 18:28:10,186 - game - INFO - loops between dmd updates: 243.000
2016-02-20 18:28:10,186 - game - INFO - Waiting for the OSC Server thread to finish
2016-02-20 18:28:10,187 - game - INFO - OSC Server thread is done.
2016-02-20 18:28:10,188 - vpcom - INFO - PYTHON FAILURE (Visual Pinball Bridge is now broken)
2016-02-20 18:28:10,188 - vpcom - INFO - Exception Name AttributeError: 'NoneType' object has no attribute 'copy'
2016-02-20 18:28:10,188 - vpcom - INFO - Traceback (most recent call last):
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\tools\register_vpcom.py", line 286, in RunGame
2016-02-20 18:28:10,188 - vpcom - INFO -     self.game.run_loop()
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 956, in run_loop
2016-02-20 18:28:10,188 - vpcom - INFO -     super(SkeletonGame, self).run_loop(min_seconds_per_cycle)
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\game\game.py", line 721, in run_loop
2016-02-20 18:28:10,188 - vpcom - INFO -     self.process_event(event)
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\game\game.py", line 593, in process_event
2016-02-20 18:28:10,188 - vpcom - INFO -     self.dmd_event()
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\game\skeletongame.py", line 908, in dmd_event
2016-02-20 18:28:10,188 - vpcom - INFO -     self.dmd.update()
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\displaycontroller.py", line 77, in update
2016-02-20 18:28:10,188 - vpcom - INFO -     layer.composite_next(self.frame)
2016-02-20 18:28:10,188 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\dmd.py", line 412, in composite_next
2016-02-20 18:28:10,188 - vpcom - INFO -     src = self.next_frame()
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 765, in next_frame
2016-02-20 18:28:10,190 - vpcom - INFO -     frame = layer.composite_next(self.buffer)
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\dmd.py", line 412, in composite_next
2016-02-20 18:28:10,190 - vpcom - INFO -     src = self.next_frame()
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\layers.py", line 663, in next_frame
2016-02-20 18:28:10,190 - vpcom - INFO -     layer.composite_next(self.buffer)
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\transitionlayer.py", line 132, in next_frame
2016-02-20 18:28:10,190 - vpcom - INFO -     f = self.transitionMgr.next_frame(self.layer_A_wrapped.next_frame(),self.layer_B_wrapped.next_frame())
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 54, in next_frame
2016-02-20 18:28:10,190 - vpcom - INFO -     return self.transition_frame(from_frame=from_frame, to_frame=to_frame)
2016-02-20 18:28:10,190 - vpcom - INFO -   File "C:\P-ROC\games\EvilDead\procgame\dmd\transitions.py", line 273, in transition_frame
2016-02-20 18:28:10,190 - vpcom - INFO -     frame = from_frame.copy()
2016-02-20 18:28:10,190 - vpcom - INFO - AttributeError: 'NoneType' object has no attribute 'copy'
i use the same version of code than shadow, juste dowloaeed it a few minutes agi with his link
sorry for the typo im using virtual keyboard its a real pain  [Vous devez être inscrit et connecté pour voir cette image]
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 18:39
Don't worry I am in for the evening Smile
This is the only difference I can see now of files. Very strange, never had that and you both have it.
See in your config.yaml: Add ball search & osc_input: False
default_modes:  # these are the default provided modes by SkeletonGame; turn them off here.
    score_display: True
    bonus_tally: False
    osc_input: False
    service_mode: True
    ball_search: True
    tilt_mode: False
    user_profiles: True
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:14
ok i found when im having the issue. its when on the dmd there is a countdown with a clock on the top right . when the timer comes down to 15 i have the popup with the error 273. I will try your modification code. i really love your table btw perfect gameplay and atmosphere thanks for that  [Vous devez être inscrit et connecté pour voir cette image]
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:21
Chepas, can you explain the difference between the final battle and the master branch and which one we should use?
also i checked the table you uploaded in dropbox, i don't get what you did with the sounds, what are these snds sound checks like
If snds_RSling Then PlaySound "slingshotright", 0, 1, 0.05, 0.05
what do we have to do avoid hearing the sounds that have the snds in their names?
finally, when we update EvilDead from the source, we have to keep our config.yaml, are there other files we have to keep? or keep some data on it?
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:23
so if i modify the config file to put false for the osc variable i can t start the table, balls missing and if i put ball_search: True i have python errors
in fact with the ball_search option before the service one no python error
edit: set to true no python error but the table dont start balls missing
set to false python error
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:38
Thanks that helps......Its weird if this clock icon ever worked before though? I was thinking it could be encoding problems there, but if it worked fine before?
""can you explain the difference between the final battle and the master branch and which one we should use?""
They're just branches (trees, roads), like when you want to make or test new things without harming the master branch. So with the final-battle branch I was working on that mode, but I did other stuff as well.
When you're finished you can Merge the branches into one. So, you were on my test branch. It shouldn't matter, because that was made from the master anyway, so it up to date.
If you load up the EvilDead GUI. exe . You can change all your settings here. This just changes the file config/game_user_settings.yaml.
You will see all the keys for the sounds there and others, but its easier to just use the interface. And I think all the sounds are selectable in the service menu as well all on the fly.
This is what the vp_live_config.py does. Like a two way config between VP & proc. You can see no matter which way it is I'm trying always to avoid hard code configurations in the VP script.
This file will never be updated from my end. If I did this,  then that would want to overwrite your config.yaml. So you generally just clone the folder and you get the config.yaml from git but is only changed on your side. The same for some config/settings.
The absolute best way to be current is to clone the master to Evil Dead. You could just remove your old files and do git clone.
Put in your assets.
You can pull in updates automatically if you wanted to and roll back anywhere.
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:47
i can tell first day i play your table
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:48
my question was not to explain me what is a branch, i work with svn from different systems for years Wink
ok so we will just care about the master then
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:52
the evil dead gui never worked for me, i get the popup error main returned -1 and then the program closes, i will check the game_user_settings.yaml
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:54
You asked the question like you didn't know. Smile Yes test without hurting, but normally if there was alot of changes you wanted you pull it.
That is still nice simple example for anybody else there reading.
Always happened? Sorry are you french as well? I cannot see flag.
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 9 EmptySam 20 Fév 2016 - 19:56
i'm french, living in belgium yes, english is just my working language Wink
do we have to put the evildeadgui to a special path in the evildead folder or i don't know where?
Page 9 sur 23Aller à la page : Précédent  1 ... 6 ... 8, 9, 10 ... 16 ... 23  Suivant
» [ABANDONNÉ] Comment installer Evil Dead sur VP10 ???
» [Table]Table evil dead vpx
» [TUTO] Installer VPX, une table VPX (UltraDMD) et VP9
» [ARCHIVÉ] Nouvelles (versions de) tables VPX 2018
» [TUTO] Installer et configurer PBX Recorder 1.6
