 [TUTO] Installer PROC et la table evil dead
naaco
Suby
chris62700
MAXxXAM
ilveropaolone
Bluetooth
Stéphanas
jphil82
DamsBALL
snwfrd38
bruce8374
kakou
Carny_Priest
moviemaniac52
firebrand007
jeyspeed
khomodo
horsepin
garath
kwak
32 participants
Aller à la page : Précédent  1 ... 6 ... 9, 10, 11 ... 16 ... 23  Suivant
Développeur Team PP
[TUTO] Installer PROC et la table evil dead - Page 10 Empty
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:00
i also saw more than once that some branches changes were never put to the master branch, that's why i ask Wink
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:10
ok sorry the bug is not related to the clock on the dmd. got it without countdown. i dont see what start this error  [Vous devez être inscrit et connecté pour voir cette image]
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:20
my question was just that in fact, The same for some config/settings, which files do we have to keep, except the config.yaml
horsepin a écrit:
finally, when we update EvilDead from the source, we have to keep our config.yaml, are there other files we have to keep? or keep some data on it?
This file will never be updated from my end. If I did this,  then that would want to overwrite your config.yaml. So you generally just clone the folder and you get the config.yaml from git but is only changed on your side. The same for some config/settings.
The absolute best way to be current is to clone the master to Evil Dead. You could just remove your old files and do git clone.
Put in your assets.
You can pull in updates automatically if you wanted to and roll back anywhere.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:29
Yeah just putting the GUI files into the game folder is fine. Like I say you can do it from the service menu anyway if you wanted.
evildead/config.yaml
These two get generated if you don't have them.
evildead/config/game_user_settings.yaml
evildead/config/game_user_data.yaml
ANy profiles you want to keep.
evildead/config/profiles/
And trophys under you name, but these need to be moved into configs also to be easier.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:32
Yes like before with config.yaml, these are ignored so you keep your own the whole time.
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 20:36
It's always done this to you? A transition does happen on the top roll overs. That's what it looks like to me in your case, but not sure why, apart from encoding.
I can do you a file you can try to ignore that to see if it passes it.
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 21:12
latest version on dropbox has an issue if you don't enable b2s, line 887, here's the fix
Sub SolFlasherMode(enabled)
vpmSolToggleObj Array(mode_flash1,mode_flash2),Nothing,"FlasherClickLow",Enabled
mode_flash_image1.Visible=Enabled:mode_flash_image2.Visible=Enabled
If Enabled Then
If b2sOn  Then B2SController.B2ssetdata 41,1
DOF 144,1
Else
If b2sOn  Then B2SController.B2ssetdata 41,0
DOF 144,0
 End If
End Sub
also 2 things i told you by mail about my updates but are not on your latest:
for primitive19 and 36 you need to disable static rendering in colors & formatting or the rails will not be hidden in fs mode
and this is the pov fix to see all the table field, the apron is truncated in your version
finally i forgot to tell, but for the reflection and ball trail, it is better to let values as -1 in the editor so it follows the global settings that the user chose in his video settings of vp
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 21:34
sorry, if the table in dropbox is really the one where you have put my changes, i have quite some issues let's continue on pm
garath
garath
Département : Paris
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 21:44
For me, no errors with "final battle". But I understand that next time, I should take "master".
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 21:46
Well, you know what you're doing for the moment.
The table won't be touched for a bit now so I wouldn't strive for perfection just yet.
I would like to know it does work for you because it's fine here. It's at the best state it's ever been at completion wise. I put time aside for finishing the last two modes but got stuck pissing around with trough /bug etc.
khomodo - You could try this build, I did ask earlier if you were french? I had a hard job using quotes in some posts.
Unless you have a really really terrible machine it shouldn't bomb. I went through and tried forced encoding, it may help, I don't know.
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 22:14
Just a quick feedback : me and my wife played Evil Dead tonight for about 15 minutes.
Then the game froze completely, and then I saw the Windows message saying that Visual Pinball 10 has stopped working bla bla bla.
I will take a look at the log tomorrow, I have enough for today Wink
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 22:16
this sounds more like a vp issue, not really the table, find the crashdump.txt and send it to vpforums vpx thread, or use the newer beta instead, perhaps that's what they should tell you to do
horsepin
Département : oui
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 22:44
Yeah its pretty rare but today I have had it after the "Chainsaw Wipe" coming out of shed.
A lot of the time I put that down to running too many other programs my end but 15 minutes is good compared to none earlier?
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptySam 20 Fév 2016 - 22:52
Yes i'm french ;-) My setup isnt too poor, i can run all the vpx tables for the moment (got some lags for the big ones) i5 with r270 amd card .
i will try your other build tomorrow thanks :-)
but i setup my language to french (belgium) like said in the tutorial
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 8:30
tuto mis a jour, j'ai retiré git, et expliqué pour une première installation ou une upgrade des sources
donc la dernière table qui est DOF full compatible ici
je mettrai à jour pour une nouvelle version
garath
garath
Département : Paris
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 8:57
Je viens de suivre le tuto pour la maj EvilDead (du coup, je passe de la branche Final Battle à Master).
Je vois que tu n'as pas indiqué de supprimer tous les *.pyc, c'est volontaire ?
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 9:02
juste je corrige, je dois encore voir si il y a d'autres fichiers a garder
garath
garath
Département : Paris
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 9:39
Je me suis mis une petite musique Evil Dead, extraite du film.
Si ça vous intéresse, la voici : EvilDead.mp3
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 9:44
uh Arngrim j'ai une erreur 404 sur ce lien ? tu as déplacé le fichier ? non c'est bon avec le le lien du tuto ça marche
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 9:54
razorbaxx a écrit:
Bon les gars je comprends pas grand chose a la discussion je suis sur mon téléphone et pincab passion c est deja galere alors en anglais c est pas la peine  lol! je vais lire tout ça avec Google trad a la maison car je suis curieux de voir de quoi vous pouvez bien discuter
Don't worry Razorbaxx, oops France , ne t'inquiète pas Razorbaxx, Arngrim "traduira" tout ça en mettant à jour le tuto au fil de l'eau Wink
Ce qu'il faut retenir des échanges avec Chepas, c'est qu'il a, comme beaucoup de développeurs font, créer une branche final battle à partir de son arbre master : à partir du code original qui fait tourner la table (le master), on crée une branche parallèle pour étudier d'autres possibilités (la final battle en l'occurence), sans compromettre la branche principale.
Et nous, on teste et on fait du compte-rendu, ça permet de cerner les problèmes et de les résoudre.
MJR a fait exactement pareil avec les problèmes USB du firmware Pinscape Controller de la KL25Z : il a gardé son code original et à créé un fork (un "dérivé"), sur lequel il a travaillé jusqu'à trouver l'origine du problème.
C'est une copie de sauvegarde en fait.
@Garath : un grand merci pour le partage, le mp3 ira au chaud dans les médias PinballX [TUTO] Installer PROC et la table evil dead - Page 10 3253257302
@Chepas : I'm explaining, for our non english speaking members, what we are doing since yesterday Wink
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 9:58
je viens d'updater la table, c'est pour ça,
un autre fichier a garder quand on upgrade, le game_user_settings.yaml
et maintenant pour disabler les sons quand on a dof, la section VPSounds doit etre comme ça
VPSounds: {Bumpers: 0, CellarVUK: 0, FlipperVol: 0, Flippers: 0, Lslingshot: 0, ModeSaucer: 0,
Rslingshot: 0, ScottySaucer: 0, ShedScoop: 0, TroughEnter: 0, TroughExit: 0, WoodsKicker: 0}
je vais le mettre dans le tuto
khomodo
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 10:35
Merci arngrim,
Bon j'ai repris evildead avec les derniers liens (table + branche) j'ai eu un espoir à un moment, plus le bug 273... Mais non il vient de
se reproduire à l'instant (encore avec l'horloge sur la frame 15).
J'ai bien effacé les 101 pyc pourtant. zut et zut
Et j'ai eu 2 autres pbs aussi , la bille est restée bloquée dans 2 ejecteurs (celui du lecteur de bande et un autre en démarrage de mode) obligé de tilter pour que la bille soit éjectée) . Je n'avais pas eu ce pb encore
Bon je teste la branche spéciale qu'il a créée au cas ou
garath
garath
Département : Paris
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 10:39
Vérifie aussi que toutes les DLL du répertoire soient bien débloquées.
Développeur Team PP
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 11:28
tu es bien en clavier belge?
maj du proc.exe, il efface le log.txt au démarrage de la table a partir de pinballx, le log.txt ne cessait de grandir sans etre effacé
MessageSujet: Re: [TUTO] Installer PROC et la table evil dead   [TUTO] Installer PROC et la table evil dead - Page 10 EmptyDim 21 Fév 2016 - 12:02
C'est qui qu'avait raison pour le log lol!
Merci Arngrim, par contre faut que je regarde ça aussi pour proc, hier soir ça n'arrêtait pas de faire planter PinballX : j'avais d'abord un message Windows comme quoi SmartScreen a bloqué le logiciel pour "ma" sécurité pas mal, je l'ai débloqué mais PBX fige sur Loading Rolling Eyes
Page 10 sur 23Aller à la page : Précédent  1 ... 6 ... 9, 10, 11 ... 16 ... 23  Suivant
» [ABANDONNÉ] Comment installer Evil Dead sur VP10 ???
» [Table]Table evil dead vpx
» [TUTO] Installer VPX, une table VPX (UltraDMD) et VP9
» [ARCHIVÉ] Nouvelles (versions de) tables VPX 2018
» [TUTO] Installer et configurer PBX Recorder 1.6
