| [ARCHIVÉ] Les logiciels essentiels | |
+36spike56 jphil82 jimenez Pincabonaute grozby88 medax chucky87 Sharkky Shadow_SHD TylerDurden67 firebrand007 jObiwan Chucky01 kwak vulbas darklvador patrickdidier91 arngrim tigrouh00h00 nicofab18 malcom1970 lololol gech leevuth peskopat DamsBALL ced Nevendaar jawah RipleYYY PHILI50 razorbaxx Citron68 AnthozoA bip-bip-72 fcdrik 40 participants |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Sam 2 Sep 2017 - 19:49 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Jeu 5 Oct 2017 - 9:48 | |
| VPX 10.4 beta rev3235 du 03/10/17 :- VBS scripts should work again now. - Sound Manager: remove *BG* from the file name, instead toggle Table/Backglass in the output column. SAMbuild 3.0 beta rev4381 du 04/10/17 :Official rev 4381 - Set Transformers to 12-port aux board to enable LE solenoids [DJRobX]. - For those keeping track, the A.G. Football rom sets recently added to the source are full clones of A.G. Soccer-Ball. Tables sold to the Europe market had different artwork but used the same game code. Just copy the following and rename if you need to run these: agsoccer.zip = agfootbl.zip agsocc07.zip = agfoot07.zip PinballX v2.42 du 02/10/17 :- Allows non cabinet mode (grid select/send keys) for Pinball FX3. DOFLinx v5.20 du 24/09/17 :- Update FX2 memory triggers to handle Pinball FX2.exe update circa 23/9/17. - Add new optional parameter DIRECTOUTPUTGLOBAL=. If you have a DOF global config file, use this parameter to point to it : DIRECTOUTPUTGLOBAL=c:\DirectOuput\Config\GLobalConfig_b2sServer.xml - Add detection of Teensy addressable LED controller. - Add test routine for any DOF configured ROM and element. - Tidy up some logging messages. - Add support for addressable LED commands from FX2 and FP. FX2 will require new FX2 files, only some games have been updated so far, new FX2 files will keep coming. FP will require the replacement of the DOFLinx.vbs file in your \FP\scripts\ folder. - New parameter AUTO_MX=. Default is 0, being off. Set to 1 "AUTO_MX=1" to enable some MX functionality for FP and FX2 games not yet fully scripted. Pin2DMD v2.42 du 11/09/17 :- Fix missing connection from pinball input P3 to RN2. - Cosmetics in the schematics by UncleSash. Pin2DMD Editor v2.32 du 19/09/17 :- Pas de changelog. DMD Extensions v1.6.0 du 30/09/17 :Breaking Changes : - Use VPM positioning settings per default when available (#38). - Dot size of virtual DMD is now larger per default (#59). Features - Added --quit-after option (#34). - The play command now supports animated GIFs. - Added --idle-after and --idle-play, useful for TPA (#36). - Added support for Pinball FX3 (#69). Fixes - Fixed crash in Pinball FX2 grabber. - Fixed PinDMD2 for Pinball FX2 and probably others (#47). - When stayontop is enabled, explicitly check for B2S and put it on top of it (#40). - Various crashes. ++ | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Ven 10 Nov 2017 - 21:05 | |
| Version PIN2DMD en V2.49 attention vous devez changer le chemin de firm il faut mettre sur PIN2DMD-master\firmware\latest\V3 STM32F4 DISCOVERY et pas comme avant \PIN2DMD-master\firmware\latest sinon vous auriez un probleme de activation et pas le bon firm
Attention chez moi la v2.49 de pin2dmd l'orange est plus sombre ca fait mal au yeux, je suis retourné en version 2.41 vu que je ne trouve pas la version 2.42 meme chez lucky je la trouve pas en attendant si quelq'un peut nous trouver la version 2.42 merci | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Sam 11 Nov 2017 - 19:22 | |
| Pour télécharger une ancienne version du firmware : - Rendez-vous sur le Github de Lucky1, - Cliquez sur XX commits (où XX = le nombre de modifications effectuées) : - Cliquez sur le bouton [<>] à droite pour parcourir le contenu de la version désirée, par exemple pour la v2.47 : - Dans la page suivante cliquez sur le bouton [ Clone or download ] puis sur Download ZIP : Il n'y a plus qu'a flasher votre carte contrôleur Info postée dans ce sujet pour qu'elle soit visible dans la bonne section du forum ++ | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Sam 11 Nov 2017 - 19:55 | |
| merci shadow tu es le meilleur ! | |
arngrim Développeur Team PP
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Lun 11 Déc 2017 - 11:48 | |
| nouvelle version de vpm, rev 4395
http://vpuniverse.com/forums/topic/3241-sambuild30-beta-thread/?do=findComment&comment=37623
Ajout notamment de Walking Dead 1.60 PRO et LE
version Pro Modifiée avec des voix de la série https://www.dropbox.com/s/0nrvmknade6etai/TWD160_CLELAND_R.BIN?dl=0
version LE Modifiée avec des voix de la série https://www.dropbox.com/s/frsafcja1r9wd2a/TWD160LE_CLELAND_R.BIN?dl=0 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Lun 11 Déc 2017 - 11:57 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Lun 11 Déc 2017 - 15:58 | |
| Sambuild et vpx 10.4 Ne prêter pas trop attention au mise en place , un nouveau sujet sur les centralisations va être ouvert d'ici peu Premier jet ~Les complémentaires~Suivront ~Les essentiels~ et ~les cartes toys et gestion~ | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 24 Déc 2017 - 16:35 | |
| Vpx installer 10.4 AIO V4 Le Tuto sera mis à jour prochainement | |
snwfrd38
| Sujet: [INFO] vpx 10.4 version finale Lun 25 Déc 2017 - 22:47 | |
| Et voila la version finale 10.4! http://www.vpforums.org/index.php?app=downloads&showfile=11572
Le parfait cadeau de noel:D | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Lun 25 Déc 2017 - 23:38 | |
| Fusionner , pour les logiciels c'est ici @snwfrd38 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Sam 30 Déc 2017 - 12:04 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mer 10 Jan 2018 - 7:49 | |
| Vp10.5 beta ---> http://www.vpforums.org/index.php?showtopic=39428 - IJ switch/cSingleLFlip fix in WPC.vbs - Hankin.vbs fix by nfozzy - also check color grading LUT images in image manager - better match direct sound and BASS devices, e.g. by name - cleanup code for textboxes - extend X and Y parameters of EMReel and textbox elements so that these can be changed dynamically by the script (e.g. can be moved around during gameplay) - fix missing bumper materials in-use detection - Updated latency delay tuning. When enabled, the delay loop is inserted between rendering and before vsync. Timing is now based on the last completed VSync frame. This allows delays to be inserted, while reliably not impacting performance. Recommended tuning factor is now 900 (90%). - update bass.dll to v2.4.13 - add ultradmd options to UltraDMD_Options.vbs by ninuzzu - nudge test and calibration table updated by Sir Cheddar - vbs script updated and commented Post à jour | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Sam 3 Fév 2018 - 16:51 | |
totoche40
| Sujet: Bonjour Dim 11 Fév 2018 - 9:33 | |
jphil82
Messages : 106 Département : 82
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 18 Fév 2018 - 17:28 | |
| nouveaux Pinballx 2.60 https://www.gameex.info/forums/files/file/527-pinballx/ PinballX 2.60 released Performance is significantly improved with this release The DirectX library has been transitioned to SlimDX with help from Ben Baker Bass audio library has been upgraded to the latest version The limit on company logo images has been increased to 70 from 60 Startup audio and GameEx online is working again New 'Launch' Keyboard and Gamepad control to immediaitly launch a game and skip the info screen. | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 18 Fév 2018 - 20:34 | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 18 Fév 2018 - 21:25 | |
| Merci pour l’info @Jphil82, je fusionne ton message avec le sujet dédié aux logiciels pour pincabs ++ | |
dom69
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mar 27 Fév 2018 - 13:51 | |
| PBX 2.64 ça va viiiiiiiiiiiiiiiiiiite | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mar 27 Fév 2018 - 14:02 | |
| il doit y avoir doublon avec un autre topic , car j'ai vue qu'il avait déja été signalé en 2.64 , mais vaut mieux un doublon que rien du tout merci ^^ | |
dom69
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mar 27 Fév 2018 - 14:16 | |
| ah oui surement il est sorti mercredi dernier je suis à la traine | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mer 14 Mar 2018 - 8:55 | |
| PinballX 2.65 : https://www.gameex.info/forums/files/file/527-pinballx/ | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Mer 14 Mar 2018 - 21:29 | |
patrickdidier91
Messages : 151 Département : 91
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 27 Mai 2018 - 21:52 | |
| Version de Pinballx 3.02 disponible | |
| Sujet: Re: [ARCHIVÉ] Les logiciels essentiels Dim 27 Mai 2018 - 22:08 | |
| PinballX... on va attendre la version 92.5 pour recommencer à en parler, parce qu’au rythme où les MAJ foireuses s’enchaînent c’est tous les jours qu’on va annoncer 2 nouvelles versions ++ | |
