 [RESOLU] mise a jour pin2dmd
[RESOLU] mise a jour pin2dmd Empty
MessageSujet: [RESOLU] mise a jour pin2dmd   [RESOLU] mise a jour pin2dmd EmptySam 24 Juin 2017 - 11:11
bonjour
mon pin2dmd fonctionne parfaitement , par contre j'ai pas fait de mise a jour depuis la première fois que j'ai installé mon pin2dmd.
faut il vraiment que je fasse la mise a jour du firm ou je peux laisser comme ca?
par contre comment faire la mise a jour du firm?
on installe comment si c’était la première installation?
[size=33]Installation[/size]
1. Firmware installation
1.1 Installation using ST-Link interface
(STM32F407 Discovery Board)
1) Download and install ST Link Utility: http://www.st.com/web/en/catalog/tools/PF258168
!! Note : Latest Discovery boards MB997D may need a ST-Link firmware update from here
http://www.st.com/content/st_com/en/products/embedded-software/development-tool-software/stsw-link007.html
2) The latest PIN2DMD files can be found here https://github.com/lucky01/PIN2DMD . For your first installation you can download all files here https://github.com/lucky01/PIN2DMD/archive/master.zipand extract them in a local folder.
3) Connect the STM32 board to the PC using a mini-USB cable (not the smaller microUSB cable). The board will light up and you should an STM32 STLink USB device connected in the Windows notification tray
4) Flash firmware: Target → Program
Choose PIN2DMD.BIN file from firmware/latest folder.
[RESOLU] mise a jour pin2dmd St-link-300x218
5) Programming STM board is done
1.2 Installation using boot mode
(custom controller without ST-Link interface)
1) Download and install DfuSE Utility: http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-stm32080.html
3.) Set controller into boot mode (DIP2 off for DMDST32) and powercycle.
4) Connect the controller board to the PC using a mini-USB cable.
5) Flash firmware using DfuSEDemo
6) Set controller into run mode and powercycle
If you have any problems please contact the manufacturer of your controller board.
2. Windows driver installation
1) Connect the STM board using the MiniUSB cable to PC to provide power,if not already connected.
2) Connect the STM board also using the microUSB cable to PC. Windows should automatically start to install the device.
3) Start Zadig Utility from usb_driver folder.
4) Choose Options → List All Devices
5) Choose LIB-USB-WIN32 as driver and install
[RESOLU] mise a jour pin2dmd Zadig-300x130
6) PIN2DMD driver is successfully installed.
kakou
kakou
Département : 18
MessageSujet: Re: [RESOLU] mise a jour pin2dmd   [RESOLU] mise a jour pin2dmd EmptySam 24 Juin 2017 - 12:36
J'ai fait la mise à jour cette semaine, j'ai donc utilisé la méthode 1.1
- télécharger la dernière version de PIN2DMD-MASTER (2.39), le dézipper dans c:\ en ecrasant l'ancienne version
- lancer l'utilitaire STM et flasher avec le nouveau .bin
Je n'ai pas mis a jour le driver USB, je sais pas si ca sert vraiment
» [RÉSOLU] Mise à jour Pin2Dmd et activation
» [RÉSOLU] Mise à jour Pin2DMD pour neuneu
» [EN COURS] Question mise à jour PIN2DMD pinballSP SMT32
» [RÉSOLU] Problème de mise à jour
