 [PARTAGE] Palettes
[PARTAGE] Palettes Empty
MessageSujet: [PARTAGE] Palettes   [PARTAGE] Palettes EmptyLun 29 Fév 2016 - 22:24
Mes Palettes Pin2Dmd..
[PARTAGE] Palettes 722859262
Big buck Hunter
https://dl.dropboxusercontent.com/u/98865673/BigBuckHunter.rar
http://vpuniverse.com/forums/files/file/4138-big-buck-hunter/
Rolling Stones Stern
https://dl.dropboxusercontent.com/u/98865673/RollingStones.zip
http://vpuniverse.com/forums/files/file/4137-the-rolling-stones/
Walking Dead
https://dl.dropboxusercontent.com/u/98865673/walking%20dead.rar
J'ai créé un dossier "twd_156" dans mon dossier rom.
Dans ce dossier j'y ai mis la rom fournie que j'ai renommé "twd_156.bin"
ensuite mettre au tout début du script de la table:
Code:
'************ BEGIN PIN2DMD PALETTE LOADING **************
'************* thanks to Rascal and gtxjoe ***************
Const PIN2DMD = True
Const PIN2DMDDIR = "C:\PIN2DMD-master\tools\vc++\Binary"
Dim oShell
Dim WScript
Dim ORIGDIR
Set oShell = CreateObject("WScript.Shell")
ORIGDIR = oShell.CurrentDirectory
oShell.CurrentDirectory = PIN2DMDDIR
If PIN2DMD = True then oShell.run "pin2dmd.exe /b TWD_156.dat",,TRUE
oShell.CurrentDirectory = ORIGDIR
Set oShell = Nothing
Dim DelayTime, StartTime
DelayTime = 0
StartTime = Timer
Do While DelayTime < 1
    DelayTime = Timer - StartTime
Loop
'************* END PIN2DMD PALETTE LOADING ***************
mon fichier palette se trouve dans
editer la ligne en fonction..
et tout a la fin du script de la table.
Code:
'************ BEGIN PIN2DMD PALETTE RESET **************
'************ thanks to Rascal and gtxjoe **************
Sub ResetPalette
Dim rShell
Dim WScript
Set rShell = CreateObject("WScript.Shell")
rShell.CurrentDirectory = PIN2DMDDIR
If PIN2DMD = True then rShell.run "pin2dmd.exe /c",,TRUE
Set rShell = Nothing
End Sub
Sub table1_exit():Controller.Stop:ResetPalette:End Sub
'************* END PIN2DMD PALETTE RESET ***************
Sources :
http://vpuniverse.com/forums/topic/2270-pin2dmd-table-support/
Sharkky
Sharkky
MessageSujet: Re: [PARTAGE] Palettes   [PARTAGE] Palettes EmptyLun 29 Fév 2016 - 23:03
Je testerai tes palettes demain, merci gech pour le taff et le partage
A la tienne A la tienne
MessageSujet: Re: [PARTAGE] Palettes   [PARTAGE] Palettes EmptyVen 4 Mar 2016 - 19:41
merci m'sieur  A la tienne
[PARTAGE] Palettes
» [RESOLU] Pin2Dmd Editor , Export Palettes As Palettes.dat
» [WIP] Pincab Mikaël
» [PARTAGE] Wheeler FX3
» [PARTAGE] db2s
Pincab Passion :: Centralisation , Créations & Partages médias :: Centralisation des Médias :: Pin2DMD-
