 [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp
pinballsp
kwak
ikari
15 participants
pinballsp
pinballsp
Département : pinball
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Empty
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyDim 21 Aoû 2016 - 1:21
I have create some preconfigured color palettes, so for test purposes its very fast to check it.
This is file with several files and instructions.
https://mega.nz/#!tUtnFRoL!jk5lGFxTHKpPhR8Fbc2rraF3z2VgFC0BEYZ8QjVUg3o
Color palettes preconfigured are following:
Black, Red, Pink, Yellow   ------> suggest for Theatre of Magic and Medieval Madness.
Black, Blue, Red, Yellow
Black, Blue Dark, Blue Light, White -----> Good look in X-Files
Black, Blue Dark, Green, White
Black, Blue Light, Blue Dark, White
Black, Blue Light, Orange, White  -----> Suggest for Addams Family
Black, Blue Light, Red, White
Black, Green, Blue, Yellow
Black, Green, Blue Dark, White
Black, Green, Blue Light, White
Black, Green, Orange, White -------> Suggest for Attack from Mars (or better replace orange by red).
Instructions, rename file desired to pin2dmd.pal and copy to root directoy in SD card, reset DMD.
Dernière édition par shadow_shd le Dim 21 Aoû 2016 - 8:57, édité 1 fois (Raison : Wrong SIZE tags removed ;))
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyDim 21 Aoû 2016 - 8:59
Thanks Luis [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302
I have edited your message, the Size tags were wrong Wink
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 13:48
More information, these are pictures about where get power supply 100VAC in real pinball to connect DMD. I will do more pictures as soon as possible, about all manufacturers (Bally/Williams (WPC, WPC95), Data East, Stern SAM, Stern WhiteStar, Spike, ).
These pictures for Bally/Williams WPC89, WPC-S.
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Sin_ty10
And these for Stern Spike:
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Spike_11
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Spike_14
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Spike_12
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Spike_10
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 14:37
Great news for those who want to replace a DMD Wink
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 15:06
Question bete :
le neutre est normalement bleu et la phase ou L marron et la c est l inverse ou je me trompe ?  [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 773715342
ikari
ikari
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 15:16
xavelios a écrit:
Question bete :
Ce sont des conventions, ça reste des bouts de cuivre ce qui compte c'est ce qu'il y a derrière Wink
Mais oui, la convention ça reste marron/noir phase et bleu neutre.
Je pense qu'il avait juste inversé le câblage de l’autre côté Wink
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 15:18
courant alternatif, donc pas d'importance.
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 16:27
je sais bien tout ca lol
je prevenais juste au cas car y a des standards a respecter  lol
Si j en commande un ce que je ne devrais pas tarder a faire d ailleurs je vois du bleu ca va au neutre un marron a la phase  Wink
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 23 Aoû 2016 - 17:47
This video about how connect wires with quick splice connectors, very easy and very fast. Only need connect two wires from DMD power supply to two wires 100VAC in pinball. Do not need cut or solder cables, and its reversible.
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 I1322.photobucket.com_albums_u573_planeta9999_conectores_rapidos_zpssclc2y8c
And in this picture of Bally/Williams (WPC89, WPC-S), in yellow circle conector where are the 100VAC wires (violet) in video controller board (connector J605, pin3 and 5, violet color cables).
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 I1322.photobucket.com_albums_u573_planeta9999_WPC_001_zpsyq5j5flo
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 I1322.photobucket.com_albums_u573_planeta9999_WPC_002_zpsow3loxzp
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 I1322.photobucket.com_albums_u573_planeta9999_WPC_003_zpsuuauilcr
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 I1322.photobucket.com_albums_u573_planeta9999_WPC_004_zpsscg0eciw
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMer 31 Aoû 2016 - 20:21
More pictures, these to connect power supply to Bally/Williams WPC95.
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wpc95_12
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wpc95_13
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wpc95_10
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wpc95_11
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMer 31 Aoû 2016 - 20:27
And more news.
1.- There is a new firmware version full compatible Spike that solve a few problems (delays and horizontal sync), this is the v2.33 version.
2.- About Data/Sega WhiteStasr and Gottlieb, also solved a problem with Black board, this install a LS123 chip to improve clock signal but do not work with standar firmware.  Data East and White Star were tested time ago with green board and worked fine (this board do not install LS123 chip).  Joerg has provide me a firmware version to run with LS123 chip, at any rate I will remove this chip from now in all Black boards to avoid this problem, so will work with standar firmware from Github. If somebody with Black board + LS123 chip need install DMD in Data/Sega Whitestar or Gottlieb, only need request to me the special firmware version, I will send it by private or email.
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyJeu 1 Sep 2016 - 15:41
Thanks for the info Luis, I will add it soon to the partnership announcement Wink
Edit :
Info added to the partnership thread.
Luis, I have beginning "playing" with the Wifi firmware Lucky1 provides in the 2.32 release.
I have an issue, I don't know if you'll be able to answer.
I've done exactly what is written in FLASH.md :
1-. Flash stm_esp_loader.dfu using DfuSe after setting Boot switch of my Black Board to OFF position.
2-. I unplug USB cable and 220 V power, set Boot switch to ON position and plug back USB cable only.
3-. I launch ESP8266Flasher.exe that sees the device on COM5 serial port :
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wifi110
I had to install STM Virtual Port drivers because I had a "device has a problem" issue.
4-. I enter exactly the values given to enter in the Config tab :
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wifi310
5-. In Advanced tab, I set Baudrate to 115200 and let others to default values (Flash size = 4MByte, Flash speed = 40Mhz and SPI Mode = DIO).
I don't want to change these values in case something goes wrong [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 773715342
6-. In Operation tab, I click on Flash button and then I switch to the Log tab, and after a while I got this :
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Wifi210
Error : Read ESP8266 register timeout.
I've done a Google search on this error but don't find any revelant tips that would help me, and I don't want to do stupid things before being sure I can do them or not [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 722859262
What do you think about this Luis ?
Thanks Wink
Edit : I've tested with the latest NodeMCU Flasher (32 bits) and I've got a successful flash Wink
After that I've updated with Pin2DMD firmware.
I have a new AI-THINKER_F36A11 wireless network. I connect my iPhone or my Mac and enter 192.168.4.1 as it is the DNS, but I have "server didn't respond" error.
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 15:26
Hello Alain.
Let me check it, latety I was bussy and I do not have test yet WIFI last version.
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 15:30
Thanks Luis, there's nothing urgent [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 15:35
Well seem you have install a wrong firmware, device AI-THINKER_F36A11 is wrong. With correct firmware you must to see something thart start with ESP_
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 15:46
Well I can't tell you Luis, I've used the files Lucky1 provides in the Pin2DMD master archive [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 773715342
I didn't want to ask on VPUniverse, as someone has asked about wifi setup and has been answered to ask you [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 722859262
But as you I suspect a wrong firmware, but that's beyond my knowledge Wink
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 16:29
Very Happy Very Happy  Well, I have develop hardware, but firmware is developed by Joerg.
Really who more know about it is Joerg, let me check what is the problem.
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyVen 2 Sep 2016 - 16:50
Thanks for your support Luis [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302
kwak
kwak
Département : 28
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyLun 5 Sep 2016 - 19:34
Vous en êtes ou de la commande groupée ?
Sinon je vais le commandé, le tarif c'est le tarif affiché en première page ou ça à changer avec le partenariat Pincabpassion ?
Merci Wink
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyLun 5 Sep 2016 - 19:42
Pour les membres de Pincab Passion c'est le tarif réduit qui s'applique [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302
Lorsque tu contactes Luis pour passer commande, tu indiques ton pseudo Pincab Passion ça sera plus facile pour lui Wink
kwak
kwak
Département : 28
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMar 6 Sep 2016 - 7:30
ok merci shadow Wink
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyMer 7 Sep 2016 - 21:48
This weekend I will check WIFI firmware update, to see if there is some problem, and will post detailed instructions with capture screens about it. If there is some problem I will contact with Joerg to solve it or clarify some steps of update.
Lately I was very busy and no time to check last update from Joerg that support for first time the ESP12 WIFI module, I think this weekend I will have free time to test all.
Also I will see if for next DMD's I may provide WIFI module with firmware already loaded and tested, because WIFI module may be also directly programmed from PC with a Serial to USB cable, so save time with no intermediate steps to load wifi loader firmware in microcontroller that work like a bridge to load WIFI firmware in ESP12.
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyJeu 8 Sep 2016 - 9:32
Thanks Luis Wink
Finally I've posted on VPU's thread, it seems I've forgot to check the checkboxes in NodemCU flasher [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 1502191233
I'll try in a few minutes and report back Wink
Edit :
It works cheers
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 Captur11
pinballsp
pinballsp
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyJeu 8 Sep 2016 - 15:36
Fine, I'm glad that everything works well.
[ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302 [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302 [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302 [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302 [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 3253257302
MessageSujet: Re: [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp   [ARCHIVÉ] DMDST32, DMD conçu et fabriqué par Pinballsp - Page 4 EmptyJeu 8 Sep 2016 - 15:55
A quoi sert le wifi ? (je l'ai sur ma ST32, mais il n'est pas activé).
Page 4 sur 6Aller à la page : Précédent  1, 2, 3, 4, 5, 6  Suivant
» [TUTO] DMDST32 by PinballSP
» [RÉSOLU] Problème Mise à jour pinballSp DMDST32
» [WIP] Pincab Mikaël
» [RESOLU] DMDST32 en mode DFU
» [RÉSOLU] cable usb DMDST32
