 [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO
traxx59
fastevie
nicofab18
Moussounet
Richard
leguluc
medax
badcat
khinyo
moviemaniac52
Migath
Nanard54
ventrax
ebor
hbenjam1
ParMesSoins
Snorky
bapt1080
yanfox
tyra38
poussmouss75
JLLL
BorisFR
xavuis
arnoz
vnguyenquangdo
valsy
Suby
isob
Matlo74
Gate
katzd
lyoxide
MAXxXAM
Sblawx
KM3L0TT
MrPomme
MarbleMad
mpierre
paf_prod
foudcox
Benoit33
Rappelbox
mikuslegrand
jawah
jadawin59
Mike72160
Arkan07
jolesharky
wspawn
Drask
BonZ@i
uncels
goliath59
kev1
jphil82
bao
rodolpher
mariela
davsouto
snwfrd38
Billy54
leopold
manples
kakou
sebx
82 participants
Aller à la page : Précédent  1 ... 11 ... 18, 19, 20 ... 31 ... 43  Suivant
Modérateur + Team PP
[TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 Empty
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyMer 16 Mai 2018 - 9:58
[Vous devez être inscrit et connecté pour voir ce lien] : OK, that's the good one, so try to flash it again with the good board selection in Arduino IDE and double check to overwrite the DOF with the last I posted.
https://www.pinballmag.fr
uncels
uncels
Département : hollande
MessageSujet: Good news, i guess   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyMer 16 Mai 2018 - 13:20
I saw life in the leds with the table: StrangerThings v2.21-MX DOF (with DOF as in example here Combo 1, 2 & 3 on Port 1,4 & 7 of WS2811
Or should it work with all vpx tables?
Not with the others so far, i will reflash it.
This is gonna be fun after a long frustration.
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyMer 16 Mai 2018 - 13:57
Good news so ! It supposes to work with others vpx table. Try with the twilight zone too... Afm have some effects too.
In fact, if you have the effects in stranger things, you should have for the others. Don't hesitate to share a video to show us what you have
uncels
uncels
MessageSujet: DOF   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyMer 16 Mai 2018 - 17:55
Aetios,
my cabinet is still early wip, waiting until my friend finds the time to build me a nice cabinet, until now all the components live in a bananabox....
I hope to have it finished soon, then i will present a video.
Now i can play around with some Dof effects & try some more tables, thanks for the help & attention so soon.
I pass this info on my Spanish friend, we were (on internet) together in a struggle to get DOF working on the Wemos.
I'll keep following this threat & tell Pinball Junkies that it can be done with a Wemos.
Happy Pinballing all.
Arkan07
Arkan07
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyMer 16 Mai 2018 - 20:09
[Vous devez être inscrit et connecté pour voir ce lien] ok il me semble avoir vu cette option sur un poste mais elle a disparu, je pensais qu’elle était déplacer ailleurs , je vais recherché la discutions
[Vous devez être inscrit et connecté pour voir cette image]Sujet: Re: [TUTO] Teensy controller   [Vous devez être inscrit et connecté pour voir cette image]Sam 30 Jan 2016 - 20:13
ici essayez 20 ou 10 ou 05 par exemple
EDIT 2
c'est bon j'ai trouvé voila les options de réglage pour la luminosité 5 c'est pas trop peu j'ai mis 20 c'est mieux
Désoler pour mes questions a répétition Wink maintenant si sa peut servir a quelqu'un [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
je pense que j'aurai d'autres questions je reviendrai [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 773715342
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 7:00
[Vous devez être inscrit et connecté pour voir ce lien] , pour régler la luminosité de tes leds ws2812 c'est ici dans le ledstrip.h mais l'inconvénient c'est qu'il faut reflasher la wemos à chaque fois , parce que dans le dof tu diminue également les autres leds , flashers etc... en même temps  quand tu modifie ces valeurs .
Arkan07
Arkan07
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 10:02
OK mais en fais j’ai une teensy j’ai posté ici car je pensais que le réglage au niveau du DOF était le même
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 10:08
[Vous devez être inscrit et connecté pour voir ce lien] : Regarde dans le code du teensy, il me semble que tu peux faire la même manip que pour la wemos... sinon c'est de la merde  [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3746298195
uncels
uncels
MessageSujet: Aetios another question   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 19:36
I'm a happy man, thanks to you [Vous devez être inscrit et connecté pour voir ce lien]
My kl25z (with uln2803) works as a ledwiz for my buttons with light, but if i want to make undercab light. Can i do that with a second wemos?
Because i can't do it with ledwiz & ws2812b.
I don't know what leds are normally used & how they connect them.
Anybody who can give me an answer to this?
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 21:32
For undercab, you don't need adressable leds, just buy RGB ledstrip (12V DC) like here
You can drive them with your kl25z but connect them with MOSFET or with multiple ULN2083 ports (500mA each but you can sum them)
uncels
uncels
MessageSujet: Thanks Aetios   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 17 Mai 2018 - 21:40
Now i understand how, i will order them.
Thanks again.
Arkan07
Arkan07
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyVen 18 Mai 2018 - 0:29
Non je viens de regarder et c'est plus simple par le Dof sinon faut changer pour chaque couleur lol, c'est donc plus simple avec la wemos, mais ce n'est pas non plus super lourd a faire  [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyVen 18 Mai 2018 - 6:45
En fait non , donc fait par le DOF si pour toi c'est mieux Wink  , j'ai aussi un TEENSY [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
Arkan07
Arkan07
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyVen 18 Mai 2018 - 8:20
Ok se serai cool d’expli La manip [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
jolesharky
jolesharky
Département : 10
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 24 Mai 2018 - 21:40
Bon, je reviens un peu en arrière concernant le fil de discussion.
J'avais viré les resistances pour les tests, les 330ohmes bloquaient le signal.
J'ai donc essayé des 220, marche pas non plus, 180 et 150, pas mieux !
Bref, des dès que j'y met une résistance, ça fonctionne plus.
Dommage, j'aurais aimé proteger mes strip..
wspawn
wspawn
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyJeu 24 Mai 2018 - 22:36
Salut alors voila pour revenir a nos mouton Wink
Je confirme le dof port 7 correspond au port d5 wemos .
Ensuite il est possible de travailler le ledstrip pour du minipincab ( travaux en cours ) mais c est chaud , minutieux et faut pas se louper Wink
jolesharky
jolesharky
Département : 10
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyVen 25 Mai 2018 - 0:05
La 60 LEDs par mêtre se coupe entre chaque led, c'est plus facile à installer pour un mini je pense et ça se soude très bien !
C'est très bien pour les côtés, mais c'est moins joli pour la backboard...
Donc ça dépend des effets qu'on veut donner.
Moi j'ai pas de backboard, juste un bandeau simple dans le fronton et les 2 cotés, et c'est joli aussi.
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyVen 25 Mai 2018 - 9:31
Les 144 leds se coupent aussi et se raccordent très bien , mais cela dépend de ce que tu reçois [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 1982470514
Pour les résistances  [Vous devez être inscrit et connecté pour voir ce lien] , je pense que cela dépends des bandeaux , certains nécessitent d'avoir 5v qui arrivent sur le fil data , d'autre fonctionnent très bien à partir de 3.3v , sachant que la Wemos balance 3.3v sur le data , il faudrait voir les spécifications de vos bandeaux [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 1982470514
[Vous devez être inscrit et connecté pour voir ce lien] j'ai corriger quelques trucs dans le code de la wemos , est ce que tu peux mettre le github à jour avec ma version [Vous devez être inscrit et connecté pour voir ce lien] et je suis en train de modifier le tuto également [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
jolesharky
jolesharky
Département : 10
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptySam 26 Mai 2018 - 0:32
Ah oui effectivement, ceux là ont l'air de se couper à chaque leds aussi...
Par contre reste pas grand chose pour les soudures !
Les spécifications pour les strip led c'est chaud, sur ebay, direct depuis la Chine...
Pas vraiment d'infos...
C'est des 5v, 60 LEDs par mètre. En bandeaux d'un metre.
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyDim 27 Mai 2018 - 11:14
As tu un lien [Vous devez être inscrit et connecté pour voir ce lien]
wspawn
wspawn
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyDim 27 Mai 2018 - 12:35
Sur ebay je  prend en general chez tubelight  c est un vendeur super serieux et tres rapide a l envois
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyDim 27 Mai 2018 - 12:40
[Vous devez être inscrit et connecté pour voir ce lien] c'est un lien que je veux , pour regarder les spécifications et voir pourquoi avec résistance ça fonctionne pas [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3746298195
Pourrais tu réduire ta photo stp [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3253257302
jolesharky
jolesharky
Département : 10
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyDim 27 Mai 2018 - 21:27
Le lien de ceux que j'ai pris...
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyLun 28 Mai 2018 - 16:17
Et maintenant on voit plus rien [Vous devez être inscrit et connecté pour voir ce lien] [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 722859262  mais ce n'est pas grave , la photo ne servait à rien [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 1502191233
Merci [Vous devez être inscrit et connecté pour voir ce lien] j'ai regardai ben vu qu'il n'y a rien , je pourrais rien en dire [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 3746298195 je lui ai quand même envoyé une question  [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 1982470514
wspawn
wspawn
MessageSujet: Re: [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO   [TUTO] Pilotage de Ledstrip adressable style "Teensy" via WEMOS D1 PRO - Page 19 EmptyLun 28 Mai 2018 - 19:54
Je regle sa Wink xd
Page 19 sur 43Aller à la page : Précédent  1 ... 11 ... 18, 19, 20 ... 31 ... 43  Suivant
» [ABANDONNÉ] Wemos led adressable
» [TUTO] Tutoriel SSF Impactor + modification WeMos
» [TUTO] Comment killer une bg style old b2s depuis un frontend
» [EN COURS] Led adressable
