| | [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) | |
| | Auteur | Message |
Olivierfr
Messages : 190 Département : Aquitaine
| Sujet: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Lun 8 Nov 2021 - 11:32 | |
| Bonjour, je suis entrain de paramétrer FX3 "non steam" sous Pinup Les tables se lancent, seul le plunger et le nudge ne fonctionnent pas. Apres avoir trouvé des informations sur le site, puis sur le net, avoir demandé de l'aide à différents contacts....j'ai fait ce script et modifié le fichier doflinx.ini @MAXxXAM @Moussounet @Shadow_SHD si vous avez des solutions, trouvé une/plusieurs erreur(s) , ou avez un tuto complet en Français, je suis à l'ecoute toujours pas de BG, de SSf, de led bar, de toys (ni plunger et nudge) voici mes toys sous dof : voici mon fichier DOFLinx.ini - Code:
#### # The config file for DOFLinx with most common settings as a sample # # Note - this works with LEDWiz, PacLed64, Pinscape, Ultimate I/O and Sainsmart (FTDI devices) # Edit this file as you see fit, lines that start with a hash (#) or are blank are not processed. This blurb and comments can be cut out if you want. # # Output devices outputs are entered in the format of # device (D) and output number (#) in the format D##, so controller device 1 and output 3 is "103" without the quotes, controller board 2 output 23 is "223" without quotes # # The keyboard hex code for the key that is used for each flipper from https://msdn.microsoft.com/en-us/library/windows/desktop/dd375731(v=vs.85).aspx # ####
# Point to your directoutputconfig.ini file. Your file may have a number, ie directoutputconfig20.ini # You can point to any of your directoutputconfig.ini files, but only one # Keep this as the first pararameter to process in your INI file. The order past ths point is not relevant
DIRECTOUTPUTCONFIG=c:\DirectOutput\config\directoutputconfig51.ini
# The location of the .FX3 game specific files included with the DOFLinx release package # Ensure your path has a \ on the end of it
PATH_FX3=C:\DirectOutput\FX3_PUPlayer\
# The path to where you keep all of the .directb2s files that you've downloaded for use with FX3 # Ensure your path has a \ on the end of it
PATH_FX3_B2S=C:\DirectOutput\FX3_B2S\
# This is the folder where B2SServer.exe can be found on your system
PATH_B2S_SERVER=C:\VisualPinball\Tables\
# The list of processes that can activate DOFLinx, in this case, Pinball FX2, Pinball FX3 and Future Pinball
PROCESSES=Pinball FX2,Pinball FX3,Future Pinball
# An over-ride to the default setting given this is just being used with Pinball FX3, not FX2, FP or other systems that may require the default delay
PROCESS_TO_ACTIVE_TIME=1
# Set the key code for the keys being used as Left and Right flippers # Used for the default fll back if a full link cannot be established # Left Shift = A0, Right Shift = A1
L_FLIPPER_KEY=A0 R_FLIPPER_KEY=A1
# Just in case things go wrong (ie no keyup signal is detected, flipper held down for a long time), what is the maximum time a flipper solenoid / contactor can be in in milliseconds MAX_FLIPPER_ON=5000
# Use random colour order for the RGB undercabinet lighting RGB_STYLE=RANDOM
# Use the flipper key press to to cause undercabinet lighting to change RGB_TRIGGER=FLIPPER
# The minimum time for change between flipper flips, 1000mS or 1 second RGB_MIN_TIME=1000
# The red device / port for undercabinet lighting, device #1, port 29 RGB_OUTPUT=129
# Turn on the attempt to make a full connection to Future Pinball when it is detected as running FP_ATTEMPT_LINK=1
# The device / port for the left and right flippers, set to output device 1, left flipper solenoid on port 1 and right flipper solenoid on port 2 L_FLIPPER_OUTPUT=119 R_FLIPPER_OUTPUT=116 LINK_LF=119,50,10000,255 LINK_RF=116,50,10000,255
# The other 8 solenoid of a 10 solenoid setup using ports 4 to 11 inclusive LINK_LS=120,50,500,255 LINK_RS=115,50,500,255 LINK_ML=114,50,500,255 LINK_MC=117,50,500,255 LINK_MR=117,50,500,255 LINK_BL=113,50,500,255 LINK_BC=113,50,500,255 LINK_BR=118,50,500,255
# Ports for the shaker, gear motor, knocker, beacon and strobe using ports 12 - 16 inclusive LINK_SH=110,1000,5000,255 LINK_GR=110,750,10000,255 LINK_KN=119,120,500,255 LINK_BK=110,FLASH,200,255 LINK_SR=116,ON,0,255
# Ports for the lights inside the various buttons being Start, Extra Ball, Coin, Exit, Launch Ball and Fire for ports 17 to 22 inclusive LINK_ST=100 LINK_EB=100 LINK_CN=100 LINK_EX=100 LINK_LB=100 LINK_FR=100
# The device and red ports for five flashers, these have been set in the example below as on the second output device, ie LEDWiz #2 LINK_FLOL=200 LINK_FLIL=200 LINK_FLCN=200 LINK_FLIR=200 LINK_FLOR=200
##### # Legacy FX2 colours - All other colours now in individual FX3 files ##### GAME_COLOUR=MsSplosionMan,Dodger_Blue,Pink,Medium_Blue,Purple,Royal_Blue GAME_COLOUR=PlantsVSZombies,Lime_Green,Yellow_Green,Dodger_Blue GAME_COLOUR=SouthParkButtersVeryOwnPinballGame,Dark_Red,Blue,Gold,Dark_Violet,Orange,Dodger_Blue,Lime_Green GAME_COLOUR=SouthParkSuperSweetPinball,Dark_Red,Lime,Blue,Gold,Dark_Violet,Orange,Dodger_Blue,Lime_Green,Yellow_Green GAME_COLOUR=SuperLeagueASRoma,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueZenStudiosFC,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueArsenalFC,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueLiverpoolFC,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueJuventus,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueACMilan,Lime_Green,Orange,Lime,Yellow,Red GAME_COLOUR=SuperLeagueRealMadridCF,Lime_Green,Medium_Blue,Lime,Yellow,Red GAME_COLOUR=SuperLeagueFCBarcelona,Slate_Blue,Lime_Green,Yellow,Blue_Violet,Lime,Red
et mes paramètres sous pinup:
| | | MAXxXAM
Messages : 501 Département : 27
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Lun 8 Nov 2021 - 19:43 | |
| | | Olivierfr
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Lun 8 Nov 2021 - 20:59 | |
| Merci @MAXxXAM de t'intéresser à mon pb J'ai essayé, comme tu peux le constater, si tu regardes mon .ini j'ai modifié les ports des solénoïdes et des liens fichiers pour le bg Mais rien ne marche, même pas 1 solénoïde, ni ssf, ni bg. | |
| | | MAXxXAM
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Lun 8 Nov 2021 - 22:23 | |
| concernant le point ini, voila ce que j'ai vu comme différence : moi je pointe sur le directoutputcongig30 et non 51, mais je ne sais plus pourquoi .... pour moi : DIRECTOUTPUTCONFIG=c:\DirectOutput\config\directoutputconfig30.ini un autre écart également, si comme moi tu a un UPC avec un kl25 dessus, je crois me souvenir d'avoir eu un pb de fonctionnement avec des adresse de toy en commençant par un 1, j'ai du tout mettre en 2 exemple pour toi : LINK_LF=119,50,10000,255 LINK_RF=116,50,10000,255 pour moi LINK_LF=218,50,10000,255 LINK_RF=230,50,10000,255 a tester concernant le launch setup de pinup, je ne fais pas comme toi, je lance doflinx au démarrage du pc, et il reste toujours actif, mais je ne pense pas que cela est une grande importance par rapport à ton pb et un autre truc aussi, pour aider à comprendre le problème, active le mode débug de doflinx pour voir le journal des événement : ###### DEBUG MODE ###### # 0 = OFF (normal operation), 1 = ON. When ON a window will appear and a log file will be created in the EXE directory. DEBUG=1 | |
| | | Olivierfr
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mar 9 Nov 2021 - 6:47 | |
| Merci pour ton aide, je vais essayer | |
| | | MAXxXAM
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mar 9 Nov 2021 - 20:10 | |
| salut @olivierfrun autre truc qui me turlupine et qui me fait dire que ce que je t'ai dit précédemment n'est surement pas suffisant pour résoudre ton pb. c'est que rien ne marche : B2S, SSF, toys et led le point commun à tout ça c'est le B2S serveur qui lance les plugin DOF pour les toys et les leds, et pinup pour le SSF (sur fx3 en tout cas) tu es sur de ton chemin d'accès au B2S serveur? PATH_B2S_SERVER=C:\VisualPinball\Tables\il ne te manque pas un espace entre visual et Pinball par exemple, ou une majuscule en trop ? pareil pour le nudge et le plunger, c'est par le pilote de manette x360ce que ça se gère. le nudge via le joystick analogique gauche de la manette, et le plunger via le droit tu l'a bien installé également? si oui, tu dois voir la valeur du cadre de droite doit changer quand tu tire sur le plunger, et les valeurs du cadre de gauche quand tu remus ton flip | |
| | | Olivierfr
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mar 9 Nov 2021 - 21:01 | |
| Merci pour ces conseils. sous X360 j'ai changé les axis 1/2/3 par 4/5/6 comme toi et ca fonctionne . Il faut maintenant que je trouve a faire les bons réglages dans left/right thump pour DOflinx.ini je ne sais pas j'ai mis DEBUG1 j'ai un message "the file DOFLinxExt.dll appears tu be blocked (internet). Please unlock this file and retry" mais pas de SSF/solenoides/led/bg je ne pense pas avoir d'erreur de chemin d'acces....sur le sript FX3 le dof fonctionne parfaitement sous pinup vpx | |
| | | MAXxXAM
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mar 9 Nov 2021 - 22:21 | |
| Pour le coup t’as vérifié dans les propriétés du fichier en question : doflinxext.dll, et vérifier qu’il n’est pas bloqué ? | |
| | | Olivierfr
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mer 10 Nov 2021 - 8:37 | |
| il est debloqué.... plus le message mais pas de changement notable
comme toi je soupçonne le b2s mais à quel niveau .... | |
| | | Olivierfr
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mer 10 Nov 2021 - 17:47 | |
| je tenais à te remercier @MAXxXAM pour ton aide. tu m'as parfaitement aiguillé c'était le DOF, j'ai fait la dernière mise à jour en R3++ et grâce à tes conseils CA MARCHE ps : tu as mis quoi comme réglages sous x360 pour ne bonne sensibilité pour left/right thump | |
| | | MAXxXAM
| Sujet: Re: [RÉSOLU] Parametrage fx3 sous pinup (toys, ssf, bg) Mer 10 Nov 2021 - 21:39 | |
| salut @olivierfrcooolll!! content de savoir que cela fonctionne pas besoin de me remercier, surtout que tu t'en es sorti tout seul pour trouver les vrais problèmes sinon je suis content d'aider à mon tour, comme tout ceux qui m'ont aidé quand j'en avais besoin... c'est juste l'ADN de ce forum, respect et entraide pour le réglage du plunger, moi j'ai ça : et pour le nudge (chez moi la kl25 est au fond du cab, donc peut être pas adapté à ta config) : | |
Sujets similaires | |
