| [DOF TERMINÉ] Baseball (Gottlieb 1970) | |
foxyt
Messages : 188 Département : essonnes
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Jeu 20 Jan 2022 - 17:40 | |
| Salut Je viens de tester la table (toujours sans les LEDs ),le DirectOutpout.log est sans erreur chez moi - Code:
--------------------------------------------------------------------------------- DirectOutput Version 3.1.6656.21457, built 2018.03.23 11:55 MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy DOF created by SwissLizard | https://github.com/mjrgh/DirectOutput 2022.01.20 18:30:17.339 DirectOutput Logger initialized 2022.01.20 18:30:17.211 Pre-loading DLL Ciloci.Flee.dll from C:\DIRECTOUTPUT\Ciloci.Flee.dll : ok 2022.01.20 18:30:17.213 Pre-loading DLL Extensions.dll from C:\DIRECTOUTPUT\Extensions.dll : ok 2022.01.20 18:30:17.216 Pre-loading DLL FTD2XX32.dll from C:\DIRECTOUTPUT\FTD2XX32.dll : ok 2022.01.20 18:30:17.217 Pre-loading DLL Newtonsoft.Json.dll from C:\DIRECTOUTPUT\Newtonsoft.Json.dll : ok 2022.01.20 18:30:17.218 Pre-loading DLL PacDrive32.dll from C:\DIRECTOUTPUT\PacDrive32.dll : ok 2022.01.20 18:30:17.218 Pre-loading DLL Q42.HueApi.ColorConverters.dll from C:\DIRECTOUTPUT\Q42.HueApi.ColorConverters.dll : ok 2022.01.20 18:30:17.218 Pre-loading DLL Q42.HueApi.dll from C:\DIRECTOUTPUT\Q42.HueApi.dll : ok 2022.01.20 18:30:17.296 Global config filename is "C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml" 2022.01.20 18:30:17.339 Global config loaded from: C:\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml 2022.01.20 18:30:17.339 Loading Pinball parts 2022.01.20 18:30:17.339 Loading cabinet 2022.01.20 18:30:17.340 No cabinet config file loaded. Will use AutoConfig. 2022.01.20 18:30:17.341 Cabinet auto configuration started 2022.01.20 18:30:17.667 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01 2022.01.20 18:30:17.668 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 32 2022.01.20 18:30:17.672 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log) 2022.01.20 18:30:17.680 Opening 32-bit LedWiz driver... 2022.01.20 18:30:17.680 Detected and added LedWiz Nr. 1 with name LedWiz 01 2022.01.20 18:30:17.682 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1 2022.01.20 18:30:17.684 Cabinet auto configuration finished 2022.01.20 18:30:17.684 Cabinet loaded 2022.01.20 18:30:17.684 Loading table config 2022.01.20 18:30:17.685 Warning: No table config file found. Will try to load config from LedControl file(s). 2022.01.20 18:30:17.685 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName Baseball_1970 2022.01.20 18:30:17.692 Loading LedControl file C:\DIRECTOUTPUT\config\directoutputconfig51.ini 2022.01.20 18:30:17.703 Min DOF Version is 0.8 for file directoutputconfig51.ini 2022.01.20 18:30:18.090 1 directoutputconfig.ini or ledcontrol.ini files loaded. 2022.01.20 18:30:18.091 Config for RomName Baseball_1970 exists in LedControl data. Updating cabinet and config. 2022.01.20 18:30:18.122 Table config loading finished: romname=Baseball_1970, tablename=Baseball (Gottlieb 1970) 2022.01.20 18:30:18.123 Pinball parts loaded 2022.01.20 18:30:18.124 Starting processes 2022.01.20 18:30:18.124 Initializing cabinet 2022.01.20 18:30:18.124 Debug: Initializing output controllers 2022.01.20 18:30:18.125 Pinscape Pinscape Controller 01 intialized and updater thread started. 2022.01.20 18:30:18.126 Debug: Initializing LedWiz Nr. 01 2022.01.20 18:30:18.126 Pinscape Pinscape Controller 01 updater thread started. 2022.01.20 18:30:18.127 Pinscape Pinscape Controller 01 updater thread has connected to Pinscape Pinscape Controller 01. 2022.01.20 18:30:18.127 LedWiz Nr. 01 initialized and updater thread initialized. 2022.01.20 18:30:18.127 Debug: Output controllers initialized 2022.01.20 18:30:18.128 Updater thread for LedWiz 01 started. 2022.01.20 18:30:18.131 Cabinet initialized 2022.01.20 18:30:18.134 Loading shape definition file: C:\DIRECTOUTPUT\config\DirectOutputShapes.xml 2022.01.20 18:30:18.212 Framework initialized. 2022.01.20 18:30:18.212 Have fun! 2022.01.20 18:31:15.423 Finishing framework 2022.01.20 18:31:15.425 Finishing cabinet 2022.01.20 18:31:15.426 Debug: Finishing output controllers 2022.01.20 18:31:15.428 Pinscape Pinscape Controller 01 updater thread has disconnected from Pinscape Pinscape Controller 01 and will terminate. 2022.01.20 18:31:15.429 Pinscape Pinscape Controller 01 finished and updater thread stopped. 2022.01.20 18:31:15.429 Debug: Finishing LedWiz Nr. 01 2022.01.20 18:31:15.429 Updater thread for LedWiz 01 terminated. 2022.01.20 18:31:15.442 LedWiz Nr. 01 finished and updater thread stopped. 2022.01.20 18:31:15.442 Debug: Output controllers finished 2022.01.20 18:31:15.442 Cabinet finished 2022.01.20 18:31:15.442 DirectOutput framework finished. 2022.01.20 18:31:15.442 Bye and thanks for using!
arngrim Développeur Team PP
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Dim 30 Jan 2022 - 9:55 | |
| - ebor a écrit:
- @arngrim, tu as une idée ? Il y a des chances que ça vienne ma config et pas du DOF de la table. J'ai peut-être une erreur dans le fichier de conf en xml.
Je relis les messages précédents, il y a (encore) un problème? | |
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Lun 31 Jan 2022 - 21:17 | |
| bizarre je ne reçois pas toutes les notifications
E203 Blue/E260 Red w400 f200/E216 Red f200/E214 Red f200/E206 Blue
il y a un espace à la fin
et
E207 Green/E260 Orange w200 f200/E213 Red f200/E218 Blue/E202 Blue/E220 Red /E231 Red
Il y a un espace entre le E220 Red et le /
pas sûr que ce soit ça mais essayez, je publie le fix | |
foxyt
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Lun 31 Jan 2022 - 21:28 | |
| Faut vraiment que je fasse gaffe avec la syntaxe . Promis je vais m'ameliorer J'ai envoyé ma config sur dof config avant de te lire donc valide la tienne et supprimer la mienne | |
foxyt
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Jeu 10 Fév 2022 - 17:45 | |
| Salut Pouvez vous me valider le fonctionnement pour la publier | |
leeoneil
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Jeu 10 Fév 2022 - 17:52 | |
| Je teste tout à l'heure ! @foxyt Ahem Ligne 1535/1536, juste après bumpersoff, tu ne voulais pas mettre un truc mais tu as oublié ? Genre DOF 101, DOFOff DOF 102, DOFOff | |
foxyt
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Ven 11 Fév 2022 - 17:07 | |
| arff !!!! le boulet si il manquait que ça ,je peux l'envoyer à Wildman ? | |
leeoneil
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Ven 11 Fév 2022 - 17:41 | |
| Moi je n'ai repéré que ça, le reste ça semble nickel. La table est ultra cool pour se réconcilier avec son knocker, vu qu'il y a 2 possibilités de faire claquer le truc (score et home-run), c'est très satisfaisant ! | |
foxyt
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Sam 12 Fév 2022 - 12:20 | |
| savez vous qui sont les admin de VPForum car la table est dispo aussi chez eux mais je ne voudrais pas m'attribuer la table car il m'ont déjà mis 4 roses (williams 1962 ) sur un autre post que la table originale ,c'est dommage | |
leeoneil
| Sujet: Re: [DOF TERMINÉ] Baseball (Gottlieb 1970) Sam 12 Fév 2022 - 16:22 | |
| Malheureusement, j'ai contacté noah fenz et ils ne peuvent pas faire ça sur vpforums. Perso j'ai décidé pour le coup de ne pas les coller là bas. Bon de toute façon tout le monde navigue entre les deux sites. | |
