| [TABLE] Ghostbuster Stern | |
+187Kenshiro68 CEGCAB TontonChelou shalkys ozloz31000 giotta stanimal CalimeroOeuf El'Baronrouge lemerle benoitdu77 biuod hypermc dario7218 Kidloco alucard_xs PO5481 cyrgeta Powerus Moussounet tomimpakt Darven Arkan07 dav7 yopsolo Steeven.14 hobuxo njaynl zack06007 Nesta78 leeoneil Francis971 berserk flajolbass ryguy417 julian1976 tealk oroborus77 heyjoe laulaw06 PDERYCHE marmotte666 stoneheart Maxwell42 ebor zax badcat zekill seriousam28270 ozon davadruix blouik titi29 Flaviox bono flashpc Vincent0047 defre1976 jawah philgoods9 leopold GUILLAUME49 Benoit33 katanka sarsouille28 tlub fraglerok01 17Al3x17 Draken06 colsaber Krys76 beckscc2010 Bigbeefr Snorky gangstaalien777 VPtouko810 foxyt roms34 vothar altimeuler GéraldB vilko zoubiwan quen ducatfrank nico7575 nitros alivan Fibology mrtr32 JohnRofls olijez Colonelpacman BorisFR TylerDurden67 vnguyenquangdo guhtravesso thebeast0449 Lee dujack Mikcab Rey blc29 doraj90 xphilou29 nicofab18 junkbox35 gigalula mikuslegrand sOuLWwX Kern glx Satansx phl0ve joku ze-bob POOTERMAN zedrummer giannibini lustucul BonZ@i TheHighFlying magnum1976 ElricDesDragons Carny_Priest sebinouse le.ced samsmile Rhis Spidey077 djtete pietjepukel jeyspeed optikazz Magicaurel Citron68 mikevirgil zubial moviemaniac52 snwfrd38 Sebcemoi neofr45 jéjé83520 jphil82 belgarion41 wspawn Mick_03 miket37 Mandrack obtender spike56 mouche jObiwan DamsBALL nussss lololol foudcox darkslide Nnanard8 Jannek42 chucky87 grozby88 xavelios khomodo g57 mariopourlavie PHILI50 garath AnthozoA jimenez nairolf firebrand007 Aetios ktmboy manples peskopat bip-bip-72 kwak vulbas lavache599 leevuth razorbaxx RipleYYY arngrim ced Shadow_SHD tom tower 191 participants |
razorbaxx Ancien du staff
| Sujet: Re: [TABLE] Ghostbuster Stern Sam 17 Mar 2018 - 23:29 | |
| oui je sais bien pesko ^^ mais je fait toujors des tests avant d integrer a pinballX | |
Mandrack
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 0:24 | |
| [Vous devez être inscrit et connecté pour voir cette image]J'ai bien suivi le tuto mais j'ai l'erreur suivante manque MSVCP110.dll. | |
jphil82
Messages : 106 Département : 82
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 3:23 | |
| fonctionne avec windows7 mais pas windows10, je n'y comprend plus rien et comme le pincab est en windows10 ,je laisse tomber,a moins d'une solution
marque laod dll ? | |
spike56
Messages : 118 Département : morbihan
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 8:54 | |
| Pour ceux qui ont un problème de dmd, télécharger le nouveau fichier VpinSPA.dll proposé par djrobx2,sa a réglé mon problème de dmd trop petit. [Vous devez être inscrit et connecté pour voir ce lien] | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 8:56 | |
| - peskopat a écrit:
- il faut copier ton dmddevice dans le dossier de vpinspa
Merci pour l'info [Vous devez être inscrit et connecté pour voir ce lien] j'avais un affichage en 2 couleurs - razorbaxx a écrit:
- je pense que c est pour eviter d avoir des souci ils te fournissent pas la rom cracké mais seulement le patch qui permet de le faire ensuite c est toi qui prend la responsabilité de cracker le jeux
Exact [Vous devez être inscrit et connecté pour voir ce lien] les fichiers sont sous copyright Stern / Steam - razorbaxx a écrit:
- perso pour les couleur de haut en bas j ai mit blanc / rouge / rouge avec luminosité a 60% / noir
le rendu est pas trop mal je trouve Je confirme c'est plutôt pas mal avec ces valeurs - bip-bip-72 a écrit:
- J'ai une erreur au lancement de la table.
Les fichiers à copier vers VPinSPA\Patch sont : → C:\Program Files (x86)\Steam\steamapps\common\Stern Pinball Arcade\SternGB.dll; → C:\Program Files (x86)\Steam\steamapps\common\Stern Pinball Arcade\Resource\TGhostBustersStern.dll (et non pas le fichier TGhostBustersStern_LE.dll). - lololol a écrit:
- voila j'ai crée un launch table audio pour ghosbuster a mettre sur les media pinballx
Merci [Vous devez être inscrit et connecté pour voir ce lien] le fichier sera ajouté au média pack - jphil82 a écrit:
- fonctionne avec windows7 mais pas windows10
Aucun problème sur mon cab en Windows 10 La DLL en question n'est pas bloquée sur ton système (clic droit / Propriétés et cliquer sur le bouton Autoriser si message "ce fichier provient d'un autre ordinateur...") ? La fiche Pincab Passion de la table : [Vous devez être inscrit et connecté pour voir ce lien]++ | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 9:25 | |
| - spike56 a écrit:
- Pour ceux qui ont un problème de dmd, télécharger le nouveau fichier VpinSPA.dll proposé par djrobx2,sa a réglé mon problème de dmd trop petit.
[Vous devez être inscrit et connecté pour voir ce lien] merci pour l'info spike | |
zubial
Messages : 419 Département : 67
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 9:59 | |
| Merci [Vous devez être inscrit et connecté pour voir ce lien], la nouvelle DLL a corrigé mes problèmes de dmd. Par contre j'aimerais savoir si tout comme moi et [Vous devez être inscrit et connecté pour voir ce lien] certains ont des problèmes lorsque il lance la table depuis VPX sans passer par pinballX. Pour rappel lorsque je lance la table Ghosbuster directement depuis VPX tout fonctionne, et lorsque je quitte la table pour en relancer une autre, j'ai le message suivant qui apparaît (exemple avec la table Twilihgt zone) : Machine 'tz_94ch' (Twilight zone (9.4CH Coin play)) terminated before intialized check the rom or rom file! | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 10:03 | |
| - zubial a écrit:
- lorsque je quitte la table
Tu as essayé de quitter VPX plutôt que de fermer la table et en ouvrir une autre ? Sauf erreur de ma part ça a résolu le problème pour Razorbaxx et c'est d'ailleurs une excellente habitude à prendre avec Visual Pinball : toujours le quitter avant de lancer une nouvelle table En tout cas je viens de faire le test et RAS tout fonctionne nickel ++ | |
zubial
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 10:16 | |
Effectivement en quittant VPX pour relancer une autre table, plus de message d'erreur . Et merci pour le conseil [Vous devez être inscrit et connecté pour voir ce lien] : TOUJOURS QUITTE AVANT DE LANCER UNE NOUVELLE TABLE | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 10:19 | |
| J'ai pas ces fichiers. [Vous devez être inscrit et connecté pour voir cette image] | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 10:21 | |
| bonjour, je ne quitte jamais vpx avant de lancer une nouvelle table, et j'ai jamais de problème. ca dépend des pc a mon avis [Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir cette image]Sujet: Re: Ghostbuster Stern [Vous devez être inscrit et connecté pour voir cette image]Hier à 13:06
| la table est sortie: en cas ou comment installer:Installation:-----1) Télécharger Stern Pinball Arcade à partir de Steam (Vous devrez peut-être installer l'application Steam):http://store.steampowered.com/app/56401…ll_Arcade/2) Copiez ces fichiers dans le dossier "Patch":SternGB.dllTGhostBustersStern.RezPour trouver ces fichiers, recherchez votre chemin d'installation Steam puis allez dans steamapps \ common \ Stern Pinball Arcade.Vous y trouverez SternGB.dll, tandis que TGhostBustersStern.Rez est dans le dossier "Resource".3) Une fois que vous les avez copiées, double-cliquez sur RunMe.cmd: cela créera un dossier spagb100. Déplacer ce dossier dans le dossier VpinSPA4) Vous pouvez supprimer le dossier "Patch" à ce stade. Maintenant, déplacez le dossier VPinSPA à l'intérieur de C: \ Visual Pinball5) Ouvrez le dossier VpinSPA et lancez InstallVpinSPA.exe (l'installation est similaire à l'installation de VPM).Remarque: Assurez-vous d'avoir installé les deux packages redistribuables Microsoft Visual C ++ 2010 et 2012.remarque comme j'ai eu un problème de pin2dmd :pour information a ceux qui ont pin2DMD:faut aller sur le dossier VpinMAME et copier le fichier dmddevice.dll dans le nouveau dossier VPInSPA sinon si vous faites pas ca, vous aurez une erreur ( No pindmd device detected)tu te trompe de chemin je crois regarde dans common qui se trouve dans steamapps |
jphil82
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 10:36 | |
| bon j'ais tous controlé et tous debloqués,changer de dll toujour meme probleme de dll | |
wspawn
Messages : 239 Département : Belgique
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:04 | |
| j'ai du rater un truck , le dossier "patch" avec vpispa je trouve sa ou ? | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:06 | |
| [Vous devez être inscrit et connecté pour voir ce lien] faut lire les instructions | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:08 | |
| [Vous devez être inscrit et connecté pour voir ce lien] on dirait que tu n'as pas installé Stern Pinball Arcade, ton dossier Steamapps est vide Je viens de t'envoyer un MP [Vous devez être inscrit et connecté pour voir ce lien] en cliquant sur le DMD sur la page Monsterbashpincab (oui moi aussi j'ai cherché ) : [Vous devez être inscrit et connecté pour voir cette image]++ | |
jphil82
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:10 | |
| tous est a jour .j'installe un anti virus que je rettirerais apres. j'ais eu le meme probleme avec evil dead sur w7 marche surw10 ne marche pas ???? | |
| pour vos probleme de dll [Vous devez être inscrit et connecté pour voir ce lien] et [Vous devez être inscrit et connecté pour voir ce lien] ce sont vos c++ redistribuable qui ne sont pas a jour | |
jphil82
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:14 | |
| ils sont a jour ,puis fait essai de desinstaler et mettre ceux du site MB ?Toujour pareil | |
wspawn
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:20 | |
| Merci voila ou je devait chercher la table :p) go me flageller | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:28 | |
| Dans pratiquement 99% des cas une table VPX qui génère une ou des erreurs c'est lié à une installation obsolète. Déjà pour Windows essayez d'activer les mises à jour complémentaires de Windows Update : [Vous devez être inscrit et connecté pour voir cette image]Et vérifiez la présence de mises à jour, on sait jamais vous risqueriez de tomber sur des MÀJ C++ redistribuables Pour ma part j'essaie d'être constamment à jour sur toutes les parties du système (Windows, VPX 10.5 beta, SAMbuild) et je n'ai jamais eu le moindre souci quelque soit la table, aussi bien Cactus Canyon Continued v2.0 que la Evil Dead (bah oui j'ai quand même essayé la dernière version même si je suis en désaccord total avec la façon de voir les choses de son auteur) ainsi que cette Ghostbusters ++ | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:37 | |
| J'ai installé via le lien [Vous devez être inscrit et connecté pour voir ce lien] | |
wspawn
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:38 | |
| L'erreur du load dll viendrai du c++ ? | |
| Sujet: Re: [TABLE] Ghostbuster Stern Dim 18 Mar 2018 - 11:40 | |
- J'ai installé via le lien
[Vous devez être inscrit et connecté pour voir ce lien] as tu vue une maj s'effectué quand tu as lancé steam avec stern pinball arcade | |
