DirectOutput Version 3.1.7776.42172, built 2021.04.16 23:25
MJR Grander Unified DOF R3++ edition feat. Djrobx, Rambo3, and Freezy
DOF created by SwissLizard |
[Vous devez être inscrit et connecté pour voir ce lien]2024.08.14 10:42:23.076 DirectOutput Logger initialized
2024.08.14 10:42:23.061 Global config filename is "C:\DirectOutput\Config\GlobalConfig.xml"
2024.08.14 10:42:23.076 Global config loaded from: C:\DirectOutput\Config\GlobalConfig.xml
2024.08.14 10:42:23.076 Loading Pinball parts
2024.08.14 10:42:23.076 Loading cabinet
2024.08.14 10:42:23.079 Will load cabinet config file: C:\DirectOutput\Config\cabinet.xml
2024.08.14 10:42:23.271 1 output controller defnitions and 3 toy definitions loaded from cabinet config.
2024.08.14 10:42:23.271 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig.
2024.08.14 10:42:23.271 Cabinet auto configuration started
2024.08.14 10:42:23.287 PhilipsHueAutoConfigurator.AutoConfig started...note, actual connection detection will happen asynchronously, and device disabled if not succesfull (check further down in the log)
2024.08.14 10:42:23.297 LedWiz-like device at VID=1103, PID=45845, product string=Thrustmaster dual analog 3.2, manufacturer string=Mega World
2024.08.14 10:42:23.302 Cabinet auto configuration finished
2024.08.14 10:42:23.302 Autoconfig complete.
2024.08.14 10:42:23.302 Cabinet config loaded successfully from C:\DirectOutput\Config\cabinet.xml
2024.08.14 10:42:23.302 Cabinet loaded
2024.08.14 10:42:23.302 Loading table config
2024.08.14 10:42:23.302 Warning: No table config file found. Will try to load config from LedControl file(s).
2024.08.14 10:42:23.302 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName afm_113b
2024.08.14 10:42:23.304 Loading LedControl file C:\DirectOutput\Config\directoutputconfig30.ini
2024.08.14 10:42:23.311 Min DOF Version is 0.8 for file directoutputconfig30.ini
2024.08.14 10:42:23.311 Resolving Tables Variables
2024.08.14 10:42:23.314 Resolving Global Variables
2024.08.14 10:42:23.989 1 directoutputconfig.ini or ledcontrol.ini files loaded.
2024.08.14 10:42:23.990 Config for RomName afm_113b exists in LedControl data. Updating cabinet and config.
2024.08.14 10:42:24.008 Table config loading finished: romname=afm_113b, tablename=Attack from Mars (Bally 1995) g5k 1.3.11
2024.08.14 10:42:24.009 Pinball parts loaded
2024.08.14 10:42:24.009 Starting processes
2024.08.14 10:42:24.009 Initializing cabinet
2024.08.14 10:42:24.010 Debug: Initializing output controllers
2024.08.14 10:42:24.012 WemosD1MPStripController Boognish intialized and updater thread started.
2024.08.14 10:42:24.012 Debug: Output controllers initialized
2024.08.14 10:42:24.013 WemosD1MPStripController Boognish updater thread started.
2024.08.14 10:42:24.015 Initializing ComPort COM10 with these settings :
2024.08.14 10:42:24.015 BaudRate 2000000, Parity None, DataBits 8, StopBits One, R/W Timeouts 300ms
2024.08.14 10:42:24.015 Handshake Timings : Open 300ms, Loop Start/End 100/100ms, DTR enable False
2024.08.14 10:42:24.016 Cabinet initialized
2024.08.14 10:42:24.019 Loading shape definition file: C:\DirectOutput\Config\DirectOutputShapes.xml
2024.08.14 10:42:24.072 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:35, W:100, H:
![Cool](/users/1414/11/35/46/smiles/3313507897.gif)
, Matrix(W:65, H:1), ResultArea(Left: 0, Top:22, Right:0, Bottom:27, Width:1, Height:6)
2024.08.14 10:42:24.072 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:7, W:100, H:6), Matrix(W:65, H:1), ResultArea(Left: 0, Top:4, Right:0, Bottom:8, Width:1, Height:5)
2024.08.14 10:42:24.072 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:15, W:100, H:6), Matrix(W:65, H:1), ResultArea(Left: 0, Top:9, Right:0, Bottom:13, Width:1, Height:5)
2024.08.14 10:42:24.072 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:65, W:100, H:15), Matrix(W:65, H:1), ResultArea(Left: 0, Top:42, Right:0, Bottom:52, Width:1, Height:11)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:70, W:100, H:20), Matrix(W:65, H:1), ResultArea(Left: 0, Top:45, Right:0, Bottom:58, Width:1, Height:14)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:10, W:100, H:90), Matrix(W:65, H:1), ResultArea(Left: 0, Top:6, Right:0, Bottom:64, Width:1, Height:59)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:80, W:100, H:10), Matrix(W:65, H:1), ResultArea(Left: 0, Top:52, Right:0, Bottom:58, Width:1, Height:7)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:80), Matrix(W:65, H:1), ResultArea(Left: 0, Top:0, Right:0, Bottom:52, Width:1, Height:53)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:100), Matrix(W:65, H:1), ResultArea(Left: 0, Top:0, Right:0, Bottom:64, Width:1, Height:65)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:70, W:100, H:30), Matrix(W:65, H:1), ResultArea(Left: 0, Top:45, Right:0, Bottom:64, Width:1, Height:20)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixShiftEffect. Calculated area size: AreaDef(L:0, T:65, W:100, H:15), Matrix(W:65, H:1), ResultArea(Left: 0, Top:42, Right:0, Bottom:52, Width:1, Height:11)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:15, W:100, H:
, Matrix(W:65, H:1), ResultArea(Left: 0, Top:9, Right:0, Bottom:14, Width:1, Height:6)
2024.08.14 10:42:24.073 Debug: MatrixBase for RGBAMatrixColorEffect. Calculated area size: AreaDef(L:0, T:0, W:100, H:6), Matrix(W:65, H:1), ResultArea(Left: 0, Top:0, Right:0, Bottom:3, Width:1, Height:4)
2024.08.14 10:42:24.081 Framework initialized.
2024.08.14 10:42:24.081 Have fun!
2024.08.14 10:42:27.530 EXCEPTION: Could not put the controller on com-port 'COM10' into the commandmode. Will not send data to the controller.
2024.08.14 10:42:27.530 EXCEPTION: Thread: WemosD1MPStripController Boognish updater thread
2024.08.14 10:42:27.532 WemosD1MPStripController Boognish updater thread has connected to WemosD1MPStripController Boognish.
2024.08.14 10:42:27.538 EXCEPTION: WemosD1MPStripController Boognish updater thread could not send update for WemosD1MPStripController Boognish: Comport is not initialized. Will try again.
2024.08.14 10:42:27.538 EXCEPTION: Thread: WemosD1MPStripController Boognish updater thread
2024.08.14 10:42:27.538 EXCEPTION: Message: Exception --> Comport is not initialized
2024.08.14 10:42:27.543 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.UpdateOutputs(Byte[] OutputValues)
2024.08.14 10:42:27.543 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt()
2024.08.14 10:42:27.543 EXCEPTION: Targetsite: Void UpdateOutputs(Byte[])
2024.08.14 10:42:27.543 Warning: WemosD1MPStripController Boognish updater thread tries to reconnect to WemosD1MPStripController Boognish.
2024.08.14 10:42:27.653 Initializing ComPort COM10 with these settings :
2024.08.14 10:42:27.653 BaudRate 2000000, Parity None, DataBits 8, StopBits One, R/W Timeouts 300ms
2024.08.14 10:42:27.653 Handshake Timings : Open 300ms, Loop Start/End 100/100ms, DTR enable False
2024.08.14 10:42:31.965 EXCEPTION: Could not put the controller on com-port 'COM10' into the commandmode. Will not send data to the controller.
2024.08.14 10:42:31.965 EXCEPTION: Thread: WemosD1MPStripController Boognish updater thread
2024.08.14 10:42:31.966 WemosD1MPStripController Boognish updater thread has reconnected to WemosD1MPStripController Boognish.
2024.08.14 10:42:32.075 EXCEPTION: WemosD1MPStripController Boognish updater thread could still not send update for WemosD1MPStripController Boognish: Comport is not initialized. Thread will quit.
2024.08.14 10:42:32.075 EXCEPTION: Thread: WemosD1MPStripController Boognish updater thread
2024.08.14 10:42:32.075 EXCEPTION: Message: Exception --> Comport is not initialized
2024.08.14 10:42:32.075 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.AdressableLedStrip.TeensyStripController.UpdateOutputs(Byte[] OutputValues)
2024.08.14 10:42:32.075 EXCEPTION: Stacktrace: à DirectOutput.Cab.Out.OutputControllerCompleteBase.UpdaterThreadDoIt()
2024.08.14 10:42:32.075 EXCEPTION: Targetsite: Void UpdateOutputs(Byte[])
2024.08.14 11:06:33.230 Finishing framework
2024.08.14 11:06:33.235 Finishing cabinet
2024.08.14 11:06:33.236 Debug: Finishing output controllers
2024.08.14 11:06:33.236 WemosD1MPStripController Boognish finished and updater thread stopped.
2024.08.14 11:06:33.236 Debug: Output controllers finished
2024.08.14 11:06:33.237 Cabinet finished
2024.08.14 11:06:33.237 DirectOutput framework finished.
2024.08.14 11:06:33.237 Bye and thanks for using!
