2015.02.09 21:58:23.487 DirectOutput Logger initialized
2015.02.09 21:58:23.487 DirectOutput Version 0.8.5307.1702 as of 2014.07.13 00:56
2015.02.09 21:58:23.487 Global config loaded from: D:\ROMS\VPINBALL\TABLES\PLUGIN\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml
2015.02.09 21:58:23.487 Loading Pinball parts
2015.02.09 21:58:23.487 Loading cabinet
2015.02.09 21:58:23.487 No cabinet config file loaded. Will use AutoConfig.
2015.02.09 21:58:23.487 Cabinet auto configuration started
2015.02.09 21:58:23.565 Detected and added PacLed64 Id 1 with name PacLed64 1
2015.02.09 21:58:23.565 Added LedwizEquivalent Nr. 20 with name PacLed64 1 Equivalent 1 for PacLed64 with Id 1
2015.02.09 21:58:23.565 Detected and added PacLed64 Id 2 with name PacLed64 2
2015.02.09 21:58:23.565 Added LedwizEquivalent Nr. 21 with name PacLed64 2 Equivalent 1 for PacLed64 with Id 2
2015.02.09 21:58:23.580 Detected and added LedWiz Nr. 8 with name LedWiz 08
2015.02.09 21:58:23.580 Added LedwizEquivalent Nr. 8 with name LedWiz 08 Equivalent for Ledwiz Nr. 8
2015.02.09 21:58:23.580 Cabinet auto configuration finished
2015.02.09 21:58:23.580 Cabinet loaded
2015.02.09 21:58:23.580 Loading table config
2015.02.09 21:58:23.580 Warning: No table config file found. Will try to load config from LedControl file(s).
2015.02.09 21:58:23.580 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName ij_l7
2015.02.09 21:58:23.596 Loading LedControl file D:\ROMS\VPINBALL\TABLES\PLUGIN\DIRECTOUTPUT\directoutputconfig20.ini
2015.02.09 21:58:23.892 Loading LedControl file D:\ROMS\VPINBALL\TABLES\PLUGIN\DIRECTOUTPUT\directoutputconfig21.ini
2015.02.09 21:58:23.970 Loading LedControl file D:\ROMS\VPINBALL\TABLES\PLUGIN\DIRECTOUTPUT\directoutputconfig8.ini
2015.02.09 21:58:24.017 Warning: Cant parse the part E105Sky_blue of the ledcontrol table config setting E105Sky_blue.
2015.02.09 21:58:24.017 EXCEPTION: Could not parse setting E105Sky_blue in column data E105Sky_blue.
2015.02.09 21:58:24.017 EXCEPTION: Thread:
2015.02.09 21:58:24.017 EXCEPTION: Message: Cant parse the part E105Sky_blue of the ledcontrol table config setting E105Sky_blue.
2015.02.09 21:58:24.017 EXCEPTION: Stacktrace: at DirectOutput.LedControl.Loader.TableConfigSetting.ParseSettingData(String SettingData)
2015.02.09 21:58:24.017 EXCEPTION: Stacktrace: at DirectOutput.LedControl.Loader.TableConfigSetting..ctor(String SettingData)
2015.02.09 21:58:24.017 EXCEPTION: Stacktrace: at DirectOutput.LedControl.Loader.TableConfigColumn.ParseColumnData(String ColumnData, Boolean ThrowExceptions)
2015.02.09 21:58:24.017 EXCEPTION: Targetsite: Void ParseSettingData(System.String)
2015.02.09 21:58:24.017 Warning: Previous exceptions occured in the line hawkman,E101,S7/W2|W12|W22 60 I48/E102,S1/S3/E103,S5/S6/W13|W23|W33|W43|W53|W63 60 I48,S8/W54|W64|W74 60 I48,S9/W42|W52|W62 60 I48,E104,E105Sky_blue,S48,S2/S46,0,0,0 of the ledcontrol file
2015.02.09 21:58:24.142 3 directoutputconfig.ini or ledcontrol.ini files loaded.
2015.02.09 21:58:24.142 Config for RomName ij_l7 exists in LedControl data. Updating cabinet and config.
2015.02.09 21:58:24.189 Table config loading finished
2015.02.09 21:58:24.189 Pinball parts loaded
2015.02.09 21:58:24.189 Starting processes
2015.02.09 21:58:24.189 Initializing cabinet
2015.02.09 21:58:24.189 PacLed64 Id:1 initialized and updater thread started.
2015.02.09 21:58:24.189 PacLed64 Id:2 initialized and updater thread started.
2015.02.09 21:58:24.204 LedWiz Nr. 08 initialized and updater thread initialized.
2015.02.09 21:58:24.204 Updater thread for LedWiz 08 started.
2015.02.09 21:58:24.204 Cabinet initialized
2015.02.09 21:58:24.235 Framework initialized.
2015.02.09 21:58:24.235 Have fun!
2015.02.09 21:58:57.306 Finishing framework
2015.02.09 21:58:57.306 Finishing cabinet
2015.02.09 21:58:58.336 PacLed64 Id:1 finished and updater thread stopped.
2015.02.09 21:58:59.366 PacLed64 Id:2 finished and updater thread stopped.
2015.02.09 21:59:00.396 LedWiz Nr. 08 finished and updater thread stopped.
2015.02.09 21:59:00.396 Cabinet finished
2015.02.09 21:59:00.396 DirectOutput framework finished.
2015.02.09 21:59:00.396 Bye and thanks for using!
